Members DieselTech Posted January 26, 2024 Members Report Posted January 26, 2024 Guys & gals dont laugh too hard, but here is my first pancake holster. Of course it's in a working progress. I made my own pattern from poster board & went from there. I used 6-7oz veg tan craftsman leather, & laminated/glued 2 pieces for the front & 2 pieces for the back of the holster. Lol 6-7oz glued together might be a touch much for the front piece of the holster. This for sure has been a learning process for me. But I think it's going to turn out ok. Next I need to figure out my stitch lines, then dye, & saddle stitch it together. What's your guys thoughts. Thanks. Quote
Members Sinbad395 Posted January 26, 2024 Members Report Posted January 26, 2024 Looks like it has potential to turn out real nice...when I do something pancaked I edge bevel the front panel before I glue and stitch. Both sides across the opening and all around the front panel. Makes it easier to blend the edge where front and back meet. Quote
Members DieselTech Posted January 26, 2024 Author Members Report Posted January 26, 2024 32 minutes ago, Sinbad395 said: Looks like it has potential to turn out real nice...when I do something pancaked I edge bevel the front panel before I glue and stitch. Both sides across the opening and all around the front panel. Makes it easier to blend the edge where front and back meet. I some what did that before I glued it, but not enough thou. Another thing is I used 2 pieces of 6-7oz leather for the front panel & it was too much I think. Lol was kinda hard to wet form by hand. This was kinda of a test run for a straight up carry pancake holster. Also was a test run for making a pattern. Next 1 I will have a vacuum pump & a forming bag to form the holster. Plus I think I'll step down to 4-5oz leather laminated/glued panels also. Thanks for the info. I appreciate it. Quote
Contributing Member JLSleather Posted January 26, 2024 Contributing Member Report Posted January 26, 2024 4 layers of 6/7 is GREAT for self-defense. Ya dont hafta shoot nobody - just hit em witda holster Okay, that's enough, I'm done there. GOOD to see the new guys jumpin' in both feet. That said ... I thik you gonna find it's tough to get a good grip on the grip .. might remove some leather in that area. As a rule, I start by drawin' the gun, then draw a line about 5/8" away from the bottom of the grip - more for hands bigger'n mine, maybe abit less for the mrs. ANd as you would suspect, the position of the slots matters. Higher the slots, the lower the carry. Each his own there... Is that the shield you was talkin' bout? Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members DieselTech Posted January 26, 2024 Author Members Report Posted January 26, 2024 28 minutes ago, JLSleather said: 4 layers of 6/7 is GREAT for self-defense. Ya dont hafta shoot nobody - just hit em witda holster Okay, that's enough, I'm done there. GOOD to see the new guys jumpin' in both feet. That said ... I thik you gonna find it's tough to get a good grip on the grip .. might remove some leather in that area. As a rule, I start by drawin' the gun, then draw a line about 5/8" away from the bottom of the grip - more for hands bigger'n mine, maybe abit less for the mrs. ANd as you would suspect, the position of the slots matters. Higher the slots, the lower the carry. Each his own there... Is that the shield you was talkin' bout? Lol! I did not want to start cutting up a new side of leather, in case my design did not work out. Lmao I used thick enough leather to use the holster as a hip support. Thanks for that drawing. Can I ask when it says 1/2" width frame + leather. Does that mean i should leave a 1/2" width from the gun to the stitch line? Yes i did put the belt slots up a bit high to the top, but I was just trying to do a straight carry/draw type pancake holster. Yes that is the shield I was talking about. I'm still going to get some of your patterns from you yet off of your site. Thanks again for all the help & info. Quote
Members DieselTech Posted January 26, 2024 Author Members Report Posted January 26, 2024 Now we got a multi-carry holster! I knocked another slot in there with my trace punch & gave the pistol a 15 degree cant on your hip. So now it can be configured/carried 2ways now. I even got some stitch lines & holes punched to saddle stitch it. Lol my diamond punches were just barely long enough. Quote
