rktaylor Posted 11 hours ago Report Posted 11 hours ago My bottom stitches aren't clean when I start. I make one forward stitch, back stitch, then go forward to finish. I have a Cobra 4. The pictures are of the bottom and top. Any thoughts? Thanks, Randy Quote
Members Goldshot Ron Posted 7 hours ago Members Report Posted 7 hours ago Randy, what I do to avoid this problem is to use an overstitch wheel and mark about 4 or 5 stitch marks. Start at the third or fourth mark in reverse to the number one mark, then go forward from there. Make sure you hold both threads when starting. Ron Quote
AlZilla Posted 6 hours ago Report Posted 6 hours ago Yep, Goldshot Ron has it. Rookie 441 operator here and I've struggled with those backstitches, too. I've started figuring where 3rd stitch will end (4th hole), hover my needle exactly there and backstitch 3 stitches (drop the needle 3 times). Then, with the needle buried, drop the lever to forward and go. Seems to make a consistent decent stitch. I trim my tails with a pair of nail clippers. If there's any doubt, I use a pin or needle to drop just a little super glue in the hole where the cut tail pops through. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
rktaylor Posted 6 hours ago Author Report Posted 6 hours ago Thanks. I've never been able to 'eyeball' the second or third stitch very well. Using a stitch wheel is a great suggestion. Randy Quote
Members BlackDragon Posted 6 hours ago Members Report Posted 6 hours ago There are usually two ways I lock my stitching in. The standard way I do it is to start in reverse do three stitches, then go forward. The other way I do it that's not the norm is to start forward but leave extra thread so I can come back and hand stitch three holes to lock my thread in. I do this when I need a precise start and end point. Quote
AlZilla Posted 5 hours ago Report Posted 5 hours ago 1 hour ago, rktaylor said: Thanks. I've never been able to 'eyeball' the second or third stitch very well. Using a stitch wheel is a great suggestion. Randy Run some stitches without thread in scrap or cardboard, too. It's an exact template of your current stitch length setup. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members Hildebrand Posted 3 hours ago Members Report Posted 3 hours ago I use a set of calipers to find that 4th hole, leave machine in forward but stitch back to the start point, stop the needle just after it starts back up and the turn the work around and stitch forward through the stitches I just made. I don't have to worry about forward and reverse stitches being exactly equal in length. I keep scrap around so I make sure how long 3 stitches is currently on the machine. Todd Quote
Members Cumberland Highpower Posted 1 hour ago Members Report Posted 1 hour ago (edited) Why not just start your work one hole from the end? Make one stich (or 2) and turn the work around 180 degrees and chug away? I've almost never used a reverse on a machine. Some machines just aren't timed right. is your forward and reverse identical in stitch length? There can also be times when a switch to reverse and then forward again wont pull the lock up right. (geometry). Just things to consider. Edited 58 minutes ago by Cumberland Highpower Quote
AlZilla Posted 31 minutes ago Report Posted 31 minutes ago 34 minutes ago, Cumberland Highpower said: Why not just start your work one hole from the end? Make one stich (or 2) and turn the work around 180 degrees and chug away? For me, my big machine stitches the same in both directions. My 111Ws don't have reverse so either I do the turn around trick or leave long tails that I backstitch or tie off by hand. It all works. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
AEBL Posted 22 minutes ago Report Posted 22 minutes ago Someone recommended here once that you backstitch with double needle (saddle stitch) if you want it to look great and don't have to do too many of them. I have been doing that with my very low volume hobby (translates as "business that I lose money doing"). Quote
