Make absolutely sure to cut off the starting thread that protrudes from the outside hole in the bobbin, as close as humanly possible to the metal. A short thread stub can catch in the beehive ejection spring that lives inside the bobbin case.
Open the bobbin case, eject the bobbin and blow out any foreign material or thread particles. Loosen the bobbin spring screw and remove it. Feel the spring to see if it has sharp edges. If it does, use Emory cloth to buff it smooth. Blow out any thread particles that may be caught in the slot under the bobbin spring. Reassemble the spring and adjust it for a smooth pull that is not very tight, nor jumpy. Pull out a few feet of bobbin thread to adjust the spring for the smoothest pull with a modicum of tension.
Re-check the top thread path. Better yet, unthread the top thread and start over.
  1. Pull the thread up off the thread cone, making sure that it doesn't loop around previous windings. Be certain to keep the thread from getting under the spool.
  2. Feed the thread through a thread guide in the overhead stand arm. Keep the top thread guide arm inline with the spools on the round platforms.
  3. Feed through a hole in the top post on the machine. If the thread is black and very coli-springish, wrap it around the post and feed it out through a lower hole. Otherwise, one hole will do fine.
  4. Feed through the lube pot, making sure the thread doesn't hang on the sometimes tiny holes. Disregard if you don't have a lube pot. I enlarged the holes on my lube pot to reduce thread drag.
  5. Feed the thread through the twisted steel loop on the lube pot. Disregard if no pot.
  6. Feed the thread through the small steel guide in front of the top tension disks.
  7. Pull the thread up, then through the disks until you hear it snap into place near the center post.
  8. Feed the thread down through the guide over the bottom disks, then pull it to the left of the disks.
  9. Wrap around the disks two turns, then feed it up through the same steel guide.
  10. Going down, then up through the steel guide over the bottom disks helps keep the thread inside disks, rather than outside them, which causes thread jams on top and otherwise properly placed bobbin thread on top of the work.
  11. Go through the check spring thread hole (make sure that spring doesn't bind again).
  12. Go up and through the take-up lever, from back to front.
  13. Go down and through a spring loaded guide on the faceplate.
  14. Continue down, going through the lower steel guide.
  15. Feed the thread through the little hole on top of the needle mounting bracket on the needle bar.
  16. Thread the eye, from left to right.
  17. Run some test strips, adjusting the top tensions as you sew. If you cannot stop the bobbin thread from showing on top, tighten the bobbin tension spring screw a little at a time, until the knots are balanced.
You don't normally need a huge amount of tension on top and bottom to get well placed knots and good stitches. You only want to have as much tension as is needed to place the knots inside the material and have the stitches flat against the top and bottom. If you have to bury the stitches to prevent abrasion damage, use a groover tool to gouge a sewing channel on top and bottom. Your stitches will then be recessed.
Always raise the presser feet before removing the work. With the foot lifter fully engaged, the threads should pull quite freely on top and smoothly on the bottom. Twist the thread to the left between your thumb and fore or middle finger and snip them close to the leather with a Tailor's thread snipper. I prefer a curved chrome plated thread snip (Bob Kovar sells them).
Next, use a straight blade screwdriver to finger-tighten the two screws that hold the shuttle cover to the end of the body. Then back them off 1/2 turn each. This gives some added clearance for the bobbin case to move laterally when heavy top tread passes around it. If those screws are all the way in the top thread might jam against the bobbin, bobbin case, or the shuttle itself. This doesn't usually apply to thin thread, like #138.
I hope this helps.
Edited by Wizcrafts
Posted IMHO, by Wiz
  • Replies 33
  • Created
  • Last Reply
Top Posters In This Topic
Thanks Wizcraft! We did everything above. took apart and cleaned bobbin as well.
we did a test, and the first 2" did good and then the bobbin caught and pulled again. Something has to be wrong with the way the thread is being loaded ON the bobbin to begin with before it goes in the shuttle.
