shug Report post Posted November 8, 2015 I have been using 7_8oz leather for my holsters but am wondering if i should use a heavier hide?i would appreciate viewpoints on this,also,is the term roughout just the flesh side on the outside of the holster and what is the benefit of this?thanks. Quote Share this post Link to post Share on other sites
snubbyfan Report post Posted November 9, 2015 Generally I use 9-10 ounce for holsters depends on what it's for. This holster's 9-10 ounce. The reinforcement piece is 7-8 ounce and the retention strap's 9-10 ounce. 7-8 ounce rough side out for this pocket holster. That's to help it stay in the pocket when the gun's drawn. Quote Share this post Link to post Share on other sites
Dwight Report post Posted November 9, 2015 I have been using 7_8oz leather for my holsters but am wondering if i should use a heavier hide?i would appreciate viewpoints on this,also,is the term roughout just the flesh side on the outside of the holster and what is the benefit of this?thanks. I have been using 7_8oz leather for my holsters but am wondering if i should use a heavier hide?i would appreciate viewpoints on this,also,is the term roughout just the flesh side on the outside of the holster and what is the benefit of this?thanks. One of my favorite IWB holsters for a full size 1911 is 4/5 oz. The only ones I make that are over 9 oz thick, . . . are all two layers, . . . made John Bianchi style. I find that the treatment of the leather is far more important than how much skin is there. As for roughout, . . . it is generally used to keep the holster outside from being too slick and moving around, . . . to look like a spaghetti western cowboy, . . . or in some cases, to be a bit more gentle on the weapon. The hair side will not absorb oil, grit and grime like the flesh side will do, . . . becoming an inadvertent sanding machine, . . . working on your weapon's finish. May God bless, Dwight Quote Share this post Link to post Share on other sites
mlapaglia Report post Posted November 9, 2015 Rough out is also what you make when you cut a left hand pattern and you need a right hand holster. Ask me how I know Quote Share this post Link to post Share on other sites
Boriqua Report post Posted November 9, 2015 (edited) Rough out is also what you make when you cut a left hand pattern and you need a right hand holster. Ask me how I know That is REALLY funny!! So true To the OP .. You kind of have to base it to some degree on the gun you are making the holster for. When I started I always used 9/10. Its really thick ... terrible to try and bone and breaking it in can be a bear. I then discovered that putting a sub in a 9/10 oz holster made the holster heavier than the gun. In general I use 8/9 oz for most of my pancake holsters for your most common 4-5 inch guns but I will go heavier or lighter depending on the gun I am making the holster for. I just finished a holster for an 8 inch ruger redhawk and I used 6/7 oz lined with 4/5 oz. I did a Rami and used 6/7 only. But like I said ..8/9 has been my go to for most unlined work for the last 3 years. 8/9 ounce for 1911 9/10 on the twins because of the extra length 6/7 for this little cz and 6/7 laminated to 4/5 for this beast. It was hard to hold up with one hand so I wanted it built ford tough Edited November 9, 2015 by Boriqua Quote Share this post Link to post Share on other sites
JLSleather Report post Posted November 9, 2015 I use quite a bit of 7/8. 6/7 for a pocket holster (or even 5/6 on a bitty one), and 8/9 or heavier for some larger models. And the comment about rough outs really IS funny I would of course never do that, and tha's my story an im stickin to it. Quote Share this post Link to post Share on other sites
chiefjason Report post Posted November 10, 2015 I use 8-9 sides. But I'll cut the holsters for smaller guns lower on the side to use the thinner leather too. Larger guns get cut from the spine. Particularly the back side of the holster. Quote Share this post Link to post Share on other sites
druid Report post Posted November 10, 2015 I used 14 oz on this one: I had that leather laying around from another project and decided I'd try it. It's a bit of a beast to mold and even worse to stitch. I had to drill the stitching holes because my awl is too thick and makes a gargantuan hole when you try to get through the other side. This leather would take tooling/carving very well but since it's actually a personal concealment holster, I'm fine with it being plain. Quote Share this post Link to post Share on other sites
joli Report post Posted December 23, 2024 Hello Gentlemen. May I rephrase the question of the original poster? What leather thickness would you masters use for IWB Holsters? What leather thickness would you use for OWB Holsters? (Photos grabbed online.) Quote Share this post Link to post Share on other sites
Mablung Report post Posted December 23, 2024 13 hours ago, joli said: Hello Gentlemen. May I rephrase the question of the original poster? What leather thickness would you masters use for IWB Holsters? What leather thickness would you use for OWB Holsters? (Photos grabbed online.) Have you read the other replies? You’ve posed a fairly binary question, when the answer is really, “It depends.” The answers depend on the weapon, placement on the body, and user preference, not to mention the cut of leather you’re using. 9 oz belly will never work as well for a holster as 6 oz shoulder, for instance. By way of example, I usually carry a CZ P-01 Omega with a dot and a spare mag, all AIWB (i.e., up front inside my pants). It’s a weighty rig, for the overall dimensions of the firearm. 7/8 works just fine for it. Wouldn’t use less than 6/7. I’m working on an updated design using 8/9 shoulder that will be really tough and will take carving nicely. Do I need it that thick? Not really. But it will be bombproof, which is what I wanted. Quote Share this post Link to post Share on other sites
cord1974 Report post Posted 16 hours ago This was made with 7/8 oz. Most of my molded holsters are. Quote Share this post Link to post Share on other sites
