One thing to remember is that if after wiring a 380V motor to run on 220V it runs at lower RPMs, then it could overheat from the lack of air circulation.
Edited by DrmCa
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Nah....A.C. motors run at an rpm which is determined by the line frequency, not the voltage. More specifically at the line frequency minus the motor's "slip". Now it is possible that the slip is different between running at 380V or 220V, but this would be a minimal difference as slip is usually less than 10%.
Tony V
Rifle River Leather
Ogemaw Knifeworks
There are two individuals inside every artisan...the poet and the craftsman.
One is born a poet. One becomes a craftsman.
Depends on the voltage drop. I would not write the above if I did not witness it with my own eyes.
Again, an A.C. motors r.p.m is determined by frequency, not voltage. I would not have written the above had I not been an automation engineer and taught electrical engineering for 32 years. If you witnessed that a motor had slowed down under the OP's posted conditions, then it was loaded. However, this would increase the motors slip which then increases the back EMF to the windings which increases the torque which brings the motor back up to speed. However, if the motor is overloaded it cannot recover. This may describe the situation you'd witnessed.
Tony V
Rifle River Leather
Ogemaw Knifeworks
If I had a 3-phase motor I wouldn't mess around with rewiring it I'd buy one of those magic boxes that lets you run a 3-phase on single phase and also acts as a speed controller. Perfect solution, in my opinion.
Edited by dikman
I had the same thought when I bought a 3-phase splitter. Turns out those magic boxes release the magic smoke if any switchgear between the motor and the controller changes state while it's running. They also need to be tuned to the load and aren't really recommended for running multiple motors. My machine has 4 motors, all different RPMs and power requirements. I left the electrogubbins in the control cabinet alone and just built a static converter.
