for me it's certainly lead.To make some holes for rivets or anything like ,there is no risk of contamination .
time does not respect what is done without it
https://tradisign.blogspot.com
https://www.instagram.com/tradisign/
1/3rd of the gravestone I use for a granite tooling slab is covered with a thick piece of scrap veg-tan 12-14 oz. Contact cement REALLY holds when applied correctly.
I think of Chinese food when I think of life;
That's sweet and sour.
My life is sweet as saccharin.
Ye Scurvy Dog.   Swords, Weapons, Dungeon Furniture, Custom Leather Work, and More...
  • 1 year later...
anyone know of a cheap solution you can buy at your local walmart/homedepot/ hobylobby preferably under 10$
Expand
IF you have a solid backing underneath it . . . the white cutting boards sold in housewares are good.
AND they are cheap.  They will get marked up a bit after several month's use . . . simply flip em over and use the other side.
They're also cheap to replace.
Lay it on a piece of marble or granite . . . and whack away.
May God bless,
Dwight
Edited by Dwight
www.dwightsgunleather.com
  • CFM
Expand
about a six inch end piece of a log or a 4x4 . for free at a construction site of lumber yard
I have a nice big crystal cutting mat that I use for most things but for punching holes (or anything that would wear out the mat) I use a block of lead. If I didn't have the lead, I would take four short lengths of 4x4 and screw them together into a nice solid cube and use that.
  On 5/4/2015 at 10:58 AM, Geneva said:
I use a piece of HDPP, 1" thick high density polypropalene, in red. I have had it for about 5 or 6 years works great.
Expand
Perfect.
Expand
Probably not but it still isn't any better than a cheap cutting board.
One consequence of the theft of roofing lead has been the development on non-toxic self-healing alternatives, which aren't as heavy, which might not be a good thing. It's the selfhealing aspect which intrigues me: has anyone tried any of those?
