Members natenaaron Posted September 8, 2015 Members Report Posted September 8, 2015 I've been looking and not finding the answer. Is it just scrap from a side that you folks toss in the bin? Quote
Members Tugadude Posted September 8, 2015 Members Report Posted September 8, 2015 in my experience belly leather is good for small pieces for the most part. Some problems with it include irregular thickness and strange grain patterns that cause the leather to wrinkle and worse. But if you own a splitter you can get a consistent thickness at least. I made several dice cups out of veg tan belly from Tandy. Turned out nice. Straps and bands are also doable. Coasters, key fobs and the like are all small and can be cut from belly. Quote
Members natenaaron Posted September 9, 2015 Author Members Report Posted September 9, 2015 Thanks for the answer I appreciate it. Quote
Members DoubleC Posted September 9, 2015 Members Report Posted September 9, 2015 I make my belts and dog collars, etc out of the belly which they put a straight edge on. Makes using a strap cutter easier. I use the ones from Springfield Leather Company and haven't had a problem with stretching etc. using the firm parts. Cheryl Quote http://www.etsy.com/shop/DoubleCCowgirl
Contributing Member JLSleather Posted September 11, 2015 Contributing Member Report Posted September 11, 2015 I generally buy backs... sides with the belly already removed. Sure it has a purpose though. Hmmm.... Put it inside the shop door, place to wipe yer feet when you come in out the rain. Use it to cover the bench, in case you spill some dye. Makes small but good smelling curtains. Wickett / Craig will sell you the bellies for about $15 if I remember rightly. Even at that price, I dont buy 'em. http://www.wickett-craig.com/ Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members thunter9 Posted December 6, 2015 Members Report Posted December 6, 2015 there was a time when i couldn't get enough of this . i was building custom wrist and leg and ankle gauntletts . if you want to mold extreme amounts this is what you'll find you need. your able to work it into the tight areas . and not show any wrinkles. Quote
Members OLDNSLOW Posted December 13, 2015 Members Report Posted December 13, 2015 now I am a noob to all of this, but after reading a lot here I thought I could use some for mock ups before jumping in and doing the real thing to make sure my pattern was ok, glued it up threw a few stitches in it adjusted where need be then used it as the actual pattern, save a tree and use the belly. Quote
Members cgleathercraft Posted December 14, 2015 Members Report Posted December 14, 2015 I woulnd't use them for anything that would stretch and cause problems with the product. I'd limit it to small projects. Knife sheaths, Coasters, bracelets/cuffs, practice pieces (for swivel knife practice). I try to get the most out of every piece. Quote http://www.cgleathercraft.com Member of the Iron Brigade.
Members jroberts3001 Posted December 19, 2015 Members Report Posted December 19, 2015 I've used bellies for some decorative pieces before. I usually don't fool with them Quote
Members Troy Burch Posted December 19, 2015 Members Report Posted December 19, 2015 (edited) I use them for backing on alot of my belts. The cowboys around here think it's cool to have the tick bites, scars and brand marks on them, of course I use grade B HO backs for the tooling side. Edited December 19, 2015 by Troy Burch Quote
