Members Sheilajeanne Posted January 31, 2018 Members Report Posted January 31, 2018 I've been using Fiebing's dye reducer for diluting my dyes, but it really has a strong smell, and I'm wondering if there are harmful chemicals in it. I know a lot of you use denatured alcohol instead. Is there much of a difference between the two? Is the alcohol better/safer? Need to know, because I need to replenish my supply really soon! Quote
alpha2 Posted January 31, 2018 Report Posted January 31, 2018 To my knowledge, it's the same thing. I've stopped paying for the dye reducer, and using alcohol without any noticeable difference. And, it's CHEAP! It also works great to clean my airbrush when I apply dye that way. Quote
Members JMcC Posted January 31, 2018 Members Report Posted January 31, 2018 Hi Shelia, I use alcohol exclusively and have never had any issues with smell or fumes. Hope that helps 2 minutes ago, alpha2 said: And, it's CHEAP! Ditto Quote
Members TomG Posted February 1, 2018 Members Report Posted February 1, 2018 Denatured Alcohol. About $10 a gallon at the hardware store Quote
garypl Posted February 1, 2018 Report Posted February 1, 2018 4 hours ago, alpha2 said: To my knowledge, it's the same thing. I've stopped paying for the dye reducer, and using alcohol without any noticeable difference. And, it's CHEAP! It also works great to clean my airbrush when I apply dye that way. I have used denatured alcohol for years - works well.... Quote
Members Brianm77 Posted February 1, 2018 Members Report Posted February 1, 2018 I think water based may be obvious, but any brands or types of dyes that alcohol does not work with? Quote
garypl Posted February 1, 2018 Report Posted February 1, 2018 15 hours ago, Brianm77 said: I think water based may be obvious, but any brands or types of dyes that alcohol does not work with? I use alcohol with Fiebings oil dyes with no problems Quote
Members chiefjason Posted February 2, 2018 Members Report Posted February 2, 2018 9 hours ago, garypl said: I use alcohol with Fiebings oil dyes with no problems Same here. I thin all my dyes with alcohol. Quote
