Members shelr1 Posted May 11, 2023 Members Report Posted May 11, 2023 I would like to build a DIY "box style " speed reducer. I understand the concept pretty well, I am thinking of a 3:1 reduction using a 6: OD and 2" OD pulley. My first question is, if you use 2 fixed pillow block bearings to support the shaft, how do you allow for adjusting the belt tension between the reducer and the sewing machine? I thought of use a 2 bolt flanged bearing and making one of the mounting holes slotted, would need to have same setup on both bearings does that seem like it would work? Also, I see a lot of 6" pulleys rated for 4L belts and I want to use 3L, can a 3L belt work well with the larger 4L pulley? I have seen some pulleys rated for 3L and 4L that's what I'm hoping to do. Quote
Members AlZilla Posted May 11, 2023 Members Report Posted May 11, 2023 I don't have a design for you but I do have a caution. I've been working to reduce a 111w153 by putting a bigger hand wheel on it. One thing I've learned is that hardware store pulleys aren't really very well balanced. I'm probably just going to end up with a servo. I could probably balance those pulleys well enough by using the same process we used decades ago to "balance" motorcycle tires. But it's reached the point of more work than I care to put into it. Quote
toxo Posted May 11, 2023 Report Posted May 11, 2023 3 hours ago, AlZilla said: I don't have a design for you but I do have a caution. I've been working to reduce a 111w153 by putting a bigger hand wheel on it. One thing I've learned is that hardware store pulleys aren't really very well balanced. I'm probably just going to end up with a servo. I could probably balance those pulleys well enough by using the same process we used decades ago to "balance" motorcycle tires. But it's reached the point of more work than I care to put into it. Not knowing where you are doesn't make helping you any easier. As I said before, I changed my handwheel, pulley and belt for less than £40. For the big wheel look for "taperlock" whatever the size of the big wheel, The taperlock bush is the same. I've never had a pulley wobble. The speeds we are talking about means that if the bore of the pulley is slightly bigger than the shaft pad it out with a piece of baked been tin or whatever. Quote
Members shelr1 Posted May 11, 2023 Author Members Report Posted May 11, 2023 The 2 pulleys I am using for this speed reducer are straight bore, common bore sizes are 1/2" or 5/8" or 15mm depending on the shaft that is selected. They can be keyed or set screw but typically a taper bore is not used in this application. If using a quality shaft and pulley the fit is not a problem as far as run out or balance is concerned. Quote
Members Garyak Posted May 11, 2023 Members Report Posted May 11, 2023 An idle/tensioner pulley. Since you’re talking diy, find an old domestic machines with the spring loaded lift assist. I had to make one for my 145w. Quote
kgg Posted May 11, 2023 Report Posted May 11, 2023 (edited) 4 hours ago, shelr1 said: My first question is, if you use 2 fixed pillow block bearings to support the shaft, how do you allow for adjusting the belt tension between the reducer and the sewing machine? The belt for: i) the large pulley is gets it's tension by the adjustment bolt on the servo motor frame ii) The small pulley gets it's tension by adjusting the vertical distance in relation to the hand wheel pulley. The advantage of the cantilever reducer pulley over the a system where you support a shaft between to bearings is the ease at which belts can be readily change. I am doing a hybrid of both where I am using a shaft supported by two pillar block bearings that cantilevers the reducer bearing off the cross bracing on the tables K-leg. Here is a couple of sketches that may give you some ideas. The first is just a front view showing a poor representation of the cylinder arm on top of the table. The second shows the placement on the cross brace where it will have two bolts through the cross brace. The third is of the pillow block bearings mounted to a flat plate with a slot cut out to allow the reducer pulley to move which would give tension on the belt from the small pulley to sewing machines hand-wheel. kgg Edited May 11, 2023 by kgg Quote
Members shelr1 Posted May 11, 2023 Author Members Report Posted May 11, 2023 kgg, thank you for the info. Yes it is the vertical tension between the hand wheel pulley and the small pulley I was asking about. I do like your idea of the cantilever arrangement for the shaft/pulley. I am putting this on a flat bed machine, just need see how that fits my machine. I do like the easy access to the belts on your design. Garyak, I appreciate your design idea, it reminds me of a belt tensioner on a car, and pretty easy to adjust. Quote
Members dikman Posted May 11, 2023 Members Report Posted May 11, 2023 Possible out-of-balance pulleys shouldn't be an issue if using a servo as the speeds are generally not fast enough to cause a problem. I have quite a few various size (generic) pulleys I've bought off ebay and none of them have had balance problems. Quote
