Members Jpmaringa Posted May 15, 2023 Members Report Posted May 15, 2023 Hello, all right, I would like your help to find the brand of this machine to restore it. Quote
kgg Posted May 15, 2023 Report Posted May 15, 2023 50 minutes ago, Jpmaringa said: I would like your help to find the brand of this machine to restore it. Looks like a short arm Alder to me. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted May 15, 2023 Moderator Report Posted May 15, 2023 @Jpmaringa, It is definitely an Adler short arm shoe patcher. If you can open the bobbin cover plate and take a picture of the bobbin and shuttle, I can tell you if it has a large or small bobbin. Also, post a picture of a needle, next to a ruler so I can identify whether it is a high or low lift model. These details will define its thickness capabilities and thread capacities. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted May 16, 2023 Members Report Posted May 16, 2023 Basically a short Arm version of the Adler 30 - usually the short arm is named 30-15 BUT the 30-17 should have a LARGE shuttle hook but with short needle (no high lift). A rare machine but in case you need parts most parts of the Adler 30-1 and 30-7 should work with your machine. The large hook and bobbins is the same as for the Singer 29K71. The machine seems to be a quite early one cause it has no quick release for the hand wheel which allows to wind the bobbin w/o running the whole sewing mechanism. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted May 16, 2023 Members Report Posted May 16, 2023 2 hours ago, Constabulary said: The large hook and bobbins is the same as for the Singer 29K71. I meant 29K72 But as WIZ said, post a picture of the shuttle to be sure it is a large hook machine. I could be "downgraded" to 30-15 - you never know... Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
CowboyBob Posted May 17, 2023 Report Posted May 17, 2023 The bobbin winder shaft looks like it's for a large bobbin,the 30-15 I have is a standard lift large bobbin.I've never seen a 30-17 b4. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Constabulary Posted May 18, 2023 Members Report Posted May 18, 2023 18 hours ago, CowboyBob said: The bobbin winder shaft looks like it's for a large bobbin,the 30-15 I have is a standard lift large bobbin.I've never seen a 30-17 b4. my records say the 30-15 is a small bobbin machine and 30-17 is large bobbin. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members chrisash Posted May 18, 2023 Members Report Posted May 18, 2023 Did Singer make the original design and sell the licence to others or was it another company? Quote Mi omputer is ot ood at speeling , it's not me
Members Constabulary Posted May 18, 2023 Members Report Posted May 18, 2023 I think Singers UFA / 29 was the earlier model but I don´t know if a license was sold to Adler but I don´t think so. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
