Uwe Posted June 6, 2017 Report Posted June 6, 2017 I spent some quality time with my Cowboy CB-4500 trying to wrap my head around the adjustment procedures for hook timing. Best way to learn is trying to teach somebody else. Which is one reason I make the videos - it helps me understand how things work. Hopefully others will find it useful, too. Here's the video: Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members Constabulary Posted June 6, 2017 Members Report Posted June 6, 2017 Uwe, once again - an excellent Video! What else can I say.... You have reinvented the hook timing - the dial and eraser wedge is a great idea... Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members brmax Posted June 6, 2017 Members Report Posted June 6, 2017 Outstanding instruction video! Uwe, thanks again for your help. Good day Floyd Quote
Members Gregg From Keystone Sewing Posted June 6, 2017 Members Report Posted June 6, 2017 I'll check back when I have more time, Uwe sets the standard when making these videos for sure. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members SolarLeatherMachines Posted June 7, 2017 Members Report Posted June 7, 2017 Uwe, Great video. I'm impressed. Quote Alexander
Members AdamPCain Posted June 7, 2017 Members Report Posted June 7, 2017 I haven't even bought a machine yet but am in a couple weeks. I have been watching your videos just to see what i am in for. Keep up the great content thanks Quote
Members GPaudler Posted June 8, 2017 Members Report Posted June 8, 2017 Beautifully done Uwe. I'm unfamiliar with those machines, will your method work on an Adler 105? Quote
CowboyBob Posted June 8, 2017 Report Posted June 8, 2017 As always,great video,well done !! Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Uwe Posted June 8, 2017 Author Report Posted June 8, 2017 (edited) 2 hours ago, GPaudler said: Beautifully done Uwe. I'm unfamiliar with those machines, will your method work on an Adler 105? I doubt it. Some of the concepts may apply, though. I've never worked on an Adler 105 but I suspect they are very different inside from the 441 class. Thanks for all the kind feedback guys! Edited June 8, 2017 by Uwe Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members Bugstruck Posted March 5, 2018 Members Report Posted March 5, 2018 Uwe, I know this topic is a bit dated but I wanted so say thanks. I knew I needed to do something with my 4500 as I did a quick adjust out of the box about a year ago to get it sewing reasonably right. Basically that was nothing more than advancing the timing more than it should be as it was lazy and catching the loop (more in reverse) and fraying thread. That temporary fix shouldn't have but it worked as well as it did but it was always noisier on the business end than I thought it should be (thread take-up mostly, like it was fighting the hook and shuttle to some extent) and I knew I needed to get back to it. Busy with other things. I was also using my Adler 067-373 (wish I'd seen your video on that before I overhauled mine) for some projects I'd have preferred to be on the 4500 with because I trusted it more. Watched your video (a few times or more) and dug in. Took the better part of the day (I'm not fast) and I stripped one of the small feed cam screws breaking it loose. You are right, those top end screws are tight. Don't use the allen set that comes with the machine. The ball end did that screw in (not enough surface bite). Anyhow, got that resolved for the moment (I'll need a new screw) as it's more of a temporary torx screw now. Anyhow and to my point, that video is awesome. I have zero reservation going to that machine now and it is as quiet as I imagine one of these workhorses can be. I knew it needed work but the change surprised me, absolute pleasure to operate now. My needlebar did the same left to right movement you had in the video and you were absolutely correct, that ex-centric adjustment is sensitive/testy. Didn't take long but it was (4) times before I had it right. One thing I noticed being relatively new to this machine that anyone experienced would know..... Leaving any tail of thread on the bobbing after clipping it off causes it to drag on the frame below and jumps tension about pretty hard as the bobbin rotates. Leave a little tag, watch the open end of the bobbin case and pull some thread, you'll see and feel what occurs. Less than peanuts compared Uwe's contribution but it may help someone. Used your degree wheel, nice. Brake on the motor was my eraser. My handwheel sets much farther from the machine end than yours. I don't know what you use to film (can we still call it that?) but the clarity is unusually high quality. Thanks again Uwe. My machine thanks you. Quote
Members Gregg From Keystone Sewing Posted March 6, 2018 Members Report Posted March 6, 2018 Second post; this video is flat out AWESOME. Great job UWE. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Troy I Posted March 7, 2018 Report Posted March 7, 2018 Wow great video... very helpful Quote TroyImler's LeatherBentonville, VA 22610 http://www.ebay.com/usr/imlers_leather
Members aaronthearcher Posted February 21, 2023 Members Report Posted February 21, 2023 Uwe, Amazing and helpful video worked for me had my machine running like a top until last night, not sure what happened but something not good. broke needle stopped machine dead, thread stuck in race etc. Now my rear most hook position is almost a quarter of a turn too far back and the rear most movement doesn't align with my 0 degree position, where is the adjustment for that part of the timing. I can set the rear most position to the 1mm visible hook but it isn't in time with the correct position of needle or wheel... Quote
Contributing Member Tim Schroeder Posted February 21, 2023 Contributing Member Report Posted February 21, 2023 I thought this was pretty interesting. I admit I'm not the sharpest tool in the shed. I make a lot of those ID 10T errors. This is kinda confusing. Quote
Contributing Member Tim Schroeder Posted February 22, 2023 Contributing Member Report Posted February 22, 2023 Anybody with a Cowboy 4500 care to post how the Cowboy manual tells you to adjust the hook timing. Quote
Members Cdtaylor Posted November 15, 2023 Members Report Posted November 15, 2023 I can’t begin to tell you how grateful I am for this instruction video!! Thank you so very much! It’s perfect and I will be able to fix it now. Quote
