SoMo; I make mocs regularly and I use a cylinder arm walking foot Singer 153 w 103 for most of the job. But the only machine that will sew the heel tab on is a patcher. It is only two runs of 1 1/2" and could be sewn by hand. If you are looking at new, I would recommend a Techsew 2700, which is a compound feed cyl. arm machine. If you want a used patcher, I have a 29 k 71 with about $400 spent replacing the revolving bushing, needle bar, bell crank and driving lever. I recently upgraded to an Adler 30-10 patcher with an electric motor. Gump in N.S.
  • 5 years later...
Bom dia, adquira uma máquina Singer 29K2 recentemente.
Alguem poderia por favor me informar qual seria o real ano de fabricação dela?
Qual seria sua cor original?
E onde eu poderia conseguir o manual de funcionamento?
Toda informação será muito bem vinda, pois não tenho conhecimento de máquina.
The best advice on buying any machine is to try it out, on what you need it for, many people are happy with 29K machines, and use them for a variety of purpose. they have been, and still are in production over 100 years, they can sew inside shoes and boots few other machines can handle. As with all machines some people have duff ones other think they are great only you  know the full story of how it works for you
Mi omputer is ot ood at speeling , it's not me
http://ismacs.net/singer_sewing_machine_company/serial-numbers/singer-sewing-machine-serial-number-database.html
In this link you will find the serial numbers/date chart for your machine, and the Original colour was japanned black with gold leaf acanthus decals. The class K models were made in Glasgow Scotland. If you go to the search box above and look for "Singer 29k Owners Manual" i am sure you will find one. If not let us know.
The Singer 29k2 was probably built sometime during the late 1890s through very early 1900s. Look up the serial number on ismacs, as linked to by Jimi.
The original body color is black.
Posted IMHO, by Wiz
22 hours ago, chrisash said:
O melhor conselho para a compra de qualquer máquina é experimentá-la, para o que você precisa, muitas pessoas ficam satisfeitas com as máquinas 29K e as usam para uma variedade de propósitos. eles estão, e ainda estão em produção há mais de 100 anos, podem costurar dentro de sapatos e botas que poucas outras máquinas conseguem suportar. Como em todas as máquinas, algumas pessoas têm duff, outras pensam que são ótimas, apenas você conhece a história completa de como ela funciona para você
Muito obrigado pelo retorno
Bom dia Jimi, encontrei minha máquina.
Ela é de 1920 foram feitas 15.000 unidades.
Muito obrigado pelo retorno, me ajudou MUITO.
Wizcrafts muito obrigado pelo retorno.
Agora poderei tentar deixar tudo original.
Tenham um ótimo dia.
