Members Dave45 Posted July 1, 2023 Members Report Posted July 1, 2023 I am a somewhat new leather worker but I’d like to make a holster similar to the one in the photo. My question is how is the holster most likely attached to the belt backer? Sewn, riveted, tee nuts or a combination of those? None of the holsters like the one in the photo showed the back of the holster. Thanks Quote
Members dikman Posted July 1, 2023 Members Report Posted July 1, 2023 My guess would be tee nuts sandwiched between the outer layer and liner. I just pulled apart an old Hunter western holster and that is how the pouch was held to the skirt. Quote
Members Dave45 Posted July 1, 2023 Author Members Report Posted July 1, 2023 1 hour ago, dikman said: My guess would be tee nuts sandwiched between the outer layer and liner. I just pulled apart an old Hunter western holster and that is how the pouch was held to the skirt. Thank you. I guess I will have to give it a try and see how it works. Quote
Members Dwight Posted July 1, 2023 Members Report Posted July 1, 2023 2 hours ago, Dave45 said: I am a somewhat new leather worker but I’d like to make a holster similar to the one in the photo. My question is how is the holster most likely attached to the belt backer? Sewn, riveted, tee nuts or a combination of those? None of the holsters like the one in the photo showed the back of the holster. Thanks It's a whole lot easier to make a flat backed pancake . . . you can get almost the same look . . . especially the tooling. OR . . . you make the holster . . . the back of it will be sewn to the belt loop piece . . . then folded over and the side seam sewn . It is some tricky sewing . . . and I really don't think this one was done that way . . . but the T nuts and screws will ALWAYS allow the holster to flop . . . and if you are not up to a floppy holster . . . (I'm one who can't stand it) . . . then ya gotta sew the thing. May God bless, Dwight Quote
CFM chuck123wapati Posted July 2, 2023 CFM Report Posted July 2, 2023 I wouldn't use nuts if its not lined. sew it on. Quote
Doc Reaper Posted July 2, 2023 Report Posted July 2, 2023 There might be a clip holding it in place Quote
Contributing Member fredk Posted July 2, 2023 Contributing Member Report Posted July 2, 2023 My turn; the holster is partly sewn to the back piece, just about where it will be folded over, then after the holster is folded over and shaped it is sewn to the back piece at the same time it is sewn closed Is there a prize for the best guess? Quote
CFM Frodo Posted July 2, 2023 CFM Report Posted July 2, 2023 Glued and sewn A tip for you apply glue to both pieces allow to dry apply a second coat Then sew Quote
CFM Frodo Posted July 2, 2023 CFM Report Posted July 2, 2023 5 hours ago, fredk said: Is there a prize for the best guess? A 2 slice toaster with a crumb pan Quote
CFM chuck123wapati Posted July 2, 2023 CFM Report Posted July 2, 2023 With three pieces of leather that thing has more stitches than Frankenstein's Bu** lol, that took some work. my self i would sew it on the same as any belt loop on that type of holster along the top and along the bottom or maybe even a rectangle about 1 3/4" wide x whatever length of the back piece don't let the shape throw you. Quote
Members Dave45 Posted July 2, 2023 Author Members Report Posted July 2, 2023 Thank all of you for your help. After my initial post I got the opportunity to see the Ghormley Hugger holster pattern from his 1911 pattern pack. It is sewn to the backer then the holster is folded and sewn closed. This may or may not be the way the one in the photo was done but I think it will work for me. Quote
Members dikman Posted July 2, 2023 Members Report Posted July 2, 2023 Sewing it would be better than T nuts, I reckon. Quote
