Need A Holster Pattern For A S&w Model 59 Its Like A Standard Size For A S&w 9Mm / 45 Cal / Glock
I was wondering if anybody can help with a pattern or point me in a direction..
need a holster pattern for a S&W model 59 its like a standard size for a S&W 9mm / 45 cal / Glock
Thanks
Lew
I'd love to help but, though I am an avid supporter of 2nd amendment rights, our special needs son who has the savant capabilities of Houdini when it comes to getting into things has assured that we just don't keep guns in the house...I wouldn't know how to begin drawing up a pattern for you.
Darn it!..now I want to start researching holsters and make all kinds of holster patterns. Everything else is on hold now Big Lew! Dozens of people will now be denied timely pattern uploads because I'm gonna be focused on holsters!
LOL.... you just need to quit your job and make patterns full time... you are already popular.....
everyone holsters ;-)
Once I moved about like the wind, but now I surrender.(Geronimo)
Failure is always an option
Holster patterns, please, please, please.
Crooked Finger Leather
5514 E. Hwy 40
Greenfield, IN 46140
(317) 947-8046
Really? Nobody? Googlizin' says that's a 4" barrel, so this won't fit. Still, seems like SOMEbody should make a quick rig and show us a picture of the fit :)
Edited by JLSleather
5 leather patterns
  On 11/15/2014 at 3:35 PM, camano ridge said:
Big Lew, what style are you looking for pancake, avenger, shoulder ect.
+1
The key to immortality is first living a life worth remembering.
Bruce Lee
Umm, order a Blue Gun and make the pattern yourself?
Keep on Chooglin'
Check out my YouTube Channel, comment and subscribe for updates
https://www.youtube.com/channel/UCOM3hbruUKHov9kquIxXKlA
pancake or avenger
thanks
Lew
Thanks....... I would but I don't make gun holsters... just want to make one for my gun
I use construction paper when making a pattern.
making sure to take into consideration the thickness of the leather and stapling along the stitch line.
Sometimes I'll cut away bits of paper, sometimes I'll tape bits of paper back on and sometimes I'll throw it all away and start all over.
Once I'm happy with how it looks, I'll start cutting leather.
I'll use Blue Guns when I don't have access to the actual firearm. But if I have access to the actual firearm, I'll go ahead and use that.
Edited by snubbyfan
Keep on Chooglin'
Thank you... I think I will try that. Yours look like they came out great....
thanks
Lew
Lookin' forward to seein' what ya come up with.
Keep on Chooglin'
attachicon.gif1911_whp.pdf
Anybody put ona those together? I added 1/4" to the safety strap (left side of pattern) and moved the snap up that same 1/4". In actual practice, I never mark the female end on the pattern -- but instead I put the male end (and reinf metal if used), assemble the holster, then press the strap on the male end to mark the position of the female snap. Avoids any issues that could have resulted from different leather thicknesses.
5 leather patterns
Biglew, like Snubby, I also use paper. One thing to remember, paper does not stretch or shrink like leather do. If you like details and good retention, I would go with a front and back type holster (pancake style). You get great definition and good to great retention without having to add a thumb break. This is what I do for my patterns:
1. Get a piece of cardstock type paper to do your prototype pattern. Construction paper works, but you have to find a piece that will be big enough. I use grocery store paper bags, they are hard enough to start with plus they are usually free when you go to the store. (I use those bags for targets too, cut it in the right place, you get a torso target)
2. Trace the gun as close as you can. Make sure you cover all aspects of the firearm (trigger guard, trigger, grip, hammer, sights.......)
3. Measure the thickness of the gun along the stitch line.
4. Divide those measurements in half.
5. Add the thickness of the leather (e.g. for 1911s they are usually 1.25 or 1 1/4 in at the slide divide that in 1/2 and you get .625 or 5/8 in. If you are using 8 oz leather, then add .125 or 1/8 in to the .625 or 5/8. 5/8 + 1/8 = 3/4; .625 + .125 = .750)
6. That results will become your stitch line.
7. Trace the results from step 6 along the gun trace (I usually mark those with hashed lines)
8. Mark the outline of your envisioned holster on that paper and there you have it, your own pattern. Make sure you take in consideration the belt loops, and seam allowance. Belt loops are usually 5/16 wide by 1.5 in long.
9. Once I am satisfied with the pattern, I transfer to a heavier cardstock so I can use it many times.
My patterns are tight so I can get good retention without the use of a thumb snap. That means that when wet molding, I stretch the leather some.
Ray
U.S. Army Retired
A veteran is someone who, at one point in his life, wrote a blank check made payable to 'My Country' for an amount of "up to and including my life." That is Honor, and there are way too many people in this country who no longer understand it.
Good advice from Splash, I usually just kinda "eyeball" my patterns.
I lucked into a free ream of construction paper. If I need larger than a sheet a little masking tape helps.
My own personal holster has friction retention. No need for a thumb break.
Keep on Chooglin'
snobby, splash..... thank you both for your advice.... no w i need to get off my buttt
One thing I forgot is that on the first holster I make from that finished template, I make it from low quality/cheap leather. I do that so I dont waste some good HO or W&C leathers in the case that the pattern needs adjusments.
Ray
U.S. Army Retired
