Members jimi Posted January 3, 2017 Author Members Report Posted January 3, 2017 Hi, the screw is for blocking the rotation of the foot. you can fix it in one position without it moving. Quote
Moderator Wizcrafts Posted January 4, 2017 Moderator Report Posted January 4, 2017 I got the missing Singer lock screw and installed it a long time ago. It is a thumb screw, similar to the ones used to screw on edge guides onto flat bed machines. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members AngieNZ Posted January 6, 2017 Members Report Posted January 6, 2017 I agree lol I have 2 29 k 53 and my mum has a 29k 13 That stops the revolving head from turning Quote
Moderator Wizcrafts Posted January 6, 2017 Moderator Report Posted January 6, 2017 Jimi; I finally remembered to measure the length of my gearboxes on my 29k71 and 29k172. The small bobbin k71 gearbox measures 190mm, while the 172 large bobbin model measures 200mm. The large gearbox is about 28mm wide at the widest part of the shuttle hole, while the k71 is just 25mm wide. I hope this helps. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members jimi Posted January 7, 2017 Author Members Report Posted January 7, 2017 Wiz, thanks for the info. have you tried the large gearbox in the 171?? this one here measures 197mm long and has about a 4mm gap at the end. has anyone actually tried fitting a large bobbin gearbox in a 171??? Quote
Moderator Wizcrafts Posted January 7, 2017 Moderator Report Posted January 7, 2017 2 hours ago, jimi said: Wiz, thanks for the info. have you tried the large gearbox in the 171?? this one here measures 197mm long and has about a 4mm gap at the end. has anyone actually tried fitting a large bobbin gearbox in a 171??? No. The needle hole would be ~5mm too far to the left of the needle. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted January 7, 2017 Members Report Posted January 7, 2017 Jimi, thats why I asked for the parts number. I assumed the large bobbin gear box would probably fit. I once had the chance to try a 29K60 gear box (large bobbin) but it did not fit. Too bad. But I kowno there once was a large bobbin short arm patcher but that was one of the Jap "U" Singers afaik. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members jimi Posted January 7, 2017 Author Members Report Posted January 7, 2017 Thank you gentlemen. i will forget about that experiment then. meanwhile i will clean up the base and upload the progress. Quote
Members SARK9 Posted January 7, 2017 Members Report Posted January 7, 2017 8 hours ago, Constabulary said: Jimi, thats why I asked for the parts number. I assumed the large bobbin gear box would probably fit. I once had the chance to try a 29K60 gear box (large bobbin) but it did not fit. Too bad. But I kowno there once was a large bobbin short arm patcher but that was one of the Jap "U" Singers afaik. Consew makes what they badge as a "29B" these days, which is a short arm/large bobbin machine equipped for the handwheel to be mounted in either position. A couple of other importers also handle similar models, long or short arm. I've not seen exactly which components of their castings were copied to use original Singer parts, but it may open up a new avenue for you to explore. I couldn't wait out the avaricious hardware speculators in my area, so I bought a new Consew, since I needed its capacities. I replaced the hook which came with mine with a high-quality Japanese version made for an original large-bobbin Singer, and so far all the parts made for Singers have been drop-in fits. -DC Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
Members jimi Posted January 7, 2017 Author Members Report Posted January 7, 2017 Thank you Sark9 for the info, very nice looking clone you got there. it looks well made? changing over parts is an option left to explore but by the looks of things large gearbox`s seems to look wider also. it may be possible but i think some milling to the gearbox would have to be done?? Quote
