I buit a new shop out back for my leatherworking and have an inventory room with shelving..  I started adding the smart devices so I could keep an eye on things.. I have a Black and Decker portable AC/Heat/Dehumidifier in the main room and just added the Sensibo controller.. Also added a Govee remote hygrometer..  The main room has been showing 56% humidity and inventory room around 61%.  I bought the Govee dehumidifier to see if I could keep it below 50% but doesn't seem to move the needle much.. I am thinking I need to seal the workshop, but is is insulated and sheetrocked with moister barrier.. I am in the Dallas/Fort Worth (texas) and its been back and forth on temp.. was in the 80's day before yesterday... upper 40's yesterday and rainy and mid 40's today..
What started all this was I felt it smelt musty.. I have about 25 backpacks, 25 computer satchels and duffles in the inventory room... I don't anything to happen to my inventory while it sits..
Am I being to concerned or should I do something else as in where should the humidity level be?  The 61% had me a bit concerned..
Edited by ToddW
Around 45-55% is good.
You could have smaller, portable  dehumidifiers close to where the leather items are stored. I have  2 sensors in the same room, one near the leathers and one some distance away. Depending on whether I place a dehumidifier close to the leathers or not, the humidity readings on these sensors differ. So while you might not e able to get the humidity down in the whole room, you can do so in specific areas.
Learning is a life-long journey.
my leather storage room is about 6x12 with a barn door I can open or close. to the main workroom. its also insulated..  humidity seems to be sporatic.. up and down... just don't where I need to be concerned..
Edited by ToddW
You could do as I did. I got a humidity monitor with several sensors - placed them all around in the room. Then I could decide which areas needed a humidifier  and which  needed a de-humidifier. I bought several small humidifiers and dehumidifiers and placed them as needed. I check the monitor daily and maintain a healthy humidity for my leathers.
Before that, I bought  those packets of moisture absorbers and placed them near the leathers if the humidity was too high. They helped as well.
If the door to your inventory room is kept open for long periods, this will not work though. Humidifiers and dehumidifiers are most useful when areas are kept enclosed. I keep the door to my room closed at all times, opening only to enter or leave.,
Edited by SUP
First off I am going to assume you have a concrete floor and the shop was built recently. I think a contributing factor that maybe adding to the humidity in the shop is the concrete floor.
Concrete is porous and will absorb moisture from the air and vise versa. If a vapor/water barrier wasn't installed or is damaged under the concrete floor moisture will pass through the concrete which will increase humidity. I would check the humidity at floor level and compare it to the readings at normal height.
kgg
no concrete but shop was recently built.. .. I have 2x6's on cider blocks, moister barrier then 3/4 decking and a pergo wood floor
Edited by ToddW
Personally I find it interesting that you are having problems in getting your humidity down to 50%.  I have a whole-house humidifier that is struggling to keep the humidity above 40%.
I remember reading once that people who would buy antique furniture on the east coast and ship it to our area found that the wood would dry up and split out on them.  Makes me wonder if shipping leather goods between moist/dry regions would run into the same issues.
    /dwight
It can take a new built building up to to 2 or 2 1/2 years to stabilize with humidity/dampness in the material matching the surroundings
Air dry all your goods and wrap them in seran wrap / clingfilm enclosing a packet or three of silica gel. Re-wrap and check each item every 3 months
The dehumidifer for the inventory room has a 50 pint bucket and I am emptying it every day now.. I think I need to hook up the drain hose..  The main room has a black and decker ac/heater/dehumidifer and it has a hose.. running it on dehumidify..  I can't tell how much I am emptying that one.. today, the inventory room is running at 56% humidity and main room is running at 54%..
Edited by Northmount
fixed title typo
Be sure that you don't bring warm air into the enclosure as warm air is able to hold more moisture than cold air.  That's what your dehumidifier works on, cooling the air to knock out the moisture.
If you are bringing fresh air in, make sure it is only cold air.
fixed title typo
