Members AlamoJoe2002 Posted November 29, 2024 Members Report Posted November 29, 2024 I made a belt from Wicket & Craig chestnut veg-tan 12 ounce hide. After the neatsfoot oil (NFO) coating dried a few weeks I applied black dye. I used “Feibings Black Leather Dye.” The dye bottle doesn’t specify water or alcohol based product. It is not legal for sale in California. I finished the edges and applied a homemade sealer of NFO, bees and carnauba wax.The stuff is stiff as a wax candle poured from a teflon mold the size of an 8 ounce butter stick. I continue to use a t-shirt to remove trace of black dye rubbing off the belt. I read a few forum posts about this problem. I have a few choices…keep rubbing for the next century, seal it up with a 50/50 rosolene product…or murder it with a rag and steel wool full of xylene or toluene to remove anything black. I need a reasonable solution because the dye mixed with the homemade wax sealer and contaminated everything. Do I remove the wax sealer or seal it up? Happy Thanksgiving to Everyone Around the World, Joe Quote
Members DieselTech Posted November 29, 2024 Members Report Posted November 29, 2024 I am wondering if you possibly got too much neats foot oil in the belt. Usually 24-48 hours is sufficient for the neatsfoot oil to distribute thru the belt. I would wipe it down with a rag & acetone & then let it dry completely. Then check it for dye rub off. Others may have a better solution. Quote
Members Dwight Posted November 30, 2024 Members Report Posted November 30, 2024 I never add more than a perfunctory coat of NFO . . . hair sde only . . . just enough to make it look wet as you put it on. The leather should be VERY close to it's original color within 12 to 16 hours . . . or you put too much on. Never mix anything other than some alcohol or Feibings reducer with the dye . . . and mix it 50/50 for best results. Wax will not seal the dye pigments . . . something like Resolene is necessary . . . even if you rub it till the cows come home . . . perspiration will leach out the pigment from the leather. Might try Diesel's idea . . . personally I've never ran into such a problem May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members DieselTech Posted November 30, 2024 Members Report Posted November 30, 2024 14 minutes ago, Dwight said: I never add more than a perfunctory coat of NFO . . . hair sde only . . . just enough to make it look wet as you put it on. The leather should be VERY close to it's original color within 12 to 16 hours . . . or you put too much on. Never mix anything other than some alcohol or Feibings reducer with the dye . . . and mix it 50/50 for best results. Wax will not seal the dye pigments . . . something like Resolene is necessary . . . even if you rub it till the cows come home . . . perspiration will leach out the pigment from the leather. Might try Diesel's idea . . . personally I've never ran into such a problem May God bless, Dwight Do you think it is something about the black dye with rub off? It seems like it is a re-occurring question asked on here & it always seems to be black. Or do you think it is more to do with how it was applied? Quote
Northmount Posted November 30, 2024 Report Posted November 30, 2024 8 hours ago, AlamoJoe2002 said: I applied black dye. I used “Feibings Black Leather Dye. If it was USMC black, it takes a lot of buffing to get rid of the 'loose' pigment on the surface. Needs to be sealed with a good quality water based or lacquer. Anything else doesn't provide a real seal. Oil and wax change consistency with temperature and rub off. Quote
Members Dwight Posted December 1, 2024 Members Report Posted December 1, 2024 On 11/29/2024 at 7:41 PM, DieselTech said: Do you think it is something about the black dye with rub off? It seems like it is a re-occurring question asked on here & it always seems to be black. Or do you think it is more to do with how it was applied? Actually all of the Feibing dyes have a bit of rub off. Diluting it 50/50 with reducer will give a smoother color in the finished product . . . AND . . . cut the rub off by maybe 75% I do a dip dye on all my products . . . it is totally immersed at some point in the dye. Probably get less rub off if done with sheep wool pieces . . . but I just never could get the smooth color that way that I like. And Northmount is fully correct about USMC black dye . . . more loose pigment there than you can hardly ever rub off. Black dye gets the attention because it is too easily detected . . . but the browns do the same . . . that's the reason I like resolene so well. Seals it up . . . permanently. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
CFM chuck123wapati Posted December 1, 2024 CFM Report Posted December 1, 2024 NFo isn't a coating it is an oil, it is used to add some oil back into the leather as a Liquor or conditioner. Depending on the amount you use you can make your leather products vary in stiffness or flexability. I use very little on holsters for example but use more on leashes and straps so they become softer and more supple. here is a link to the instructions on the application of the dye. hope this helps. https://fiebing.com/ufaqs/how-do-i-dye-leather/ Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
