I'm purchasing a Cobra 26 for my first sewing machine and I'm looking for information on a good high quality thread.  I've only used Ritza Tiger thread in 0.6mm, 0.8mm, and 1.0mm sizes and all has been hand sewed.  Is there a high quality brand that stands out above others for sewing machines?  Should I be using nylon or polyester or both?  I will be sewing sheathes, small holsters, outdoor items, bags, etc.  Are there any links to choosing threads for specific situations that you could lead me to?  Thanks
I have had my Class 26 for about a month now. You're going to love it!!!!!
It has definitely been a time saver though there has been a learning curve on somethings I make. I am following this topic, I'm curious about thread too. I bought some stuff off Amazon and it has been good so far, haven't had any problems so far but I'm sure there is much better thread out there.
The black nylon thread that Leather Machine Co. sent with the machine is my favorite!
Stay way from the cheap Chinese thread particularly in the 8 oz spool size. It can be a frustration generator. Buy a brand name sewing thread preferably one made in North America like A&E ( www.amefird.com ). Yes it will be more expensive but a quality products.
Depends on what you are sewing. If the item is going to be exposed to a lot of UV rays or bleach bonded polyester would provide better protection then bonded nylon. Typically bonded polyester has a slightly lower breaking strength then bonded nylon for the same size of thread.
You did mention "small holsters" the Cobra Class 26 can only handle up to V207 thread which maybe a little light for a holster. Some of the holster makers could address the best size of thread to use.
kgg
Moved your post to leather sewing machines.
Thanks for all the info.
I wanted to post the pictures below because when I was researching the Class 26, there was so much conflicting information.  Alot of people say it can't handle thread larger than 207 or that 3/8" is max thickness.  The leather below was sewn on a Cobra Class 26 with 277 on top and 207 in the bobbin and there were no issues at all sewing this.  It was sewn by a worker at Springfield Leather at my request.  I'm sure it's probably not smart to max it out daily but on occasions, I doubt it would hurt anything.  I found it to be very good information and contradicts what you always hear repeated about the Class 26.
WOW! This is awesome to see!! The folks at SLC are the best!
They must have tweaked that machine to sew 1/2 inch and, do it with #277/207 thread. I have tweaked a few of my Singer walking foot machines to sew thicker than normal, or to use heavier thread than the standard limit suggests. One of those tweaks is changing the needle system to a longer needle, allowing me to raise the alternating height of the feet. But, this had an adverse effect on thinner work.
Posted IMHO, by Wiz
You’ve received some great advice - good quality thread is nice to sew with.   Getting it from a reputable supplier is also a safe bet.  As thread ages the wax that bonds the fibers together can get hard and cause tension issues, so “good deals” on eBay may cause problems.
Having said that, after you’re up the learning curve and comfortable with the new machine, it’s nice to have a selection of sizes and colors, and low cost import thread is an option if you keep in mind it may not be as easy to sew with or even the correct size.  Measuring thread diameter and breaking strength isn’t necessary by any means, but if someone were to check, the cheaper import threads are generally on the thin side.
Good luck and enjoy that new machine!
Edited by DonInReno
  • 1 month later...
You can purchase Ritza Tiger for sewing maschines in 3 colors: JK1 White, JK21 Brown, JK23 Black.
Available thickness 0,6mm or 0,8mm - 1000m Spools.
You can purchase it by me in Germany. I have also Meisi Super Fine thread, that will be used with maschine.
Best regards
Igor
Best regards
Igor
I thought Ritza Tiger thread was for hand-stitching and not for sewing machines.
Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
