Members ToddW Posted July 2, 2023 Members Report Posted July 2, 2023 I see these wallets that say they block RFID readers.. what do they use to do that? is it a liner? Quote
Northmount Posted July 2, 2023 Report Posted July 2, 2023 On 7/2/2023 at 2:12 AM, ToddW said: I see these wallets that say they block RFID readers.. what do they use to do that? is it a liner? Expand Did you try a search here? Lots of threads. https://leatherworker.net/forum/search/?q=rfid&quick=1 Quote
Members ToddW Posted July 2, 2023 Author Members Report Posted July 2, 2023 ok.. that was my laziness.. sorry about that one.. Quote
Members Handstitched Posted July 2, 2023 Members Report Posted July 2, 2023 On 7/2/2023 at 2:12 AM, ToddW said: what do they use to do that? Expand For my own personal credit card, I went to the bank and got the ' pay wave' component deactivated . The EFTPOS machines kept picking up my credit card while it was still in my wallet and no-where near the machine, it was in my left hand and I do transactions with my right, either with cash or a savings card, go figure. I didn't realise how sensitive those machines are. But I really should think about using RFID shielding when I make wallets. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Contributing Member fredk Posted July 2, 2023 Contributing Member Report Posted July 2, 2023 I use plumbers' aluminium tape. A roll of about 45mm x 45m costs, generally, under £/$5, Wider widths and longer rolls are available but I find 45mm wide suitable. I've tested it and it works well, it blocks even sensitive card readers from reading cards right up to touching them. And a roll will last you a lot of card holders or wallets. Its very thin and self-adhesive. Just stick it on one or both pieces of leather forming the card pocket and cover with a thin piece of cloth lining material Quote Al speling misteaks aer all mi own werk..
Members pikefish Posted July 2, 2023 Members Report Posted July 2, 2023 As fredk recommends, aluminum foil works great too! Most gimick fabics dont work from my experience(ex IT geek), lots of theives line thier bags with alfoil to evade scanner... Im keen to make a rfid card holder too but looking for alternatives to aluminum, would that work long term? Also it has to seal well or be wrapped to work well? Quote
Members pikefish Posted July 2, 2023 Members Report Posted July 2, 2023 On 7/2/2023 at 3:52 AM, Handstitched said: For my own personal credit card, I went to the bank and got the ' pay wave' component deactivated . The EFTPOS machines kept picking up my credit card while it was still in my wallet and no-where near the machine, it was in my left hand and I do transactions with my right, either with cash or a savings card, go figure. I didn't realise how sensitive those machines are. But I really should think about using RFID shielding when I make wallets. HS Expand I use a scalpel and cutt the antenna off the chip, hold your card upto a bright light and make two cuts on each side off chip. Chip still works! Never trust a bank, lol. Quote
Contributing Member fredk Posted July 2, 2023 Contributing Member Report Posted July 2, 2023 On 7/2/2023 at 7:51 PM, pikefish said: Im keen to make a rfid card holder too but looking for alternatives to aluminum, would that work long term? . . . Expand The aluminium tape works, why look for an alternative? Why should it not work long term? There is no 'wear & tear' on its blocking On 7/2/2023 at 7:51 PM, pikefish said: Also it has to seal well or be wrapped to work well? Expand I made a simple card case as tester. The case held four cards. I put a piece of the adhesive aluminium tape on the inside side of each outer cover. Each piece was slightly larger than the cards. I covered that with thin cloth and sewed it up. No card reader could read any of the cards in the case. Quote Al speling misteaks aer all mi own werk..
