Members stampingdelight Posted 17 hours ago Members Report Posted 17 hours ago (edited) hello everyone, what is the best way everyone found when dyeing a large piece of leather. think is little over 1 foot and half to 2 feet? other item looking to dye would be 3 to 4 feet long once get made. has anyone dipped leather into the dye, if so what is best to use like a plastic bucket? Edited 17 hours ago by stampingdelight Quote
Contributing Member fredk Posted 17 hours ago Contributing Member Report Posted 17 hours ago When doing a long item I dip dye. I dilute the dye 1 : 1. I use any deep container that I had to hand. Then roll the item up in a coil and place it in the dye for a minute or so then a I see-saw it; an old technique for developing films; I bring the two ends of the item out of the dye then with each end in each hand I slowly dip one end in the dye and pull the other end further out, then that end gets dipped and the first end comes out. I do this for as long as necessary to get an even dye 1.5 ft by 2 ft; I wet the leather first, then use a 1 or 1.5 inch wide paint brush to apply the diluted dye, working from the center to the edges Quote Al speling misteaks aer all mi own werk..
kgg Posted 16 hours ago Report Posted 16 hours ago 1 hour ago, stampingdelight said: what is the best way everyone found when dyeing a large piece of leather. Airbrushing for both the dye and oiling. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
