Members Chakotay Posted October 26 Members Report Posted October 26 I tried my hand at a new skill: sand casting my own conchos. I would say the process was a tad more difficult to learn than I expected. However, after a couple of lightbulb moments (a few actually), I was able to churn them out pretty successfully. These are cast in tin, which is easy to melt and work with. I plan on making them in silver eventually. Quote
Members DieselTech Posted October 26 Members Report Posted October 26 Nice work. They look great. Quote
Members dikman Posted October 26 Members Report Posted October 26 I follow your you-tube channel so watched it the other day and I was impressed at the fine detail you got, not easy with sand-casting. For tin-casting you might be able to get away with making the mold from silicon, it would allow for repeat casting and give very fine detail. As an aside after watching your episode about the Vevor press I just had to buy one - I don't really need it (yet) but it's a solid bit of engineering!! Keep the vids coming, they're always good to watch. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Contributing Member fredk Posted October 26 Contributing Member Report Posted October 26 I do some casting. I use 'model metal' which is a tin alloy and also pewter, which is a lead and tin alloy. For multiple castings I use a heat-proof silicon rubber mould and for one-offs. or two, I did the casting in oil sand For making conchos I'd use the rubber mould. Its good for about 100 to 150 castings. Less if you allow the metal to get too hot. Quote Al speling misteaks aer all mi own werk..
Members dikman Posted October 27 Members Report Posted October 27 Just checked and the melting point of tin is considerably lower than lead so a silicone mold would be ideal for repeat castings. Won't work with silver though, temp is too high. I believe jewellers use plaster to make their molds but they would likely only be good for a couple of castings at most. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Contributing Member fredk Posted October 27 Contributing Member Report Posted October 27 When tin and antimony is added to lead to make pewter it lowers the melting point temperature. For this mix I use a special heat proof silicone rubber to make the mould. The heat proof rubber is meant to be used with pewter casting Plaster is usually mainly used for a single one-off casting as the heat of the metal cracks the mould and it breaks apart when removing the casting This is a medieval style belt end I sand cast, then hand painted; Quote Al speling misteaks aer all mi own werk..
Members dikman Posted October 27 Members Report Posted October 27 Nice job on the buckle fred. I used the silicone for casting lead jig heads for fishing, works well (you need platinum-cure silicone for this). Interestingly, I have some silicone molds I made for casting resin parts for Battlemechs and out of curiosity I tried pouring lead in them and it worked, even though the packaging said nothing about lead use. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
kgg Posted October 27 Report Posted October 27 On 10/26/2025 at 2:21 PM, Chakotay said: I tried my hand at a new skill: sand casting my own conchos. Very nicely done. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Bobs Brassware Posted November 19 Members Report Posted November 19 Nicely done! Sand casting can be a challenge at first, but you’ve got those conchos looking clean. Appreciate you sharing the process. Quote John – Bob’s Brassware Hand-cast solid brass hardware or leatherworkers Made in Kenya • Ships worldwide 🔗 bobsbrassware.com
