Members mixmkr Posted February 6, 2017 Members Report Posted February 6, 2017 (edited) My plate had the numbers 98-11 and the slots didn't quite line up with the holes in the bed.... so a little dremel-ing fixed that as you can see. Earlier in the thread I had a picture before, where I just used one screw with the tabs not really doing anything, hanging off the side. After a bit, it tended to shift, but won't now. And yeah...why drill the machine bed when you can drill a lesser expensive bracket instead? Edited February 6, 2017 by mixmkr Quote JUKI LU562, Singer 107 W1, Thompson PW201 mini walker, a couple of plastic fantastics for light duty "home stuff".... ya know...fixin' and altering clothes.....
Members Willie0 Posted February 21, 2017 Author Members Report Posted February 21, 2017 The thought of drilling holes was too daunting, so I ended up buying an attachment bracket off ebay. The Sailrite binder hooked up to the bracket sans the attachment's chromed part with a touch of dremel grinding. So far this is working very well, with a solid feel. This seems to be a solution that will work nicely for my hobby projects. Since the Sailrite is only held on with one screw, it no doubt would not be a good way to attach the binder for someone who relies on this professionally. Quote
Members leecopp Posted February 26, 2017 Members Report Posted February 26, 2017 The 3/16 -32 mounting hole mr greg identified above accepted a #10 -32 on my seiko stk 8bld3 . Seemed like a very nice fit. Equivalent.. dont know. Easier to find for me. Quote
Members dikman Posted February 27, 2017 Members Report Posted February 27, 2017 The Singer treadle that I'm restoring needed a tapered bolt (acts as a pivot) and I have absolutely no idea what the thread size is!!! I finally found a 10 mm metric bolt just fitted, without being too loose, and the threads will lock up. Good enough. Bloody sewing machine threads drive me nuts!!!!!! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Bluefever Posted May 19, 2020 Members Report Posted May 19, 2020 On 2/6/2017 at 12:57 PM, Gregg From Keystone Sewing said: If you are drilling and tapping holes into the bed of your machine, you're doing it wrong. I made and attached an image of Juki with LU-563 with proper base plate from T/A, 460-563J mounted using 200095 Set Screw. No mods, direct bolt on from the supplier. Hope this helps. Where could I buy these 2 part numbers you show here. Quote
Members Bluefever Posted May 19, 2020 Members Report Posted May 19, 2020 On 2/21/2017 at 3:39 PM, Willie0 said: The thought of drilling holes was too daunting, so I ended up buying an attachment bracket off ebay. The Sailrite binder hooked up to the bracket sans the attachment's chromed part with a touch of dremel grinding. So far this is working very well, with a solid feel. This seems to be a solution that will work nicely for my hobby projects. Since the Sailrite is only held on with one screw, it no doubt would not be a good way to attach the binder for someone who relies on this professionally. How could I find the Modified bracket you show here. I have searched attachment brackets on ebay with no luck. Quote
Members Constabulary Posted May 19, 2020 Members Report Posted May 19, 2020 (edited) Don´t know where you are living but Collge Sewing in the UK has them: https://www.college-sewing.co.uk/226292-swing-guide-singer-111w-211w-211g.html or check ebay: https://www.ebay.com/itm/Swing-Away-Edge-Sewing-Guide-226292-For-Industrial-Walking-Foot-Sewing-Machine/401372513600 Edited May 19, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members nylonRigging Posted May 19, 2020 Members Report Posted May 19, 2020 2 hours ago, Bluefever said: How could I find the Modified bracket you show here. I have searched attachment brackets on ebay with no luck. Is your machine not have a R-side slide plate like singer 111 or 212, or another clone machine, like being discussed in thread topic ? . Because the R-side slide-plate, will completely mount/hold a ( swing away ) R-angle seam binder attachment you use. you don't need to use that bed attachment swing arm with mounting to your bed . . Quote
Members Bluefever Posted May 20, 2020 Members Report Posted May 20, 2020 On 5/19/2020 at 2:23 PM, Constabulary said: Don´t know where you are living but Collge Sewing in the UK has them: https://www.college-sewing.co.uk/226292-swing-guide-singer-111w-211w-211g.html or check ebay: https://www.ebay.com/itm/Swing-Away-Edge-Sewing-Guide-226292-For-Industrial-Walking-Foot-Sewing-Machine/401372513600 Thank you Quote
Members Bluefever Posted May 20, 2020 Members Report Posted May 20, 2020 On 5/19/2020 at 4:07 PM, nylonRigging said: Is your machine not have a R-side slide plate like singer 111 or 212, or another clone machine, like being discussed in thread topic ? . Because the R-side slide-plate, will completely mount/hold a ( swing away ) R-angle seam binder attachment you use. you don't need to use that bed attachment swing arm with mounting to your bed . . Thank you for the reply. My machine does Not have holes in the slide plate to the right of the needle. Unfortunately. Quote
