Members Rcc619 Posted August 10, 2023 Members Report Posted August 10, 2023 (edited) Hi guys, I am making a holster which I dye black but want to use white thread. I keep trying and I get bleed over into my stiches. I have tried dying and letting dry then stich. No go. I then tried dying and sealing then stich still no go. What is the trick I am missing? Edited August 10, 2023 by Northmount fixed title typo Quote
Members GrampaJoel Posted August 10, 2023 Members Report Posted August 10, 2023 (edited) Cotton thread or poly? machine stitch or hand? Edited August 10, 2023 by GrampaJoel Quote
Contributing Member fredk Posted August 10, 2023 Contributing Member Report Posted August 10, 2023 Possibly easier to control with hand stitching. Soak a good sealer in and around the sewing holes and use about 3 or 4 times the length of thread actually needed. By the time the tail of the thread is coming through the rub off should or may be just on the needle end Quote
Members GrampaJoel Posted August 10, 2023 Members Report Posted August 10, 2023 An after thought. Are you punching the holes and then dying? Joel Quote
Members zuludog Posted August 11, 2023 Members Report Posted August 11, 2023 (edited) I don't make holsters but I do make knife sheaths. This is my sequence for sewing black or dark brown leather with white or cream thread - Cut out natural veg tan leather ...... dye it with Fiebings oil/spirit/pro dye ....... glue ....... make stitch holes with a stitching chisel, usually followed up with an awl ..... saddle stitch with synthetic thread ..... even if it's ready waxed I usually wax it myself The thread is about 5X the line of stitching I've never had a problem with the thread becoming dirty/stained while I'm sewing. Edited August 11, 2023 by zuludog Quote
Members akguy59 Posted August 13, 2023 Members Report Posted August 13, 2023 I had the same problem when I used cheap dye. After switching to Feibing's Pro the problem went away. After reading this, it sounds like a commercial. It's not though, really happened. Quote
Members chiefjason Posted August 13, 2023 Members Report Posted August 13, 2023 I bet you are using USMC black. It's awful. If you are that's your problems. Fiebings Pro oil black is much better. Then pull out a lot more thread than normal. Let the extra thread on the end take on any excess dye. Quote
Members K5HEP Posted August 14, 2023 Members Report Posted August 14, 2023 On 8/11/2023 at 6:34 AM, zuludog said: I don't make holsters but I do make knife sheaths. This is my sequence for sewing black or dark brown leather with white or cream thread - Cut out natural veg tan leather ...... dye it with Fiebings oil/spirit/pro dye ....... glue ....... make stitch holes with a stitching chisel, usually followed up with an awl ..... saddle stitch with synthetic thread ..... even if it's ready waxed I usually wax it myself The thread is about 5X the line of stitching I've never had a problem with the thread becoming dirty/stained while I'm sewing. Spot on... Quote
