Members FresnoFox Posted February 22, 2018 Members Report Posted February 22, 2018 I am new to posting here though I’ve been reading for several months. Someone is giving me a Singer 31-15. It is my first machine bigger than a home machine. I know it is not ideal for sewing leather. But it’s free so....I am going to pick it up Sun. I haven’t seen it in person yet, just pictures. If I take the head off, will the table fit in the back of a Yukon? It looks like the original table based on google searches I’ve done. Also, what tools will I need to remove the head? Quote
CowboyBob Posted February 22, 2018 Report Posted February 22, 2018 (edited) Great Deal !! Yes.it will fit,we've even put the stands in smaller vehicles like a Honda CRV. Edited February 22, 2018 by CowboyBob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Matt S Posted February 22, 2018 Members Report Posted February 22, 2018 I've put one in a VW Polo before (small hatchback). Took along a tool bag and spent a half hour stripping it down. Head off and in the passenger footwell. Motor ditto. Table top in the back (seats folded down), legs on top of that, all the other gubbins chucked on top of that. Finished the cuppa the nice lady made for me, washed the worst of the rusty schmoo off my hands and off I went. Quote
Members FresnoFox Posted February 22, 2018 Author Members Report Posted February 22, 2018 Thank you! Quote
Members Yetibelle Posted February 22, 2018 Members Report Posted February 22, 2018 If its the solid wood table and standard H-legs with a clutch motor still attached it will be heavy and awkward. I put some cardboard down and slide it on top of that they look bigger in pictures than the actually are, I figure the table is 48 long by about 20 wide, easy for a big SUV. you will have fun they are nice machines and easy to maintain. Quote One day I hope to learn how to sew..... Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
Members FresnoFox Posted February 23, 2018 Author Members Report Posted February 23, 2018 It is the wood table with H legs I believe. My phone automatically deleted the pics she sent me unfortunately and I only have a couple I sent to a friend to look at. I am going to replace the motor with a servo so I could take it off to move since I’m going to anyway. What all tools should I take to remove the head and motor? I’m just starting to make purses so free with some maintenance cost is good until I see if this is going to make any $ at all. Quote
Moderator Wizcrafts Posted February 23, 2018 Moderator Report Posted February 23, 2018 The table should be 20" x 48", with steel legs and a (probably clutch) motor underneath. The head sits in a cutout in the table and has two tilt clamps on the back, for tilting it back to remove the vbelt. With the belt off the 50+ pound head can be lifted off the table. The top of the table will probably have a thread stand and flex lamp and a bobbin winder. If you need to remove the thread stand, you will need a flat blade screwdriver for sure and possibly a Philips driver. The motor will be bolted onto the table with nuts that may have SAE or Metric heads, ranging from 1/2" to 5/8", or 12mm to 18mm. Bring open end wrenches. The motor will have wiring clamped to the table bottom, leading to a switch box that will need to be unscrewed and removed. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members FresnoFox Posted February 23, 2018 Author Members Report Posted February 23, 2018 Perfect! Thank you all so much for the info! Quote
Members dikman Posted February 24, 2018 Members Report Posted February 24, 2018 (edited) I've done this to several (different) tables, I take a set of socket spanners (metric and imperial), a couple of adjustable wrenches, assorted screwdrivers (flat and philips), assorted pliers, a pair of locking vice-grips and a cordless drill (probably not necessary but I take it anyway) - you never know what problems you might run into. Don't forget to take some old cloths as it can be a grubby job! Remove the head unit and turn the table upside down to remove the motor (heavy!!) and dismantle the legs if needed (I find it better to do this as it makes everything manageable). Edited February 24, 2018 by dikman Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members councilman24 Posted March 1, 2018 Members Report Posted March 1, 2018 No need to remove the motor. Pull.the head, no tools. Clean the top by removing a bobbin winder lamp thread stand. Screwdrivers, cresent wrech, wire cutter for lamp cord. Cut and replace if necessary. Slide table in upside down on top. Use ratchet strap to hold in center of vehicle. Don't loose hinges which will fall.out of head. Open end wrenches along with crescent wrench to shorten legs if necessary. Quote
