Contributing Member Samalan Posted October 1, 2025 Contributing Member Report Posted October 1, 2025 9 hours ago, kgg said: I use good fashion contact cement. I don't think the brand name really matters much. What I have found that bests works for me and gives me the best holding is to apply one coat on the flesh (fuzzy) side of the pieces, let dry then add a second coat until dry (about 10 -15 minutes), mate the two pieces, use a roller to evenly press the pieces together, clamp or weight down the pieces and let sit for 12-24 hours. My theory is the first coat of contact cement sinks into the fibres and binds them together. The second coat holds both surfaces permanently together. I have found sometimes with only one coat of contact cement the two pieces can be pulled apart. kgg I do that as well, but one thing I do differently is that I keep two jars of contact cement, one of which is slightly thinner than the other. The thinner is for the first coat. I also work in a good tooth on the leather. The first coat must be dry; then apply the second coat. then I press and hammer together. The only contact cement I use is Bardge cement and thinner. I have never had a separation. Bardge contact is as strong as it gets. Quote
Members TomE Posted October 1, 2025 Members Report Posted October 1, 2025 (edited) I've been using a heat gun to "activate" contact cement - just a brief warming of the glued pieces before assembly. Bonds well with less cement so I have fewer problems with the glue interfering with burnishing edges. For some shaped pieces I case the leather lightly and shape the leather before applying the glue, and the heat gun treatment results in a better bond when the leather is damp. I'm using Barge cement but will probably switch to Weldwood in the future. Edited October 1, 2025 by TomE Quote
Members Thadrick Posted October 1, 2025 Author Members Report Posted October 1, 2025 OK? So are you guys popping the lid on wildwood glue each time you use it or are you transferring the glue to a different container and using a different type of applicator? I've been using barge quart cans with the applicator and a pair of channel lock pliers to get it open every time I need it. Is their a different more convenient method? Quote
Contributing Member Ferg Posted October 1, 2025 Contributing Member Report Posted October 1, 2025 I replace the lid after I finish gluing an item. I also tap the lid around the edges with a mallet. Used to do a lot of plastic laminate work. Bought the contact cement in five gallon buckets. Also: I used latex contact cement on laminate, only use solvent based on leather. Quote
CFM chuck123wapati Posted October 1, 2025 CFM Report Posted October 1, 2025 yea, i have a smaller glass weldwood bottle with a brush that I transfer to. You can also replenish the acetone as needed if it starts drying up. i usually put a bit in the can after opening it or transferring. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members TomE Posted October 1, 2025 Members Report Posted October 1, 2025 I refill a Barge quart can from a gallon can, adding Barge thinner as needed. Made a funnel from a 16 oz plastic bottle. What is everyone's favorite glue pot? Quote
Contributing Member fredk Posted October 1, 2025 Contributing Member Report Posted October 1, 2025 I use a contact adhesive all the time For small areas or seams I use a tube glue called UHU. For larger areas I use a brand none of youse would have heard of. I work straight from the 1 litre tin. Sometimes I pour in a wee bit of Evostick adhesive cleaner which acts as a thinner too and it stops the glue going 'off' I rarely wait for the glue to go tacky. One generous coat of glue on one of the item parts then I stick the items together and clamp up. After a couple of hours I remove the clamps and tap down with a small rubber-head mallet Never had a problem doing it this way and 99.9999% of the time I get a good glue bond Quote Al speling misteaks aer all mi own werk..
Members dikman Posted October 1, 2025 Members Report Posted October 1, 2025 I suspect most (if not all) solvent contact cements are pretty much the same formulation. I have started adding a bit of Xylene to mine occasionally if it starts thickening in the can, seems to work ok. I'm currently using Sika brand but I have a can of Selley's for when that runs out. I was going to pour it into a smaller container but haven't bothered, instead I glued one of those cheap "acid brushes" into the lid to use as an applicator, it's working ok so far. The down side to the Sika is it has a screw cap and a couple of times it got stuck! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Contributing Member fredk Posted October 1, 2025 Contributing Member Report Posted October 1, 2025 25 minutes ago, dikman said: . . . The down side to the Sika is it has a screw cap and a couple of times it got stuck! Wipe some vaseline on the screw threads, a fairly heavy coat. That'll stop the cap sticking Quote Al speling misteaks aer all mi own werk..
Members dikman Posted October 2, 2025 Members Report Posted October 2, 2025 Ta, I'll give it a try. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
