I think that I am using the right products but I think I may be using them in the wrong order.
Here are the steps I use after a holster has been assembled and burnished (burnished using only water).
1) dye and let dry for a few hours (Feibings non pro dye)
2) using a dry cloth wipe off excess dye.
3) Spray on Saddle Soap to clean off any dye that did not take...let dry
4) Dye again let dry over night
5) Lexol to moisturize
6) Resolene (if only the dye looks good)
It is in step 5 where I have been noticing dye coming off. Dye coming off to the point where I can seen bare leather showing through.
Any suggestions? I get the feeling that I am way out of whack here.
My sequence goes something like:
1 I use Lexol as I am tooling the leather.
2 Neatsfoot oil let stand over night
3 Dye only once let stand until dry
4 Wet leather and apply antiquing paste while wet.
5 Wipe off paste immediately. Dry overnight
6 Rub on NeatLac using cloth.
7 Aussie Cream or Leather Balm
Done
Dave Theobald
I'd recommend dying the leather before assembly, certainly before molding.
The molding/burnishing is probably inhibiting the dye from penetrating.
But oil after all molding is complete.
Back to the bench,
Paul
"When you finally get your wings, don't complain about the wind in your face."
Try Feiblings Pro Oil Dye in your sequence. It's all I use. Eveery time I stray from it, I am not satisfied with the results.
Bondo Bob
  • 5 months later...
Done
Dave Theobald
Dave,
can you explain how you use Lexol while tooling? do you use it in a casing solution? or just straight from the bottle?
i mix the casing solution that contains Lexol, but when i use it i have a little trouble getting an even dye job. (i air brush fiebing's pro oil dye) i wonder if i should be using a deglazer after tooling, but i worry if wetting again will dull the tooling impressions.
also, how do you apply neatsfoot oil? can that stuff be air brushed on?
thanks for any help,
ken
Bondo Bob
Thank you, Bondo Bob, . . . thought for a while I was alone
I have one exception to the above, . . . it is a special color I cannot (haven't figured it out yet, truthfully), . . . get using Pro Oil dyes. Other than that, . . . Pro is my only dye for all my projects.
May God bless,
Dwight
www.dwightsgunleather.com
