toxo Posted August 28 Report Posted August 28 After years of taking my one belt from one pair of trousers to use on another pair, bearing in mind what I do I finally got disgusted enough with myself to start on three more. Bearing in mind that my world is practical and not for the benefit of others, it will just be one layer and rivets so I should be finished by the end of today. Quote
CFM chuck123wapati Posted August 28 CFM Report Posted August 28 11 minutes ago, toxo said: After years of taking my one belt from one pair of trousers to use on another pair, bearing in mind what I do I finally got disgusted enough with myself to start on three more. Bearing in mind that my world is practical and not for the benefit of others, it will just be one layer and rivets so I should be finished by the end of today. Good luck!! Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Dwight Posted August 28 Members Report Posted August 28 That's why in my "wardrobe" . . . there are no less than 8 or 9 belts. Generally speaking . . . I wear the one I have on . . . and have for over 20 years . . . will probably kick the bucket some day and it will still be serviceable. But that's OK . . . pass it on to someone who needs one. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
kgg Posted August 28 Report Posted August 28 3 hours ago, toxo said: Bearing in mind that my world is practical and not for the benefit of others, it will just be one layer and rivets so I should be finished by the end of today. I would be interested in seeing the belts. 2 hours ago, Dwight said: That's why in my "wardrobe" . . . there are no less than 8 or 9 belts. Me I have two belts. A store bought "genuine" leather black dress belt which I figure I have worn maybe a dozen times in the last 8 years and my daily 13 oz medium brown chrome tan. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
toxo Posted August 28 Author Report Posted August 28 The bottom one just needed a little messing and re dying so I only had to do two. Still waiting for some cord to finish my corset hat. Quote
kgg Posted August 28 Report Posted August 28 1 hour ago, toxo said: The bottom one just needed a little messing and re dying so I only had to do two. They are decent enough, better then some I have seen for sale. Suggestion: Add a stitch line along the edge to help reduce stretching. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
toxo Posted August 28 Author Report Posted August 28 48 minutes ago, kgg said: They are decent enough, better then some I have seen for sale. Suggestion: Add a stitch line along the edge to help reduce stretching. kgg If I ever make a "real" one it'll be wider with two layers and glued and stitched. These are just to hold my trousers up and stop me wondering which pair of trousers I left my one belt on last. Quote
Members dikman Posted August 28 Members Report Posted August 28 Functional, should do to keep your pants up while you make yourself some fancier ones. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
kgg Posted August 28 Report Posted August 28 6 hours ago, toxo said: If I ever make a "real" one it'll be wider with two layers and glued and stitched. Couple of questions: i) How wide are the belts?? On this side of the pond the typical width is 1 1/2" (38mm) for say jeans while 1 1/4" ( 32mm) is more for dress pants. ii) How thick is the leather, 8 / 9 oz?? iii) Did you glue, staple, sew or rivet the belt loop? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members TonyV Posted August 29 Members Report Posted August 29 Good job. Blue jeans don't need fancy. I did a similar belt build several years ago. But I found that I still wear the same old favorite belt day after day. It's broke in and stretched in all the right places. Quote
