Hi! Does anyone know a good source for embossed metal hand bag logos that doesn't have a high minimum order quantity?
  • 1 month later...
They aren’t metal but wood.  I love using these tags I get them on Etsy   Wearhouseindustries
Ok thank you. That looks great! I really have my mind set in metal or leather logos though. I will keep hunting! Thanks again for replying!
Depending on what exactly you want try a local trophy shop
try searching for  ( copy and paste into search engine, then hit enter )
metal clothing labels alibaba
and
metal handbag and bag tags alibaba
you'll find many suppliers offer custom service from your artwork / designs..MOQs can be found as low as 50 units.although MOQ s in the 100 or 200 or 500 is more common.
You can limit google searches to a particular site by using a search string like:
  site:alibaba.com metal bag tags
The site:xxxx.xxx is what restricts the search to the site.
Tom
Tom..reason I didn't say to use the site: "operator" ( in this case ) was that ( on my machine and browser at least ) the site: "operator" usually gives a general SERP with no images included , whereas a search string with the site name at the end , gives some images* included in the general SERP..otherwise the actual pages linked to on the alibaba site in both SERPs are the same.
IME the site: "operator" removes some ads from the  SERP too ( usually the ones at the top )..although you still get one or two at the bottom, I can't imagine that any one targeting terms without putting a "neg" on any use of site: is going to do their adwords QS any good, alibaba target the use of their own name and "metal tags", but someone else's ad shows up on that page too for keywords "bag tags" in a search from my area at least.
*I thought she'd maybe prefer to get some images back in the initial SERP.
Shame that G hijacked the + "operator" for use on G+ and also pretty much ignore "surrounding quotes" to restrain results to exact match these days..I know that one can go into "advanced" , but most people don't .and even then G still doesn't really respect surrounding quotes like they used to.
Edited by mikesc
Thanks guys! I actually have ordered from alibaba before. I ordered custom laser logos. The metal scratched easily and the laser was hard to see. I want to make sure the next ones I order are high quality. If anyone has ordered from a place before and liked the quality, please shoot me the source!!
  • 2 months later...
A little older post, but if someone does laser wood engraving, which is what the picture looks like, they should be able to engrave on leather.  Some of your local print or marketing shops may do laser engraving.
A local metal shop may also do engraving on metal.  They should be able to engrave more deeply than your other samples.
Thank you baroness. I actually did have a local trophy shop do a few for me before. They charged me 12 per piece so I started looking for alternatives. They would go lower for a larger quantity, but I figured paying for the ones with a mold was better. Looks like I will have to go back to them until I can afford more high end ones. I’m also considering having them make me some laser engraved labels..not sure if that would take away from the look of my bags though...I haven’t seen many high end designer bags with leather labels. I may be wrong though!