kgg Posted July 2, 2023 Report Posted July 2, 2023 On 7/2/2023 at 8:07 PM, fredk said: The aluminium tape works, why look for an alternative? Expand I like the KISS solution. Cheap, simple, effective and functional. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members pikefish Posted July 2, 2023 Members Report Posted July 2, 2023 I was only concerned with long livity, most alfoil and tape seems to 'tarnish' and deteriorate over time. In usa it might be better than the junk were sold down under, lol Quote
Members dikman Posted July 2, 2023 Members Report Posted July 2, 2023 Tarnishing won't make any difference. If you feel it's too thin double it up, if you put something each side (leather, cloth whatever) to protect it then it should last a very long time. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Handstitched Posted July 3, 2023 Members Report Posted July 3, 2023 On 7/2/2023 at 11:48 AM, fredk said: I use plumbers' aluminium tape. Expand Might give that a go HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Contributing Member Ferg Posted July 3, 2023 Contributing Member Report Posted July 3, 2023 I have a roll of stainless steel cloth. Quote
Members Tugadude Posted July 3, 2023 Members Report Posted July 3, 2023 Nowadays there’s a better chance you will lose your whole wallet to a pickpocket than encounter someone exploiting RFID. Quote
Contributing Member fredk Posted July 3, 2023 Contributing Member Report Posted July 3, 2023 There has been a great increase in 'creeper' car thefts in the UK. N.I. is seeing the biggest increase. Several expensive cars just last week. It targets 'key-less' cars. In a 'creeper' theft the thief uses a special scanner reader to read the details of your electronic car 'key'. They can do it from up to 30ft from your key. Then they transfer the information to another device with which they can open your car and start it and drive away. All this inside about 3 minutes. The technology these thieves use is the same as used for reading debit or credit cards, oe even bus passes Quote Al speling misteaks aer all mi own werk..
Members pikefish Posted July 3, 2023 Members Report Posted July 3, 2023 (edited) On 7/3/2023 at 4:25 PM, fredk said: There has been a great increase in 'creeper' car thefts in the UK. N.I. is seeing the biggest increase. Several expensive cars just last week. It targets 'key-less' cars. In a 'creeper' theft the thief uses a special scanner reader to read the details of your electronic car 'key'. They can do it from up to 30ft from your key. Then they transfer the information to another device with which they can open your car and start it and drive away. All this inside about 3 minutes. The technology these thieves use is the same as used for reading debit or credit cards, oe even bus passes Expand Bit off topic sorry. Dumb cars, aka smart cars can be started and stopped from your phone, tablet, pc and remotely via evil corporation. Madness what they are promoting... Smart device = government/corporate control and data collection, not real smart. I drive a old 1993 4wd, I would never buy a digital car. Technology has been turned into a weapon and is being used against us! The manufacturer is the biggest criminals! Edited July 3, 2023 by pikefish spelling, lol Quote
CFM chuck123wapati Posted July 3, 2023 CFM Report Posted July 3, 2023 On 7/3/2023 at 5:20 PM, pikefish said: Bit off topic sorry. Dumb cars, aka smart cars can be started and stopped from your phone, tablet, pc and remotely via evil corporation. Madness what they are promoting... Smart device = government/corporate control and data collection, not real smart. I drive a old 1993 4wd, I would never buy a digital car. Technology has been turned into a weapon and is being used against us! Expand you have only touched on the tip of the iceberg my friend. 5g isn't for us its for them! Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM Frodo Posted July 3, 2023 CFM Report Posted July 3, 2023 Lead WOOL. Spread it on on a cloth beat to a consistent thickness sew it between layers do not suck on your fingers while working with lead or chew on it Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles Stand your ass up during the National Anthem
Contributing Member fredk Posted July 3, 2023 Contributing Member Report Posted July 3, 2023 On 7/3/2023 at 5:45 PM, Frodo said: Lead WOOL. . . . Expand you can buy sheets of extremely thin self-adhesive lead. Its meant for fly-making for fly fishing*. But, 1. its expensive for all you get 2. its much heavier than the aluminium tape, 3. if you go through a metal detector / scanner it will block that and you'll be pulled and searched * who fishes for flies? Quote Al speling misteaks aer all mi own werk..
CFM Frodo Posted July 3, 2023 CFM Report Posted July 3, 2023 On 7/3/2023 at 6:06 PM, fredk said: you can buy sheets of extremely thin self-adhesive lead. Its meant for fly-making for fly fishing*. But, 1. its expensive for all you get 2. its much heavier than the aluminium tape, 3. if you go through a metal detector / scanner it will block that and you'll be pulled and searched * who fishes for flies? Expand Searched? Having lead in your wallet is not a crime you can not be detained and searched for walking down the street Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles Stand your ass up during the National Anthem
Contributing Member fredk Posted July 3, 2023 Contributing Member Report Posted July 3, 2023 I meant, if you go through a metal detector at a government building or an airport the lead will block and the security staff there will want to know what the lead is hiding Quote Al speling misteaks aer all mi own werk..
