Members CustomDoug Posted August 27, 2016 Members Report Posted August 27, 2016 (edited) On 7/15/2016 at 7:30 PM, Art said: If I were to modify the one I have, I would put a second motor on, or a clutch setup to continuously run the bell knife and intermittently run the feed. The two motor system would allow for variable speed on the feed Expand Do you have any specifics ideas for accomplishing this? I'd like to add a second motor also but don't know where to start. I'd think an adjustable servo motor would be ideal for slowing the feeder speed. Doug C Edited August 27, 2016 by CustomDoug Quote
Moderator Art Posted August 28, 2016 Moderator Report Posted August 28, 2016 On mine it would just be a matter of finding a clutch that would work with that shaft. If you want to go with two motors, it is a bit easier, just install another motor and hook to the other shaft. I haven't tackled it as it is not high on my list. If Consew (Chinese these days) and Fortuna (German) can engineer it, it won't be a problem, they don't use any secret parts that I know of. Art Quote
Members CustomDoug Posted August 31, 2016 Members Report Posted August 31, 2016 A picture of a dual motor set up would be a tremendous help. I looked but could not find one. Anyone know of a site with such a pic? Doug C Quote
Members Silverd Posted June 3, 2018 Members Report Posted June 3, 2018 Id like to throw a probably obvious question into this thread from someone with only landis 5 in 1 skiving experience. Will the Fortuna or Fortuna clome style skivers work on bridle leather straps? Silverd Quote
Members Sonydaze Posted June 3, 2018 Members Report Posted June 3, 2018 On 6/3/2018 at 8:35 PM, Silverd said: Id like to throw a probably obvious question into this thread from someone with only landis 5 in 1 skiving experience. Will the Fortuna or Fortuna clome style skivers work on bridle leather straps? Silverd Expand Yes, we make a lot of straps with a buckle on one end. The buckle end gets skived down so the fold over isn't as thick. With the straight foot on the skiver. it can be set up to quickly and nicely bevel the end of the strap as well. Quote
Members Silverd Posted June 3, 2018 Members Report Posted June 3, 2018 The equine bridle straps are sometimes skived on both sides (left and right) their entire length...as well as the ends where the buckle is married. A Landis 5 in one will technically handle that work but has a tendany to leave drive wheel witness marks. At least on Veg Tan. I've not tried to use it on bridle leather but I assume there will be some evidence as a consequence. The Fortuna skiver has the drive wheel positioned on the skiving side; probably for that very reason. I invested in the Landis before I turned tiller North tward the equine trade and will serve it up on Ebay if it makes sense. Silverd Quote
