William,
Well, the factory part explains removing the button that changes stitch length. My guess is it still can be accomplished via a dowel or pencil. It will sew 3/8 but not much more, period. I did 22oz with one ONCE, could barely get it under the presser. Broke a needle along the way (my fault), so I would say 3/8 is the functional limit.
Art
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Thank you all.
Going to check it out, see if all parts are with it, and if she will move on the price.
Thank you, William.
If its a consew 226 copy, I think 400 is a steal. best of luck.
Got it and 6-7 extra large to me cones of thread and hundreds of bobbins of black and white thread. Has an adjustable stand and a 1/2 horse power 120v clutch motor,with knee lift for 300$ everything we could stuff under the foot it would sew good looking stitches. I"m going to have to look into adjusting the stitch length, I checked under the table and everything looks to be there, ill have to get a diagram to be sure. Have it covered in the truck to heavy to move it in the dark.
Thanks, William
I think the stitch length indicator on this version of the 226 is right next to the hand wheel like shown in the photo of a pristine 226 below. The older style 226 had the indicator wheel inside under the top cover (also visible by peeking through the hole in the front). The missing button normally just engages a notch in a disk on the underside to keep a shaft from rotating as you turn the hand wheel to adjust the stitch length. You can stick a screwdriver or something else suitable into hole to engage that notch.
Uwe (pronounced "OOH-vuh" )
Links: Videos
Started cleaning it up yesterday, but the sun popped out and I bush hogged some instead. I'm going to get some sewing machine oil and oil it up good maybe tomorrow. Seems the darkness in the woman's basement wasn't the only reason I had thought it was green. Her husband must have been a heavy smoker, and it took a while to clean it up but it is a nice shade of industrial grey. Going to have to change the needle and bobbin thread as I keep jamming on the bobbin side and I read some threads last night and this seems to be pointing in this direction. I have also done some searching on speed reducers and servo motors and I have some questions.
1) Servo motor, I gather its quiet till you hit the pedal,
2) Would it also need a speed reducer? I would rather have say 0-800 spm. I'm just starting the industrial sewing and this thing is fast I'm guessing 4 or 5 times too fast.
3) Clutch motor, noisy all the time. I looked at some videos and I'm not sure of the reduction but it still looks too fast.
After i finish cleaning some more and get it oiled up and sewing a good stitch, ill post another picture. Thanks for all the help!
William.
The "servo" motors I use don't run at all until you step on the pedal....its hard to be more silent than that! Mine just make the merest whisper when running as well. I use speed reducers *with* the servos on my upholstery class machines - Juki LU-563's, a Consew 206RB5 & a Mitsubishi CU-865) ...and your 226 is of the same type/class. For me, its more to multiply the torque a bit when going very slow through multiple layers of folded webbing and Cordura. I have a couple of "fabric" machines that do fine with the servo alone. I've tried reducers on a couple of random clutch motors that actually seemed well-behaved and controllable, and I'm quite sure with practice they would have served me well....but there is no getting around the noise most of them make. I'm a maintenance machinist for a medium-sized factory, and I get enough background cacophony during the day to make me appreciate stillness. Enjoy your 226!
-DC
Edited by SARK9
Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562,  Mitsubishi LS2-180,  Seiko SK-6, Juki LG-158-1
I've been messing around with speed reducers (pulley system) and they do help, but a servo is far better, in my opinion, when it comes to control. I've just fitted one to my Pfaff 335, after experimenting with various pulleys with the clutch motor. I used a small 1 3/4" pulley on the motor, fitted a large 8" pulley on the machine itself and once I tweaked the settings in the servo I got it to crawl along! Top speed is also quite slow, which is fine by me.
Fitting a larger pulley on the machine helps immensely, as it slows things down while giving more torque. On some machines it's difficult (if not impossible) to fit a larger pulley - my Singer G166 is one that I can't fit one to - so a speed reducer may be a good idea. I intend to build one for the Singer eventually, to go with the servo on it.
Been reading several things on the servo motors, Wiz had mentioned 1 in a write up about a built in gear reduction of 3/1 built in. I have found a video or 2 but no pricing information as of yet. That one seems like it may be the way to go even more so if you can control the speed with the drive.
The other units like the Consew I'm wondering if you would loose any punching power on start up if it was turned way down to creep along. Rather not have to buy a servo and a separate speed reducer if I don't have to.
SARK9 I also am a maintenance man but for a CNC machining facility. It sounds like rock crushers running full tilt all around me most of the time.
As popular as the "servo" motors have become, someone should compile a sticky about the various designs and pros/cons.
I think the model with the integral geared-reducer is no longer around, but I'm not in the supply chain. Others may know.
The main *species* divisions for these motors are brush or brushless....both have their fans. I've not owned a brush-style motor that employs the rheo dial for speed range control, but they seems to have a reputation for better starting torque at minimal RPM. I will leave that subject for its adherents.
I have probably owned 10 of the Consew servo-type motors...they suit me pretty well for the stuff I sew. Recently, they seem to have replaced the older style (CS-1000-with an optical speed controller) with a more modular design (the "Premier" CSM-1000) which I *hear* uses an hall-effect sensor, though I confess I've not had either of my two apart to see.
My 2 cents: I think the later generations of the older model CS-1000 were somewhat preferable to the new units
in a several ways...one, the optical control in the later ones seemed to be pretty usable right out of the box, but if you did the well-known "hack" to the blade, you really could get super fine predictable control of the low speeds that I don't think could be much better. I personally found shaping a progressive arc shape out of a thin, opaque material gave the best granularity, but many had good results with the "gradient" method. The older units also had a traditional belt-tensioner threaded rod which everyone knows from the clutch motor designs. I also miss the switched 110V outlet for a sewing lamp on the rear of the switch body.
The new Consew Premier CSM-1000 is rated for roughly the same 3/4 hp/wattage/RPM as its elder, and now has the unit broken up into 3 parts- the motor and its mount, the actuator with control arm, and the much larger switch unit with the electronic controls. There is a new range of applications one can use this new design for, by reason of the remote actuator---it can be mounted anywhere in any position, which is dang useful. The downside is the controller does seem a bit more abrupt when starting now..... its not horrible, but its certainly not as delicate and gradual as a CS with a well-done optical hack. I can literally make my old motors take (n)number of seconds to go from TDC to the needle touching my material if I limit my coffee intake. These new actuators will undoubtedly get modded at some point. The other main potential drawback with the new design is the lack of a positive mechanical belt tensioner rod to hold its setting against the reactive force of the belt when it suddenly hits high resistance at speed. I really haven't (yet) worked mine hard enough to test the failure point, but I'm not 100% confident some of the leather jobs won't overload it. Its not particularly robust. New vs. old:
post-46726-0-97423400-1445178148_thumb.j
post-46726-0-38258500-1445178178_thumb.j
-DC
