Members Dwight Posted November 14, 2016 Members Report Posted November 14, 2016 I was told that polishing a cutting blade will make it MUCH better as a cutter, . . . What is the process for polishing a blade? Thanks, may God bless, Dwight Quote
electrathon Posted November 14, 2016 Report Posted November 14, 2016 Polishing and stropping are the same thing. Once you use a quality stone and your blade is razor sharp step up to your strop and polish it till it is sharper. Quote
Members Dwight Posted November 14, 2016 Author Members Report Posted November 14, 2016 OK, . . . not meaning to sound funny, . . . but how do you strop the blade out of a splitter? I'm thinking there should be some way other than pulling that blade out and handling it with my hands that can cut and bleed profusely should I make a mistake with a razor sharp splitter blade. I bleed easy and profusely, . . . May God bless, Dwight Quote
Members Big Sioux Saddlery Posted November 14, 2016 Members Report Posted November 14, 2016 (edited) I use a cloth wheel loaded with various types of compound on an electric motor (not a bench grinder). I always let my splitter blades go way too long before I take them out because I hate the job. It's not so much the danger part of it as it is taking the time to do it and then getting the blade set back where I want it when I'm finished. The only blade I haven't taken out yet is the one out of my big splitter. . . 18 or 20 inches. That one does scare me. Sometimes for a quickie job of stropping, I rub some compound on a piece of leather and pull it backwards through the splitter. It "kind of" works. Edited November 14, 2016 by Big Sioux Saddlery Quote
Members OLDNSLOW Posted November 14, 2016 Members Report Posted November 14, 2016 what size splitter is it? I have the 6 inch Tandy one I use on belt ends that I have done a few times now, each time after running several straps through it. Size might be the factor on how it is done. For the one I have and there are several others on the market under different names, but, I loosen the hold down bolt on one side remove the other swing out retighten the remain bolt and run a stone over the blade in the appropriate direction then repeat with the leather. The loosen the bolt switch the blade to the opposite side, I think you get the picture, I am still a newb but that is how I have done it with good success. Quote
MADMAX22 Posted November 15, 2016 Report Posted November 15, 2016 Here is one video on stropping splitter blades. Quote
Members Dwight Posted November 15, 2016 Author Members Report Posted November 15, 2016 OK, . . . thanks, Madmax, . . . I had visions of my hands holding this thing, . . . slipping, . . . crying, . . . bleeding, . . . you know the drill. Now I see it can be done rather safely, . . . may just up and get me one of them there toys. May God bless, Dwight Quote
Members Colt W Knight Posted November 15, 2016 Members Report Posted November 15, 2016 I use finer sharpening stones(hone) to Polish things like jointer and planer blades. Quote
Members TomG Posted November 15, 2016 Members Report Posted November 15, 2016 17 minutes ago, Dwight said: OK, . . . thanks, Madmax, . . . I had visions of my hands holding this thing, . . . slipping, . . . crying, . . . bleeding, . . . you know the drill. Now I see it can be done rather safely, . . . may just up and get me one of them there toys. May God bless, Dwight Crying??? there's no crying in leatherwork!!!! Quote