Members shelr1 Posted May 21, 2023 Author Members Report Posted May 21, 2023 I'm making progress. This is pretty close to kgg's design. Quote
kgg Posted May 21, 2023 Report Posted May 21, 2023 8 minutes ago, shelr1 said: This is pretty close to kgg's design. Yep, that's damn close. Nicely done. That arrangement should help tame the clutch motor. The next step maybe to replace the clutch motor with a servo motor. A couple of questions: i) What sewing machine are you installing this on? ii) speed reducer shaft diameter, large pulley size and the motor pulley size. I'm assuming the motor speed is 1750 rpm. kgg Quote
Members shelr1 Posted May 21, 2023 Author Members Report Posted May 21, 2023 kgg, 1. it is a Pfaff 545, I recently purchased it. The clutch motor had a small pulley installed by the previous owner, so there was some speed reduction already. 2. Shaft dia. is 1/2", large pulley is 6" O.D. the small pulley is 1 3/4" O.D. These are rated for either 4l or 3l belts, I think I am close to a 4:1 reduction using a 3L belt. Quote
RockyAussie Posted May 21, 2023 Report Posted May 21, 2023 5 hours ago, shelr1 said: I'm making progress. This is pretty close to kgg's design. It May be just the picture but it looks like the small pulley mounted where it is would not allow a belt to miss the motor above it on the way up to the machine head. Quote
Members dikman Posted May 21, 2023 Members Report Posted May 21, 2023 Very nice job, looks good. Now, if you coupled that to a servo you could make the machine crawl like a caterpillar! Quote
Members shelr1 Posted May 22, 2023 Author Members Report Posted May 22, 2023 RockyAussie, the belt will clear , it is a little hard to tell from that angle. Thanks for the input. Quote
Members Quade Posted May 22, 2023 Members Report Posted May 22, 2023 I can buy a 1 HP servo for under $200 US. I'm wondering if the cost of parts for this reducer is approaching the cost of a servo? I'd simply never use a clutch motor. I took two to the dump the other day. Quote
Members shelr1 Posted May 22, 2023 Author Members Report Posted May 22, 2023 2 hours ago, Quade said: I can buy a 1 HP servo for under $200 US. I'm wondering if the cost of parts for this reducer is approaching the cost of a servo? I'd simply never use a clutch motor. I took two to the dump the other day. I have spent a little over $50.00 so far, add to that new belts about $9.00. I appreciate the servo motor option, I also really like the challenge of designing and implementing a mechanical reduction. Quote
Members shelr1 Posted May 26, 2023 Author Members Report Posted May 26, 2023 I got the belts installed, happy with the way it turned out. Quote
Members fibersport Posted July 15, 2023 Members Report Posted July 15, 2023 Sheir1 - would you mind sharing some of the details on the pulleys and pillow block bearings such as vendor and specs? Thanks Quote
Members Constabulary Posted July 15, 2023 Members Report Posted July 15, 2023 (edited) Not sure what he used but cheap pillow blocks for 15mm shafts can be found on Ebay F.I. Pillow Block Type KP002 https://www.ebay.com/itm/144782907792 a 40mm and 120mm pulley (for 1:3 reduction) with 15mm bore can be found here: https://www.ebay.com/itm/264553616997 15mm shaft: https://www.ebay.com/itm/163869249505?var=463451784748 Just some suggestions I have used these bits for some speed reducers and I´m running one with the above components on my Singer 51w post bed machine. I just have the reducer in a different position. Depends on your stand where you mount it. This is just how I did it. EDIT: You may find the bits cheaper if you dig deeper but smallest pulley here is 45mm https://www.ebay.com/itm/272680918308 Edited July 15, 2023 by Constabulary Quote
Members Constabulary Posted July 15, 2023 Members Report Posted July 15, 2023 I forgot this picture: Quote
Members AlZilla Posted July 15, 2023 Members Report Posted July 15, 2023 @Constabulary, I never thought of stapling a V-belt. But, why not ... we do it all the time with leather belts. Especially living where parts aren't plentiful and easy to find, this is a great idea. Next time I see them on sale/clearance cheap, I'll stock up. Quote
Members Constabulary Posted July 15, 2023 Members Report Posted July 15, 2023 Back then I had no proper size V belt for the test setup. But yes, it actually works. Quote
Members fibersport Posted July 15, 2023 Members Report Posted July 15, 2023 (edited) Thanks Constabulary, extremely helpful! In my mind I kept trying to find a 150mm pulley without much luck, never thought to just change the size of the smaller one as well. I'll be placing my orders tonight! Edited July 15, 2023 by fibersport spelling error Quote
Members Constabulary Posted July 15, 2023 Members Report Posted July 15, 2023 You are welcome BTW - toothed V-belts are better when you go around small size pulleys. Quote
Members fibersport Posted July 16, 2023 Members Report Posted July 16, 2023 Parts all on order, now to just try and be patient for them to arrive. Agreed on the belt also. Quote
