Members CLW Posted February 3, 2018 Members Report Posted February 3, 2018 Any tips on how to properly line up inside and outside pieces for saddle stitching holes using diamond point chisels? I am having a dickens of a time lining up the saddle stitching holes i make with a diamond chisel on the front of my card case or wallet with the holes i punch in the inside pieces. I have tried using the BRL precut templates which come with hole marks but none of my diamond chisels match the spacing and doing a project with a one hole chisel seems crazy. Last time i had the holes on the outside piece going in one direction and the holes on the card case inside pieces going in the opposite direction. (A shame because I spent a lot of time tooling some sumo wrestlers.) I can't afford a drill press or anything like that. Any ideas and pointers will be most welcome. Thanks ! Quote
Members Webicons Posted February 3, 2018 Members Report Posted February 3, 2018 The way I do it is: 1. Glue or tape the pieces together. 2. Scribe a line where I want my stitching line to be. 3. Place piece on a solid surface and put a scrap piece of leather or similar under by pieces. 4. Orient stitch line away from me (north/south direction). Place Chisel on scribed line perpendicular to the piece. 5. Look down the stitch line like sighting a gun to make sure Chisel is strait and right on stitch line. 6. Hammer in Chisel. Quote
Members CLW Posted February 3, 2018 Author Members Report Posted February 3, 2018 Awesome, thanks. Does this mean you punch holes after tooling and dyeing? Or do you use a non permanent cement to glue them together for hole punching then tool and dye? Double sided tape?? Quote
Members Mattsbagger Posted February 3, 2018 Members Report Posted February 3, 2018 I use the same steps. I dye and finish all pieces before sewing. I use different colored thread for contrast. Also I primarily airbrush my dye on. Only people I know that dye after sewing are ones who dip dye. Does all that make sense? I does in my head.lol Quote
alpha2 Posted February 3, 2018 Report Posted February 3, 2018 I use contact cement and occasionally double sided tape, but not just any tape. It has to be tape that is designed to hold leather together. The stuff Tandy has is actually quite good for the purpose. Make sure to hammer pieces together, (with a scrap leather to protect the project). Alternatively you can just use a roller made for the purpose, or a rolling pin to do the job. This makes sure the cement has good adhesion. Remember, any cuts on the leather will accept the dye much more readily than the grain surface of veg tan. Holes, edges, slots will have dark edges as the dye gets right into the flesh of the leather at those locations. PRACTICE on some scrap to see what the piece will look like when dyed. For that matter, try your stitching chisels on some scrap first, to get your technique down. Keeping the chisel in line and vertical is the key. Hang in there! We've all been there...some still are, ask me how I know. Jeff Quote So much leather...so little time.
Members Dun Posted February 3, 2018 Members Report Posted February 3, 2018 6 hours ago, CLW said: Any tips on how to properly line up inside and outside pieces for saddle stitching holes using diamond point chisels? I am having a dickens of a time lining up the saddle stitching holes i make with a diamond chisel on the front of my card case or wallet with the holes i punch in the inside pieces. Do you mean like "with the single chisel set you have it's hard to line up the angled holes when you have to flip the project over? I have seen that some pricking irons can be purchased with a reverse set as well https://www.amazon.com/Leather-Pricking-Lacing-Stitching-Piercing/dp/B01MZH91I7 (i havn't tried those it just came up in a search) Quote
bikermutt07 Posted February 3, 2018 Report Posted February 3, 2018 You should be pricking\chiseling from one side only. Attach your pieces with an adhesive and strike from the "front" side. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members CLW Posted February 4, 2018 Author Members Report Posted February 4, 2018 Thanks... I think what is happening is that I punch the holes separately in the front and inside pieces and don't attach them first to punch holes. I am going to try that, then peel apart for tooling etc. It makes sense if you punch first to attach them but I was letting the how do I get them apart or line them up correctly get in my way. Thanks to all and will let you know how it goes.... Quote
Members Mattsbagger Posted February 4, 2018 Members Report Posted February 4, 2018 22 minutes ago, CLW said: Thanks... I think what is happening is that I punch the holes separately in the front and inside pieces and don't attach them first to punch holes. I am going to try that, then peel apart for tooling etc. It makes sense if you punch first to attach them but I was letting the how do I get them apart or line them up correctly get in my way. Thanks to all and will let you know how it goes.... Never punch holes before anything. It's the last step for me before sewing and then last step is edges. Why do you want to punch holes first? Quote
Members billybopp Posted February 4, 2018 Members Report Posted February 4, 2018 Leather tends to distort and "grow" a bit when tooled. If you punch holes then too, they likely will not align again after. As Mattsbagger said, punching holes for sewing is usually near the end of the process. - Bill Quote
