toxo Posted April 9, 2024 Report Posted April 9, 2024 It's not too bad from ten feet but I don't care, I've learned so much. I like to challenge myself and this was a challenge . I even made the leather strap thing that goes around the cord and joined the pieces together with that diagonal/right angle thing. I didn't do myself any favours with a fairly tight curve and those corners were tough. Even though I skived everything it's difficult to find the piping under the second piece of leather and it's a constant worry that you want to get as close to the piping as you can but you don't want to break the needle. Not sure if I was using the right size piping foot and I'm not sure sure if a piping foot is even needed with tight corners because they just wanna go straight on. I don't know if I'm brave enough to attempt the smaller pocket that sits in the middle of this one. Quote
Members DieselTech Posted April 9, 2024 Members Report Posted April 9, 2024 Looks good to me toxo. I think you did fine. @toxo what machine did you sew your bag up with? Thanks. Quote
toxo Posted April 10, 2024 Author Report Posted April 10, 2024 10 hours ago, DieselTech said: Looks good to me toxo. I think you did fine. @toxo what machine did you sew your bag up with? Thanks. Thanks mate but I think you might be overdue a visit to the optician lol. The machine choice was purely because of the presser feet. I have lots of em for the Durkopp 239 and the new machine but not so much for the Adler 69 and because it was "practice" the thread/colour didn't matter so much either so the turned edges were done on the 69 using the colour "Toast" and the piping foot was on the new machine using a blue thread which also tested the theory that, if done right you won't see the thread. Quote
Members NatesLeatherGds Posted April 10, 2024 Members Report Posted April 10, 2024 Nice. Ok - million dollar question -- never done piping, I like the look - but... why piping ? Does it help structure? Look good? Opinions and facts welcome Quote Peace https://www.leatherandpaint.com
Members jrdunn Posted April 10, 2024 Members Report Posted April 10, 2024 40 minutes ago, NatesLeatherGds said: Nice. Ok - million dollar question -- never done piping, I like the look - but... why piping ? Does it help structure? Look good? Opinions and facts welcome Well, if you want opinions, I got 'em! Seriously, I think the piping "hides" the stitching on a turned item. It should also protect the thread from abrading if exposed. JM2C, Jim Quote
toxo Posted April 10, 2024 Author Report Posted April 10, 2024 (edited) 1 hour ago, NatesLeatherGds said: Nice. Ok - million dollar question -- never done piping, I like the look - but... why piping ? Does it help structure? Look good? Opinions and facts welcome This is a huge question. Firstly I'll repeat something I've often said, there's not a lot of mystery to leathercraft, far more common sense and finding a way to fulfill a purpose. "Piping" covers a huge swathe of applications. Piping "cord" can be many things. I put the commas around the word because some piping uses no internal cord at all. Then there is the choice of the size of cord that's used according to the project. As an example I think the size I used here is bigger than I would like for that size of pocket. If doing it for real it would be smaller. What's the cord made of? This goes to some of your question @NatesLeatherGds, plastic cord could help hold up a bag made of thinner leather, some piping cord is made of soft cotton type material which might be useful along with a soft leather when you don't want chafing against someone's skin such as clothing or a nice collar maybe. Of course most piping is used as a decorative detail and can be very effective and not just on edges either. I'm getting excited about learning about double piping on bag panels. Check this out. Forgive the ads. UPHOLSTERY TIPS - How you can make a double Piping - MECA - YouTube Edited April 10, 2024 by toxo Quote
RockyAussie Posted April 11, 2024 Report Posted April 11, 2024 I am no expert at doing piping either but for what it is worth I do the front or back panel first with the piping marked out glued on the stitched around the edge to hold it firm as shown in these pictures - This one shows the piping glued to attach to the back piece The corners have to be clipped to allow the piping to go around the tight curve The join overlap I do as shown I then stitch around the outer edge I then attach with clips the panel to the gusset as shown - This video shows the next step sewing the pieces together After that I run a binder tape around on the inside as shown in this video - The finished bag which is only a prototype at this stage hence a bit ordinary. Hope that is of some help. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members DieselTech Posted April 11, 2024 Members Report Posted April 11, 2024 1 hour ago, RockyAussie said: I am no expert at doing piping either but for what it is worth I do the front or back panel first with the piping marked out glued on the stitched around the edge to hold it firm as shown in these pictures - This one shows the piping glued to attach to the back piece The corners have to be clipped to allow the piping to go around the tight curve The join overlap I do as shown I then stitch around the outer edge I then attach with clips the panel to the gusset as shown - This video shows the next step sewing the pieces together After that I run a binder tape around on the inside as shown in this video - The finished bag which is only a prototype at this stage hence a bit ordinary. Hope that is of some help. @RockyAussie what class of cowboy sewing machine was you using in them sewing videos? Also where did you get your binder tape attachment? Thanks. Great videos by the way. Quote
RockyAussie Posted April 11, 2024 Report Posted April 11, 2024 3 hours ago, DieselTech said: @RockyAussie what class of cowboy sewing machine was you using in them sewing videos? Also where did you get your binder tape attachment? There are 2 different machines in use on them. The one with the binding tape is an Elizabeth TK-335 which is basically a copy of the Pfaff 335. The machine came with the binding parts already on it and the tape folding part came from the dealer but they are pretty common to get over the net. The Cowboy one is a CB246 which is basically a copy of a Juki machine. I believe they don't stock them in the States but Techsew have a version which is 2600 if you want to check them out. This video I did awhile back shows some of the features I think are important - Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Doc Reaper Posted April 11, 2024 Report Posted April 11, 2024 I have been wanting to do piping, but I don't know where to find affordable setups for a cowboy 4500, I'm open for suggestions Quote Doc Reaper
