Members brianjaa Posted March 24, 2013 Members Report Posted March 24, 2013 I am new to leatherwork. I need to know how to punch holes through multiple layers of leather. I am using 8-10oz leather to make holsters. I have been using a drill with a tiny bit to make the holes through both layers so that the holes match up. I know this is not correct, but I have yet to find a good way to do this and ensure they line up. My holsters are turning out okay, but I want to do it right. Can someone let me know if they use their diamond awl to go through two layers at once? Can you let me know if there are different size diamond awls, and if so what size would you recommend. If you respond, pics would be great if possible. I really appreciate your time. I will attach a pic of a holster I did. Quote
electrathon Posted March 24, 2013 Report Posted March 24, 2013 There is likely no single question that will get more differant responces. What I do. I drill the holes with a very large sewing machine needle. Tandy sells them. Put the needle in the drill press and drill through with it (turn it on). The needle will push leather back but not remove leather like a drill bit will. Aaron Quote
Members brianjaa Posted March 24, 2013 Author Members Report Posted March 24, 2013 There is likely no single question that will get more differant responces. What I do. I drill the holes with a very large sewing machine needle. Tandy sells them. Put the needle in the drill press and drill through with it (turn it on). The needle will push leather back but not remove leather like a drill bit will. Aaron So you use a drill press but put a sewing needle in it? I thought about that but wasn't sure. Good advice I will try it. Thanks a bunch for your response. Quote
electrathon Posted March 24, 2013 Report Posted March 24, 2013 So you use a drill press but put a sewing needle in it? I thought about that but wasn't sure. Good advice I will try it. Thanks a bunch for your response. Exactly. The sewing needle is spun like a drill. Quote
Members Matt S Posted March 24, 2013 Members Report Posted March 24, 2013 Two layers of 8-10oz? Diamond awl. Sharpen and polish until you think you're done, then do it some more. Use the smallest size you can get away with; the smallest 1-1/2" size does for most jobs like this. Quote
Members PutnamLeather Posted March 25, 2013 Members Report Posted March 25, 2013 I like to think of it as creative stiching, as long as it gets the job done and looks good its the rite way to do it. Quote
Members thekid77 Posted March 25, 2013 Members Report Posted March 25, 2013 Brian, see Nigel Armitage's video at the link below: This is a great video tutorial about how to make holes through multiple layers of leather. Nigel is a true master of the art Quote
Members Dwight Posted March 26, 2013 Members Report Posted March 26, 2013 Brian, . . . one thing which will help you out immenseley, . . . glue your pieces together before you try to sew them. You can use Weldwood contact cement (my preferred product), Tandy's contact cement, Elmer's wood glue, or a host of other products: just figure out which one you want to use. You can then dress your edges, . . . which gives you a good starting point for your stitch gouge to roll against, . . . and will make your product look SOOOOO much better. Once you have done that, . . . Electrathon has a good idea, . . . personally I hate hand sewing, . . . use a machine any time I can, . . . but when forced to do so, . . . I do my stitch gouge line, . . . run my stitch wheel, . . . get out the awl, . . . whet her up real sharp (my awl is a pointy headed little blonde female awl), . . . and go at it. Now, . . . if you are real persnickity about how it looks, . . . put a plastic cutting board under your project, . . . that will let the awl just peek through the bottom layer. You can then run the awl back through the other way, . . . and the back side will look "very pretty" also. I only do that on projects that have to be "so so" and it is not that often. But that is one way to do it. Good luck, . . . and remember, . . . practice makes perfect. You have completed a project, . . . that means you have scrap laying around. Sew that scrap together, . . . giving you practice. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members camano ridge Posted March 26, 2013 Members Report Posted March 26, 2013 I combine the above methods I also do holsters as well as some hefty sheaths with welts. I glue everything that is to be sewn and dress my edges then run my stitching grove, mark my stitch line. When I am ready to make my stitching wholes i have a very sharp diamond awl blade chucked into a drill press that is not pluged in. I crank the drill down and poke the awl through the mark for my stitch with very little effort and does not take anymore time then pushing an awl through by hand or drilling the whole. It gives a good clean awl hole. when all holes have been punched sitch away. Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
Members brianjaa Posted March 26, 2013 Author Members Report Posted March 26, 2013 Brian, . . . one thing which will help you out immenseley, . . . glue your pieces together before you try to sew them. You can use Weldwood contact cement (my preferred product), Tandy's contact cement, Elmer's wood glue, or a host of other products: just figure out which one you want to use. You can then dress your edges, . . . which gives you a good starting point for your stitch gouge to roll against, . . . and will make your product look SOOOOO much better. Once you have done that, . . . Electrathon has a good idea, . . . personally I hate hand sewing, . . . use a machine any time I can, . . . but when forced to do so, . . . I do my stitch gouge line, . . . run my stitch wheel, . . . get out the awl, . . . whet her up real sharp (my awl is a pointy headed little blonde female awl), . . . and go at it. Now, . . . if you are real persnickity about how it looks, . . . put a plastic cutting board under your project, . . . that will let the awl just peek through the bottom layer. You can then run the awl back through the other way, . . . and the back side will look "very pretty" also. I only do that on projects that have to be "so so" and it is not that often. But that is one way to do it. Good luck, . . . and remember, . . . practice makes perfect. You have completed a project, . . . that means you have scrap laying around. Sew that scrap together, . . . giving you practice. May God bless, Dwight Hey Dwight, Man, thanks for the information. This may be a stupid question, but what do you mean by "dress your edges?" Quote
