Northmount Posted February 22, 2018 Report Posted February 22, 2018 42 minutes ago, garypl said: I don’t know if I am doing it correctly or if this is what everyone means by handstretching the stitch, but I use the stitch length adjustment to position the stitch so it hits the point. Is this what you are referring to? Gary That works too. Depends on your preferences and your machine. Some easy to adjust stitch length on the run, others not so easy. And of course, you can see above that practice helps a lot. Tom Quote
garypl Posted February 22, 2018 Report Posted February 22, 2018 2 minutes ago, Northmount said: That works too. Depends on your preferences and your machine. Some easy to adjust stitch length on the run, others not so easy. And of course, you can see above that practice helps a lot. Tom Thanks Tom - I will try adjusting the stitch length by hand - might be easier than fooling with the stitch length adjuster. Gary Quote Cowboy 4500, Consew 206RB-4
Members keithski122 Posted February 22, 2018 Members Report Posted February 22, 2018 I use a juki 563 and use the reverse lever too position the stitch on a corner. Quote
Members Gregspitz Posted February 22, 2018 Members Report Posted February 22, 2018 use an edge creaser and put a dot with your awl at the tip...4 stitches before getting to the point start planning...change stitch lengths appropriately like anything it will take some time to get this down usually finishing at the lugs in the same place is harder..I use the same method Quote Greg Spitz MD,FACS Custom Watch Straps 922Leather Gregspitz@922Leather.com
alpha2 Posted February 22, 2018 Author Report Posted February 22, 2018 43 minutes ago, keithski122 said: I use a juki 563 and use the reverse lever too position the stitch on a corner. I don't understand what you're describing. If you're approaching a corner, how do reverse to get there? I've got a reverse lever, but don't see how that will precisely put a stitch in a corner. I'm likely picturing it all wrong? Quote So much leather...so little time.
alpha2 Posted February 22, 2018 Author Report Posted February 22, 2018 36 minutes ago, Gregspitz said: use an edge creaser and put a dot with your awl at the tip...4 stitches before getting to the point start planning...change stitch lengths appropriately like anything it will take some time to get this down usually finishing at the lugs in the same place is harder..I use the same method I can where that would work. I'm no where near the point yet where I could estimate 4 stitches from a certain point where the needle will end up! I know...practice. And what do you mean "at the lugs"? Is that a watch-band thing? Thanks, Jeff Quote So much leather...so little time.
garypl Posted February 22, 2018 Report Posted February 22, 2018 As I approach the corner and I see my stitch will be too far ahead of the corner, I slowly move the stitch lever toward reverse, but not all the way . You will see the foot move to the rear a bit - turn the fly wheel by hand and watch the tip of the needle. When you are close to the surface, do the final adjustment and then push the needle into the leather. Once it is set, you can go the rest of the way down and then lift the presser feet and rotate the leather 90 degrees. Gary mark a spot on a practice piece and sew to the spot, adjusting at the very end so you hit the spot dead on... Quote Cowboy 4500, Consew 206RB-4
alpha2 Posted February 22, 2018 Author Report Posted February 22, 2018 Ah, I see. Lever doesn't go all the way to reverse, just enough to move the foot. I'll have to try that. Some serious practice is in my future. Thanks Quote So much leather...so little time.
garypl Posted February 22, 2018 Report Posted February 22, 2018 1 hour ago, alpha2 said: Ah, I see. Lever doesn't go all the way to reverse, just enough to move the foot. I'll have to try that. Some serious practice is in my future. Thanks Exactly! Quote Cowboy 4500, Consew 206RB-4
Moderator Wizcrafts Posted February 23, 2018 Moderator Report Posted February 23, 2018 6 hours ago, alpha2 said: I don't understand what you're describing. If you're approaching a corner, how do reverse to get there? I've got a reverse lever, but don't see how that will precisely put a stitch in a corner. I'm likely picturing it all wrong? The reverse lever on an LU-563 floats the feed mechanism towards you, shortening the stitch length until it reverses completely. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
