alpha2 Posted May 14, 2017 Report Posted May 14, 2017 I got one of the Tandy ponies when I started this leather thing. I got the higher level one, but it still needs some help to be "not annoying" to use. So far I've re-contoured the top of the clamp. (cut/peeled off the leather, contoured the wood on a disc sander, reglued the leather.) It was just too blunt for my liking. I also added a wire to guard the thread from hanging up on the wing nut. THAT is really annoying! Then, I counter sunk the bold head at the other end of the bolt from the dastardly wing nut. There are many ways to immobilize that bolt, this is just what I came up with. As you can see from the pictures, I have some extra Styrofoam insulation hanging around. I used contact cement to put a small piece on each side of the clamp, tapered so as to not let the thread hang up. Also put a larger piece at the bottom of the clamp to hold the awl. It's all easy stuff to do, but it makes a huge difference when trying to get a stitching flow going. Oh, and still had a lot of Styrofoam, so I made a holder for various misc. stitching stuff. It won't last forever, but I can make a thousand more with my stash of material. Quote So much leather...so little time.
Members Bodean Posted May 14, 2017 Members Report Posted May 14, 2017 Cool mods. I got to get off my keister and build me one. Quote
bikermutt07 Posted May 14, 2017 Report Posted May 14, 2017 Thanks for sharing the ideas. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members NCArcher Posted May 14, 2017 Members Report Posted May 14, 2017 A more permanent solution to the styrofoam is to set a couple of rare earth magnets into each side. I like your wingnut guard. I need to do something to stop the thread tangling on the wingnut. As you say, REALLY annoying. Quote
Members Sanch Posted May 14, 2017 Members Report Posted May 14, 2017 necessity it truly is the mother of invention and creativity!! all of the issues you ran into you overcame in a cost efficient manner way to go! Quote
alpha2 Posted May 14, 2017 Author Report Posted May 14, 2017 (edited) 32 minutes ago, NCArcher said: A more permanent solution to the styrofoam is to set a couple of rare earth magnets into each side. I like your wingnut guard. I need to do something to stop the thread tangling on the wingnut. As you say, REALLY annoying. Good idea. I love rare earth magnets. These are on a plug strip at my bench. They hang on to the plugstrip and release the tools, except for the roller at the left. The wide metal bracket on the roller pulls the magnet off of the plug strip, no big deal, it goes right back on when I'm through using it. Edited May 14, 2017 by alpha2 Quote So much leather...so little time.
Members Mattsbagger Posted May 15, 2017 Members Report Posted May 15, 2017 And I have magnets on the side for needles. I do hate the thread snagging the wingnut. Quote
Members keplerts Posted May 20, 2017 Members Report Posted May 20, 2017 Changing the wing nut to a "Cam" clamp as pretty much eliminated my thread catching problem. Love the cam clamp. I took that suggestion from someone who suggested on this board a while back. Quote
alpha2 Posted May 20, 2017 Author Report Posted May 20, 2017 I agree that would be a nice improvement, but I haven't seen a plan for one. I suspect the geometry for that would be critical for effective use. I'm up for it if someone does the R&D! Quote So much leather...so little time.
Members Sanch Posted May 21, 2017 Members Report Posted May 21, 2017 No need for cam nuts or wing nuts if the clamping is done from the center also no need for magnetic needle holder.my "wing nut" is in the center of the jaws and needles go in the neoprene inserts on the jaws see red circle for "new wing nut" and lower red circle for insert ... Quote