Question 1: when winding the thread on the bobbin, is your tension set at pretty loose or pretty tight...?
Question 2: when the trhead winds on the bobbin, it looks nice and neat and layered at one end and then the other ends looks a bit messy. This has caused the bobbin to catch sometimes. What is wrong with the threader?
Question 3: when the threaded bobbin is put into the shuttle, is your thread going over the top of the bobbin from L to R or is it going under the bobbin from L to R.
We don't understand why this all of a sudden started messing up after using the machine successfully for the past few weeks. The only thing was i switched out my bobbin thread (for the same size) to continue stitching a strap after the first bobbin ran out and then it started messing up and having the loops on the top.
It just doesn't make sense and we are so frustrated at trying to fix this thing right now.
Answers:
  1. Not too loose and not too tight. Enough to get good close windings that lie next to each other.
  2. Your movable thread guide (mounted on the front-left side of the machine) is too far toward or away from the head. Loosen the screw on the back of the guide. Push or pull on it until the bobbin loads equally, side to side. Then lock down the screw.
  3. I usually insert the bobbins so they pull counter-clockwise. This is the same as the thread feeds over the top, then through the angled slot. However, some threads just tend to get hung up going through the slot and I will reverse the bobbin so it feeds clockwise (under the bobbin windings). When doing it this way one has to rely upon the anti-backlash effect of the beehive shaped spring inside the bobbin case. Left unchecked, the bobbin tends to loosen when rotating clockwise, vs ccw.
Posted IMHO, by Wiz
Wiz,he has a 3200 w/a table mounted bobbin winder.
So you can move the tension unit to the side it isn't going.So if it winds more on the right move the tension unit on the bobbin winder to the left.This will help to even it out.
You might want to look underneath the tension spring on the shuttle for thread or lint ,clean it out & reinstall the spring & you need to tightin it until you get some tension,then get some scrap & sew a test piece & adjust as needed.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
How full is your bobbin when fully wound? It should only be about 90% full. On my new Toro 3200, I had to adjust the winder kick-out as my bobbins were overfull and binding in the bobbin case. If you look at a full bobbin from the end and can see thread above the rim of the bobbin, there is to much thread on the bobbin. Gump.
Sucess!! :thumbsup:
Thanks you guys for the help!! It was pilot error! When taking out the bobbin we didnt realize there was a spring iside! It dropped out! :oops: Bob from Toledo sewing machines was great and sent us a new spring! :You_Rock_Emoticon: The machine is great and highly recommend The Cowboy series of sewing machines!
With all the help from the members we have learned our way around the fine art of sewing of machines! We need lots more practice but, Practice makes perfect!
Thanks again! You guys saved a lot of frustration! Looking forward to sharing our ware's in the future.
Dave and Jackie Pressley
DJP Handmade
P.S.
Also adjusted the bobbin winder. It winds much more even. :cowboy:
That's Great News !! :banana: :banana: :banana: :banana:
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Congrats Viking on working out your issues. I have been reading along and now that one disaster is avoided I need some help too. I am going to attach a few pictures I hope!!! Here is my issue when sewing on some of the thicker portions of a holster my bottom thread seems to be very tight almost pulled into the leather, it does not look like the top. What tension should I adjust to even this out. I am a rookie on the 3200 and not sure if this is thread or bobbin tension issues. It may if fact be something totally different. I look forward to the replies. The first pic is top and the second is bottom.
post-36708-0-14937200-1409345960_thumb.jpost-36708-0-45864400-1409345967_thumb.j
csmartin73; Your bottom thread is supposed to pull up into the leather and leave the knot in the middle of your piece. It looks like your needle is to large for your thread or the wrong cutting point. With some points the thread is not able to fill the holes. Look up some needle point charts from Groz Beckert or Schmetz and they will show you the effect different cutting points will have on stitch appearance. These charts will explain it better than I can. Gump
Back off your top tension slightly.
