Members BDAZ Posted June 2, 2017 Members Report Posted June 2, 2017 Glue is not my friend! It's messy and too easy to ruin a piece with a rouge drip. It stinks and when I use spray adhesives outside, a wind usually comes up and blows the tacky surfaces into each other. If all goes well I often don't get the lining square with the leather and i have to glue in little patches. Sometime I line with fabric and the glue saturates the fabric is some areas ruining it. I have also tried water soluble cements, wood glues..all a huge PIA. I ran across HeatnBond at the Walmart sewing section yesterday. I tested it out with a hand Iron and it appears to be amazing! After cooling I was unable to separate either the fabric or the suede from the flesh side of some 5-6 oz vegtan. To that end, I ordered a 15" square heat press. If this all works out, this product could cut my production time down by 30%, cheaper than using glues, and potentially no ruined pieces. Has anyone used this stuff with a press? Short term tests indicate the stuff works great and withstands flexing, is inexpensive and the temperatures required don't damage leathers and fabrics. In fact, it appears to be easier to use a fabric lining then to dye the exposed flesh side of unlined products. (I use drum dyed leather from Wickett-Craig. I supply for resale to companies who have my products in their catalogs, so color consistency is critical) Thanks for your input, Bob Quote
RockyAussie Posted June 2, 2017 Report Posted June 2, 2017 Interesting stuff. Here's a link I just looked at on the product.https://www.youtube.com/watch?v=dmDvjE14tek I would be curious to know how it would go on a curve with a heat gun.I will have to see if available here in Australia and give it a try. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members BDAZ Posted June 2, 2017 Author Members Report Posted June 2, 2017 First off, I used the Ultrahold only and noticed no issues stitching with my Cowboy machine. Nothing was "gummed up". I also used a hand iron to melt the paper backed adhesive into the flesh side of the project first, then removed the paper and ironed the suede or fabric onto the the leather. As to using a heatgun, probably not because it requires heat AND pressure BUT it does take wet forming with out issues. I am optimistic that the press arriving today will allow me to laminate half a dozen pieces simultaneously. The unit comes with a silicone cover sheet, and additional silicone sheets are available, which would be useful for even hand ironing projects. BTW I used a granite stone with a scrap piece of fabric to be able to get firm and even pressure on the item. My heat press arrived this morning! https://www.amazon.com/gp/product/B01BCUUIY4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 I felt sorry for the post man who had to haul the huge box to the door in the 100F heat. Unboxed it and plugged it in. Set the temp to 350F and the time to 20 seconds and an a test. I pressed the film to some tartan fabric, let it cool and removed the release paper. The adhesive film was perfect! I then took a leather piece, flesh side down, and placed it on the adhesive and closed the press for 20 seconds. The result was PERFECT! The platen is 15" x 15". I did a similar test using sheep suede and also perfect! The suede separated before the adhesive failed AND I tested it on a bag flap with repeated flexings. As least as good as glue and probably better. This is the Business!... Bob Quote
RockyAussie Posted June 3, 2017 Report Posted June 3, 2017 6 hours ago, BDAZ said: First off, I used the Ultrahold only and noticed no issues stitching with my Cowboy machine. Nothing was "gummed up". I also used a hand iron to melt the paper backed adhesive into the flesh side of the project first, then removed the paper and ironed the suede or fabric onto the the leather. As to using a heatgun, probably not because it requires heat AND pressure BUT it does take wet forming with out issues. I am optimistic that the press arriving today will allow me to laminate half a dozen pieces simultaneously. The unit comes with a silicone cover sheet, and additional silicone sheets are available, which would be useful for even hand ironing projects. BTW I used a granite stone with a scrap piece of fabric to be able to get firm and even pressure on the item. My heat press arrived this morning! https://www.amazon.com/gp/product/B01BCUUIY4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 I felt sorry for the post man who had to haul the huge box to the door in the 100F heat. Unboxed it and plugged it in. Set the temp to 350F and the time to 20 seconds and an a test. I pressed the film to some tartan fabric, let it cool and removed the release paper. The adhesive film was perfect! I then took a leather piece, flesh side down, and placed it on the adhesive and closed the press for 20 seconds. The result was PERFECT! The platen is 15" x 15". I did a similar test using sheep suede and also perfect! The suede separated before the adhesive failed AND I tested it on a bag flap with repeated flexings. As least as good as glue and probably better. This is the Business!... Bob Thanks Bob. When you say it takes wet forming without issues can I ask what you mean by that? I think of wet forming as being leather being cast or formed into a shape and I can't understand how you could then use a flat press.Regards Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members BDAZ Posted June 3, 2017 Author Members Report Posted June 3, 2017 Brian, What I meant was that the laminated suede lined leather wet forms with no problem. Bob Quote
RockyAussie Posted June 4, 2017 Report Posted June 4, 2017 Thanks Bob. I have never done or thought to wet form with the suede attached before. I can see a lot of potential with this product for attaching cut out pieces to other pieces and I will have to give it a try if I can find where to get it here.It could save a lot of time when making some products like these picture below I think. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members BDAZ Posted July 2, 2017 Author Members Report Posted July 2, 2017 After a month or so of using the heat press and adhesive I am STOKED! I figure it saves me 30% or more on assembly time by replacing spray glue. I am able to laminate 5 or 6 pieces at a time. The cost of adding a nice fabric to the flesh side of a pouch flap is negligible and approaches the cost and trouble of dying.Less trouble and slightly more cost. Also rockey, you could probably use the material for all your appliques. I am currently using 260F at 30 seconds with a silicone cover sheet on the press. I am also testing a double sided tape offered by the same company, which appears superior to the Tandy tape, fits the Tandy dispenser and is easier to apply due to the transparent backing. Quote
Members beltbuckles Posted October 17, 2017 Members Report Posted October 17, 2017 so, im struggling to picture how this all works out, but this could help me.. is there a video or demonstration of how this process works... is this still what you are currently using? Quote
Mark842 Posted October 17, 2017 Report Posted October 17, 2017 Following this...very interesting. Curious to see updates with the press and how this ultrabond stands up to time Quote
