mikesc Posted July 30, 2016 Report Posted July 30, 2016 (edited) "Something else".. When the reverse lever is down, ( machine in reverse ) it is at the bottom of it's "slot" in the machine head..measure the space in the "slot" that is left above it, make a wedge ( wood or brass, or thick hard plastic ) that will fit into that "slot" space..Thus the "wedge" will hold the reverse lever in the down position..make a "lip" on the wedge ( so as to stop it falling inside the machine head )..fix a ring onto the part of the "wedge" that is facing outwards towards you..( you could make it all out of brass in one piece ) so that you can pull the wedge out ( allowing the machine to run in "forwards" ) after the required stitches have been made in reverse.. You could even make it "spring loaded" so that you'd have to swing it down to put it into the slot, but that a quick tap downward on the reverse lever would release it to swing back up and out of the way.. Got access to compressed air ? or a low voltage DC solenoid ? ( or a scrap car door lock solenoid )..or a knee operated lever with spring return..even more possibilities open up.. Edited July 30, 2016 by mikesc Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members cdthayer Posted July 31, 2016 Members Report Posted July 31, 2016 This machine doesn’t have the slot for the reverse lever, but your idea would work for one that did. This one just has a lever attached to a shaft on the right end of the machine, and has a spring inside the pillar to hold the linkage in the up position when not reversing. I never have grown very fond of machines that have reverse levers or buttons that need to be held while backtacking or sewing in reverse (mostly domestic home-use machines, but some industrials). I prefer the ones that have a lever that will stay put until I’m ready to move it and sew the other way. I think my daughter’s power stand has a peddle rigged up on it to activate the reverse with a foot, so she’ll be ok. I’m having my problems because I’m fiddling with it in a treadle stand just to play with it and make sure it sews well for her. I have a couple of power stands that I could try it in, but I’m just having too much fun with it in the treadle. Vinyl and woven upholstery fabric can be sewn with the 226 fairly well in a treadle. Maybe I can hang a pork chop from the lever, and train my little shop dog Rex to take a bite from it when I need reverse? That would take some serious training, and I don’t know if either one of us is up to that.... CD in Oklahoma Quote "I sew, I sew, so it's off to work I go....." My sewing machines:Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Members dikman Posted August 1, 2016 Members Report Posted August 1, 2016 18 hours ago, cdthayer said: Maybe I can hang a pork chop from the lever, and train my little shop dog Rex to take a bite from it when I need reverse? Sounds like your medication might need changing...... Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members leecopp Posted August 10, 2016 Members Report Posted August 10, 2016 I rigged a spare industrial table top to a two speed xwide, two speed patcher treadle base. I tried treadling my 111w155 and felt like there was just too much machine resistance. I freely admit that while the machine sews well under power, I am not convinced that it is operating to spec as I had never used another. I guess I need to try one more time with the smaller drive wheel and get things settled in my mind. The machine is a heavy beastie. I am using the above treadle on my 42-5 with good success. I am also using an orphan 29k band wheel for my 78-1 just to slow things down some from the 16" industrial bandwheel. I have recently switched to 1/4 hollow poly tubing which seems to slip a little less and can be easily adjusted. Quote
CowboyBob Posted August 11, 2016 Report Posted August 11, 2016 I set a needlefeed 111W up once for an Amish guy that wanted to sew belts & worked but was pretty hard to treadle ,we stuck a walking foot 111w in the stand & it really took alot more foot power than the needlefeed.The walking foot 111w has alot of resistance going on when it walks it makes it hard to treadle.The older mchine like 29 & 42-3 have large wheels & the walking foot works different & they will spin & go around -3 x when you do it if they are oiled good.It might help a 111 treadle easier if you could find a heavier handwheel w/a small pulley.One like what's on the 42-5. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
mikesc Posted August 11, 2016 Report Posted August 11, 2016 I'd be tempted to rig up something using a chain drive and gears , pedals etc from a bicycle..I think you'd get more control and power for less "effort" like that..could be a fun project ..could even add wheels and go mobile :)..and..add a basket for the dog, and a cooler for the pork chop and a few beers..:)..The Australian version would require a built on BBQ.. Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members Yetibelle Posted August 26, 2016 Members Report Posted August 26, 2016 I like that converted 29K base. I think I will have to try that. Nice Work! Quote One day I hope to learn how to sew..... Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
