Hello guys and gals. Im sorry to beat this topic like the dead horse that it is in the sewing machine world. Ive read some very good information in this sub and appreciate the expertise. The only problem I seem to have is that most suggestions for machines are well over a thousand dollars. As a newer hobbiest just starting to get his feet wet into selling items I would like to know if there are suitable machines that can withstand the rigors of sewing leather on a small volume scale for the interim before I know that sewing is for me, and that a few thousand dollars seem more like a wise investment than a risk.
I started looking into vintage singers and even then find it difficult to wade through all of the models over the years. My main materials would just be sewing a thin lining on 9-10oz leather. Would something like a Singer 251-2, juki ddl555-5, or a Singer 121h be viable options? are there any recommended machines that can be had within the $200-500 range? Id have no problem selling the machine off when im comfortable and ready to upgrade. Thank you for your input in advance.
Edited by JerseyFirefighter
Rob
www.ridgewayleatherworks.com
IG: @Ridgewayleatherworks
FB: RidgewayLeatherworks
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Look around for a Singer 111, or a Consew 225/226. These machines are tanks and can sew up to 3/8" with 138 thread. You may find other copies of these machines at reasonable prices, but be sure to look for a triple feed, walking foot machine.
Agree with Gump - the machines should have walking foot / compound feed.
I copied my answer from an other thread:
If you are looking for a used flat bed machine check for Adler (or Chandler) 67 / 167, Singer 111w155 / 111w156, Singer 211 (don´t know all the sub classes), Pfaff 145 / 545, Juki 562 / 563, Consew 226, Consew 206 just to mention some of the most common models. Some older machines may not have a reveres function.
if you are unsure check with one of the dealers who have banners on top of this site. Most have new and used machines. They may cost more but you are buying serviced machines and you have support from the dealer.
I think www.Keysew.com is too not far away from you
Thank you both. I will look into those models and vendors. I guess truth be told since they really dont lose much value, when im ready to step up to the big boy table I can offset the cost with selling whichever one I pick up.
Rob
If you look long and hard enough, used machines pop up that are in the 400-500$ range. However, New machines capable of doing any real leather work are going to be well over $1000
I was expecting for it to be a used machine for the reason you stated above. Just something to push me down that road before making a substantial financial committment as a hobbyist.
Rob
Used leather machines don't pop up often, so finding a good deal on a used machine is tough. I looked for almost a year, but I finaly found a good used Consew 206 for $400. Then I spent ~250$ on a servo motor, new needles, thead, and a few mecanical issues. At the time, that machine was 1300 new. Before that, I tried to make an old Singer cast iron machine work, and it just wouldn't do what i needed it to do. Luckily, I cleaned it up real well and sold it to a lady who wanted to use it as a decoration in her house.
Best of luck with your search.
Edited by Colt W Knight
If you buy a real walking foot machine, it will sew up to between 5/16 and 3/8 inch of material, with #138 thread. Most modern walking foot machines yield up to 4 stitches per inch and some go even longer. This means you could buy some Kevlar thread and repair small tears in your work suit. They are invaluable machines for hemming denim pants, sewing patches onto vests, installing zippers, sewing linings to belts and cases, or assembling wallets or sewing banners and tarps along the edges. Triple feed makes the stitch length consistent, even on very long projects.
Note: very old model walking foot machines usually lack reverse and often have strange ways of setting the stitch length, and no protection of the shuttle system if the thread gets jammed inside the bobbin case and shaft. Modern machines will have a stitch length rotary dial, a palm operated reverse lever and a clutch that disengages the shuttle drive in the event of a thread jam. Most also have a much larger bobbin than any of the old machines (Consew type M or Juki LU).
Posted IMHO, by Wiz
Jersey, permit me to offer my (admittedly limited) experiences with industrial leather sewing machines. I was given a Singer post machine (a straight stitcher), which I had high hopes for, but through much experimenting and lots of reading of the great advice on this forum, I eventually realised that for sewing leather a walking foot machine (preferably a compound feed) is the only thing worth considering. You will be struggling with anything else.
That first Singer is a great machine, for what it's designed for, and I'm sure it will be very useful, but I broke quite a few needles before I figured out that it doesn't like thick/stiff leather! So I just kept looking for a suitable used machine, and whenever I saw one I looked up the model details on the 'net to find out what it was, and it's amazing how each time there were links to this forum! Shows what a great resource it is. I'm slowly learning which models are which, and which ones are worth having.
Thank you gentlemen for your input. I guess this was the kick in the rear I was looking for to sit back and take stock of what direction I really should be heading. I probably should refirect my train of thought to "buy once, cry once" then fumbling about with learning to sew on a machine that cant handle the job I would like to use it for. It seems I'll put a little more time and a fair amount more money towards the machine budget.
Rob