Contributing Member JLSleather Posted January 26, 2024 Contributing Member Report Posted January 26, 2024 56 minutes ago, DieselTech said: Can I ask when it says 1/2" width frame + leather. Does that mean i should leave a 1/2" width from the gun to the sti might could be the pic is a bit too small. that's not half INCH, that's HALF OF THE THICKNESS OF THE FRAME & LEATHER. So, assuming your frame was 1/2" thick, and your leather was 1/8" thick (exactly 8 oz), that's 5/8", and half of that would put your stitch line 5/16" away from the gun drawing. Keep in mind, this is a "starting point" - I have been known to alter the design like 4 times before i'm happy with the fit and land on a pattern. Not to sidetrack too much, worth mentioning here that this is the importance of the leather thickness. If you're molding the leather over the form (or gun, or whatever you're using), you can use whatever weight leather you want, then trim when it's formed. When cuttnig from a pattern, you need to use close to the weight of leather that the pattern was made with, or adjust the pattern to suit different leather thickness. As in... If the pattern says use 7/8 oz leather (mine usually do), I sometimes use 4/5 lined wit 3/4 without altering anything about the pattern (4.5 + 3.5 = 8 oz). If somebody asked for that same rig but in 10 oz leather, I know I'm only moving the stitch line HALF THE DIFFERENCE, so (2 more oz = 1/32", and half that distance is only 1/64"... so I just mark down the outside of the SAME LINE and It'll be fine). Start talking bigger thickness changes than that, you'd want to start kicking teh lines outward on th pattern. Im'a send you a sketch of the shield .. maybe save you some time. Use it, or pitch it, or whatever -- up to you. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members DieselTech Posted January 27, 2024 Author Members Report Posted January 27, 2024 59 minutes ago, JLSleather said: might could be the pic is a bit too small. that's not half INCH, that's HALF OF THE THICKNESS OF THE FRAME & LEATHER. So, assuming your frame was 1/2" thick, and your leather was 1/8" thick (exactly 8 oz), that's 5/8", and half of that would put your stitch line 5/16" away from the gun drawing. Keep in mind, this is a "starting point" - I have been known to alter the design like 4 times before i'm happy with the fit and land on a pattern. Not to sidetrack too much, worth mentioning here that this is the importance of the leather thickness. If you're molding the leather over the form (or gun, or whatever you're using), you can use whatever weight leather you want, then trim when it's formed. When cuttnig from a pattern, you need to use close to the weight of leather that the pattern was made with, or adjust the pattern to suit different leather thickness. As in... If the pattern says use 7/8 oz leather (mine usually do), I sometimes use 4/5 lined wit 3/4 without altering anything about the pattern (4.5 + 3.5 = 8 oz). If somebody asked for that same rig but in 10 oz leather, I know I'm only moving the stitch line HALF THE DIFFERENCE, so (2 more oz = 1/32", and half that distance is only 1/64"... so I just mark down the outside of the SAME LINE and It'll be fine). Start talking bigger thickness changes than that, you'd want to start kicking teh lines outward on th pattern. Im'a send you a sketch of the shield .. maybe save you some time. Use it, or pitch it, or whatever -- up to you. Thanks I appreciate your time & info there. When you talked about gun thickness & leather weight for pattern size/ allowance is what I was trying to figure out. Thanks that helps out a bunch when trying to get a good starting point. That holster there I made the top/outer layer a 1⅜ wider than the bottom of the holster. It was almost not enough for the thickness of leather I used. Quote
Members Hags Posted January 27, 2024 Members Report Posted January 27, 2024 I've been using JLS's method for pancakes for quite a while. Very good results for pistols. Thanks again JLS! Nice work by the way! I lay all mine out around the tracing of the pistol, mark the stitch lines, add belt loops (don't forget finger clearance under the grip and mag release!), add swoops and curves, I like a tooled reinforcing piece on the front, die, glue, sew, edge, mold, edge some more, mold some more, then finish. I'm sure I forgot a step or three. Your first looks a lot better than my first! Quote Not so retired RN. Living on the Washington Peninsula.
Members DieselTech Posted January 27, 2024 Author Members Report Posted January 27, 2024 16 minutes ago, Hags said: I've been using JLS's method for pancakes for quite a while. Very good results for pistols. Thanks again JLS! Nice work by the way! I lay all mine out around the tracing of the pistol, mark the stitch lines, add belt loops (don't forget finger clearance under the grip and mag release!), add swoops and curves, I like a tooled reinforcing piece on the front, die, glue, sew, edge, mold, edge some more, mold some more, then finish. I'm sure I forgot a step or three. Your first looks a lot better than my first! Thanks Hags I appreciate the vote of confidence. This is my 1st pancake style holster, for a auto. I've made quite a few revolver holsters & a couple mark ii holsters. Yeah I could not make my mind up which steps to do first. I will dip dye this in fiebings pro dye light brown. Yeah I think thinner leather next time & use the reinforcement piece on the front for the next holster. Thanks. Quote
