Members MrLentz Posted March 14, 2017 Members Report Posted March 14, 2017 Hello, I am finally learning to sew a zipper into a case, a small dopp kit. I was wondering if there is any big difference between the aluminum zippers vs. brass? I like the aluminum color better, but are there any downsides in using them? To me aluminum seems like a soft metal so possibly it could fail much faster. Thanks! Quote
bikermutt07 Posted March 14, 2017 Report Posted March 14, 2017 I am posting because I would like any information on zippers at all. They are a mystery to me. Thanks. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Contributing Member JLSleather Posted March 14, 2017 Contributing Member Report Posted March 14, 2017 I stay away from teh nylon zippers for all but the smallest projects. Otherwise, I've had a pair of insulated cover-alls with an aluminum zipper for years now... no troubles - and they do get some hard use (now if I could just find them after moving!). Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Thornton Posted March 14, 2017 Members Report Posted March 14, 2017 I go by color of leather. Black leather gets aluminum, Browns and reds get brass. Just my preference. Quote
Members MrLentz Posted March 14, 2017 Author Members Report Posted March 14, 2017 Thanks everyone, that certainly helps clear things up. @Bikermutt, I am getting a lot of my initial zipper learning just from the Al Stohlman book on Making Leather Cases volume 2. On page 28 he breaks it all down. Then there are a few cases that illustrate techniques for attachment. Quote
Members nrk Posted March 14, 2017 Members Report Posted March 14, 2017 12 hours ago, MrLentz said: Hello, I am finally learning to sew a zipper into a case, a small dopp kit. I was wondering if there is any big difference between the aluminum zippers vs. brass? I like the aluminum color better, but are there any downsides in using them? To me aluminum seems like a soft metal so possibly it could fail much faster. Thanks! do more research.. Quote
bikermutt07 Posted March 14, 2017 Report Posted March 14, 2017 2 hours ago, MrLentz said: Thanks everyone, that certainly helps clear things up. @Bikermutt, I am getting a lot of my initial zipper learning just from the Al Stohlman book on Making Leather Cases volume 2. On page 28 he breaks it all down. Then there are a few cases that illustrate techniques for attachment. Thanks, I have been thinking of getting that series. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Contributing Member fredk Posted March 14, 2017 Contributing Member Report Posted March 14, 2017 As above; quality zippers last better than cheap ones whether they be plastic, aluminium or brass. However, in damp or wet environments the aluminium one will corrode faster and seize up sooner.eg, a case for a fishing reel; use plastic or brass for quality, but not aluminium Quote Al speling misteaks aer all mi own werk..
Moderator Wizcrafts Posted March 16, 2017 Moderator Report Posted March 16, 2017 I do a lot of zipper replacements in a variety of goods, in my commercial leather shop. here's my 2 cents worth... I try to choose the best zipper for the project. When I replace a wrap-around, double pull zipper in a small pouch, I prefer a #5 plastic coil zipper. Ditto for money belt zippers. Jeans typically use short brass #5 zippers. Light weight jackets and blazers are fine with a #5 zipper of any material. But, heavy weight leather jackets are best fitted with a #7 metal tooth zipper. Very heavy items and items under a lot of stress along the zip line will benefit from a #10 zipper retrofit. I either match the color of the original zipper and tape, or ask the customer if they mind if I choose, based on what I have in stock, or have easy access to. In most cases, I use YKK zippers and pulls. They are the most reliable and long lasting whether made of plastic coil or formed Vislon, aluminum, nickle, or brass. If only the pull is bad, but the zipper is not a YKK, I will try a Zlide-on (see below *), or else I must replace the entire zipper set. For this I usually charge a long wheelbase 5. If the zipper is very long, as in a rifle bag tarp or tent, my price goes up exponentially. You can purchase bulk zipper tape in various size rolls from Ohio Travelbag (OTB), Wawak and ZipperStop. If the tape and teeth are okay but the pull won't close the teeth, a zipper plier can be used on the back of the zipper to close the gap until the teeth merge again. You can buy this tool from Wawak or OTB. It resembles a common nickle finish pair of pliers, but there is a wide open gap in the center of the teeth on both jaws. This gap lets the teeth grab the rear sides of the zipper without hitting the pull tab or its mounting bracket. I've saved many a zipper for customers when all that was wrong was the pull needed a little clamping down. It can give the owner a lease on life of the zipper at a very low cost (beer money). European garments may have the separating zipper pull on the left, rather than the right side, which is typical in the USA. You will probably not be able to find left hand pulls mounted on separating jacket zippers. If the zipper is a #5, you should be able to sew it in backwards to place the pull on the left. Some zippers will allow this, while others will warp and fight the pull all the way up and down. If a pull has stopped closing the teeth and clamping down on the back of it doesn't fix it, you can buy Zlide-on* zipper pulls from Ohio Travelbag. They can be popped open to slide them over the teeth, then clamped down to lock them into the path. Zlide-ons are life savers for a zipper repair person. In addition to stocking a wide range of Zlide-ons, you can buy a zipper repair kit containing numerous pulls, end stops and closure brackets. I got mine from OTB. They also sell special pliers to install the little end stops. I usually keep about a hundred zippers and replacement pulls in stock and bags upon bags of end and closure stops, in various colors. ZIppers can be a bonus service and a good money maker for a leather shop. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
bikermutt07 Posted March 17, 2017 Report Posted March 17, 2017 Thanks Wiz. That was as always lots of information. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