Members pikefish Posted July 3, 2023 Members Report Posted July 3, 2023 On 7/3/2023 at 5:34 PM, chuck123wapati said: you have only touched on the tip of the iceberg my friend. 5g isn't for us its for them! Expand How long have you got? I could write a book on it! But Id get shot... I worked in IT/data communication, treasuries, reuters, big evil corps 20 years ago... Dont get me started mate, lol Quote
Members Tugadude Posted July 4, 2023 Members Report Posted July 4, 2023 https://losspreventionmedia.com/are-rfid-blocking-wallets-necessary-to-prevent-credit-card-theft/ Quote
Contributing Member MedusaOblongata Posted November 6, 2023 Contributing Member Report Posted November 6, 2023 Tl;DR: RFID blocking is not at all necessary for security. It's just a marketing feature for a wallet maker. I do leatherwork as a hobby but my day job is in the credit card department of a bank. Theft via portable RFID scanners had been becoming a major issue at one point, you could walk through a crowd of people with a scanner in a briefcase and from several feet away capture people's credit card information, which could then be used to make transactions. My bank stopped offering paywave as a feature on their cards. A few years later they reintroduced that feature on newer cards. I contacted our fraud department directly and asked why they would do this, considering the security risks we saw materialize last time. They got back to me and explained some of the features in the reintroduced RFID system. While the old ones could be read at a greater distance, current ones must be within 3 inches or less from the machine. The old ones gave out the card number itself, which is what thieves can use; the new ones work like the EMV chip, that does not give out the 16 digit card number, but instead generates a one time use code that only works for that one transaction. If anyone were to scan your card now, all they'd get is a one time use code that's already been used and they can't even use it for a single transaction. This is also what merchants get when you insert your card to use the EMV chip, the merchant never gets your actual card number (which is reusable), they get a code that works only once for that transaction. This way if the merchant's system is hacked, the hackers don't get CC#s they can use, they just get used up codes they can do nothing with. You don't need RFID blocking for security at all. It might be worth advertising it if your customers think it's a good idea, even though it won't improve their security. Quote
Members JohnNixon Posted May 1, 2024 Members Report Posted May 1, 2024 (edited) On 11/6/2023 at 11:28 PM, MedusaOblongata said: Tl;DR: RFID blocking is not at all necessary for security. It's just a marketing feature for a wallet maker. I do leatherwork as a hobby but my day job is in the credit card department of a bank. Theft via portable RFID scanners had been becoming a major issue at one point, you could walk through a crowd of people with a scanner in a briefcase and from several feet away capture people's credit card information, which could then be used to make transactions. My bank stopped offering paywave as a feature on their cards. A few years later they reintroduced that feature on newer cards. I contacted our fraud department directly and asked why they would do this, considering the security risks we saw materialize last time. They got back to me and explained some of the features in the reintroduced RFID system. While the old ones could be read at a greater distance, current ones must be within 3 inches or less from the machine. The old ones gave out the card number itself, which is what thieves can use; the new ones work like the EMV chip, that does not give out the 16 digit card number, but instead generates a one time use code that only works for that one transaction. If anyone were to scan your card now, all they'd get is a one time use code that's already been used and they can't even use it for a single transaction. This is also what merchants get when you insert your card to use the EMV chip, the merchant never gets your actual card number (which is reusable), they get a code that works only once for that transaction. This way if the merchant's system is hacked, the hackers don't get CC#s they can use, they just get used up codes they can do nothing with. You don't need RFID blocking for security at all. It might be worth advertising it if your customers think it's a good idea, even though it won't improve their security. People often use RFID-blocking materials in wallets to protect against unauthorized scanning of RFID chips found in credit cards and passports. This protection is crucial for personal security and privacy, preventing potential identity theft and financial fraud.For more insight into the technology that protects digital information and enhances financial transactions, consider visiting https://dashdevs.com/blog/digital-wallet-types-guide/ this guide offers comprehensive information on different types of digital wallets, including those equipped with security features that safeguard against various digital threats. Expand agree with you Edited May 1, 2024 by JohnNixon Quote
