Members utah leather Posted December 17, 2016 Members Report Posted December 17, 2016 I am thinking about using beeswax over my alcohol based dyes for my belts, I have been using Resolene but don't like the plastic look ( and yes I mix it 50/50 ) . My question is if I use the natural beeswax with some neatsfoot oil in it what is the best technique to apply and exactly to buff it with and how long do I wait until I buff it ? How often should it be reconditioned and with what ? Quote
MADMAX22 Posted December 17, 2016 Report Posted December 17, 2016 Usually I use one of those little crock pots and add about equal parts bees wax and parafin wax then add some neatsfoot oil. Heat this until it is all mixed then pour into a container and let cool. It should be about the consistency of soft butter (will look and feel like sno-seal). I will rub this in sparingly and either let it sit in a warm room or area, or hit it with a heat gun BEING VERY CAREFUL to not over heat the leather. Then I usually let it sit for over night and buff out the next day. Thats what I do anyways. Quote
Members utah leather Posted December 17, 2016 Author Members Report Posted December 17, 2016 thank you, I will try this, is this your reciepe for the finish coat ? how many coats to give it a little water protection ? How often should it be reconditioned Quote
MADMAX22 Posted December 18, 2016 Report Posted December 18, 2016 (edited) Well it works pretty decent but its not 100% as most anything isnt. "Usually" with vegtan when I get to the point of finishing Ill do a 'light' coat of neatsfoot oil, one or two of tankote, then a coat of beeswax mix, then the beeswax mix whenever its required. The neatsfoot you can do a very light light coat, your mix will have some in it however IMHO its not enough for thicker leathers. The mix will permeate the tankote once its dry but I feel the combination of the two work good and provide decent protection and a natural looking finish. Wanted to add I did just get some beef tallow in and have a recipe of tallow,beeswax,touch of oil that I wanna try out however I have used the recipe above for a while, and use the beeswax mix on my work boots as well. Edited December 18, 2016 by MADMAX22 Quote
Members Dwight Posted December 18, 2016 Members Report Posted December 18, 2016 1 hour ago, MADMAX22 said: Usually I use one of those little crock pots and add about equal parts bees wax and parafin wax then add some neatsfoot oil. Heat this until it is all mixed then pour into a container and let cool. It should be about the consistency of soft butter (will look and feel like sno-seal). I will rub this in sparingly and either let it sit in a warm room or area, or hit it with a heat gun BEING VERY CAREFUL to not over heat the leather. Then I usually let it sit for over night and buff out the next day. Thats what I do anyways. I do the same thing, . . . without the parrafin. Weigh out equal weights of neatsfoot oil (not the compound, . . . use the oil), . . . and pure beeswax. I pour mine in muffin papers, . . . it's a little stiffer than Max's concoction, . . . I rub it on, . . . hit it with a heat gun, . . . melt the wax, . . . rub some more on, . . . and so forth until I get a good buildup, . . . let it cool and the oil slip down into the leather, . . . buff the next day. . . . love the effect of it. Got the recipe from the niece (?) of an old saddler from up Oregon way, . . . number of years ago, . . . May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
MADMAX22 Posted December 18, 2016 Report Posted December 18, 2016 Dwight I think the parafin helps keep it somewhat softer not sure though. I think Tinkertailor has some old literature of concoctions that are similar they use to use. Anyhow like ya said the finish is really nice. Quote
Members Eddie Q Posted December 23, 2016 Members Report Posted December 23, 2016 i experimented with Sno-Seal on a couple holsters and very satisfied with it (been using it for years on my boots) !! The finish is nice and slick after a few days,not waxy or sticky at all and water proof. Quote
Members impulse Posted December 27, 2016 Members Report Posted December 27, 2016 I posted this recipe recently: I make my own "Bushmans Leather Dressing" by melting 1 part beeswax, 1 part parafin wax, 2 parts neatsfoot oil and 1tspn eucalyptus oil. The eucalyptus prevents mould. Because beeswax varies in hardness, sometimes I need to add pure gum turpentine to make the mix creamier. Use the dressing sparingly and after rubbing in well, leave for 30mins or so and it will leave the leather supple but can be buffed up to a satin shine which repells water. I never use straight oils on leather as too much oil can weaken the fibres and also makes it impossible to get a sheen. I have saddles and harness that are still good after 40yrs of service using this dressing. Quote
Members chiefjason Posted December 28, 2016 Members Report Posted December 28, 2016 I do about 50-50 beeswax and neatsfoot oil and throw in a splash of U-82 saddlers oil. I can run my fingers through it and get enough on my finger tips to rub a section of leather. My holsters get 3 rounds of wax and heat gun to soak it in. Then they sit overnight. I still do a light coat of mop and glo over it and don't get the plastic look. But it's dull so I toss on some atom wax and buff. Yeah, probably overkill but I get a really nice finish out of it. Quote
Members Dwight Posted December 28, 2016 Members Report Posted December 28, 2016 5 hours ago, chiefjason said: I do about 50-50 beeswax and neatsfoot oil and throw in a splash of U-82 saddlers oil. I can run my fingers through it and get enough on my finger tips to rub a section of leather. My holsters get 3 rounds of wax and heat gun to soak it in. Then they sit overnight. I still do a light coat of mop and glo over it and don't get the plastic look. But it's dull so I toss on some atom wax and buff. Yeah, probably overkill but I get a really nice finish out of it. Hey, chief, . . . what is saddlers oil? Always looking to maybe take my work up a notch, . . . and that sounds a bit intriguing, . . . Sometimes my wax/oil doesn't quite come out the way I want it to, . . . maybe that is what I need to add to it. Appreciate added info if you have time. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
