Members Handstitched Posted October 18, 2025 Members Report Posted October 18, 2025 If my contact cement goes a bit gluggy in the tin, I thin it out with some toluene , leave it over night, and it's back to normal. Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
CdK Posted October 18, 2025 Report Posted October 18, 2025 On 10/1/2025 at 9:05 AM, Thadrick said: OK? So are you guys popping the lid on wildwood glue each time you use it or are you transferring the glue to a different container and using a different type of applicator? I've been using barge quart cans with the applicator and a pair of channel lock pliers to get it open every time I need it. Is their a different more convenient method? On screw top glue containers it is useful to smear a light coat of Vaseline on the threads, this prevents needing to use a tool to unscrew. Quote Leather work machines I own: Thor 1341, Thor 441, LSZ-1 clone, 801 bell skiver, Tinker's Delight Shoe Patcher. (Tippmann Boss was re-homed.)
CdK Posted October 18, 2025 Report Posted October 18, 2025 On 10/1/2025 at 6:47 AM, TomE said: I've been using a heat gun to "activate" contact cement - just a brief warming of the glued pieces before assembly. Bonds well with less cement so I have fewer problems with the glue interfering with burnishing edges. For some shaped pieces I case the leather lightly and shape the leather before applying the glue, and the heat gun treatment results in a better bond when the leather is damp. I'm using Barge cement but will probably switch to Weldwood in the future. Cobblers often use a heater prior to placing the pieces together, this activates the contact adhesive to create a good bond. I use a heat gun to activate the dried contact adhesive when laminating vegtan for belts and holsters, similar to what TomE does. The edges are easier to finish as there is less of a visible line where the laminate comes together. YMMV Quote Leather work machines I own: Thor 1341, Thor 441, LSZ-1 clone, 801 bell skiver, Tinker's Delight Shoe Patcher. (Tippmann Boss was re-homed.)
Members sheida bkh Posted October 19, 2025 Members Report Posted October 19, 2025 Hi I’ve had good luck using a contact-cement style product (Weldwood or Barge) for heavy cowhide work, especially when I’m prepping pieces that won’t be sewn immediately. I apply a thin coat to both flesh sides, let it sit until tacky but not sticky (about 10-15 min), then press with a roller and clamp for 12-24 hours. If anyone’s interested, you can see my works in my website here : https://paeezleather.com Quote Shoes and Bag designer in Paeez Leather
Members Ole South Posted November 21, 2025 Members Report Posted November 21, 2025 For leather work After using all mentioned so far, my choice for heavy duty leather projects I'd rank contact cements as follows: 1. Masters or Petronio Shoe Master All Purpose Contact Cement 2. Barge 3. Weldwood 4. Tandy low odor, water based cements. #1 is the ONLY cement(s) I'd use for cobbler work. I've not had good luck with Weldwood from Hardware/Big Box Stores. It's okay for temp tacking but not for extended use... maybe I got a (couple) bad batches and it's fine for most everything else but never again for leather work. That being said, the Barge/Weldwood I've gotten from my suppliers has different labeling and did work pretty well. Quote
Members BlackDragon Posted November 22, 2025 Members Report Posted November 22, 2025 On 10/1/2025 at 6:43 PM, dikman said: .The down side to the Sika is it has a screw cap and a couple of times it got stuck! This is why I keep a pair of channel lock pliers on my bench. Quote
