27 minutes ago, Double Daddy said:
When I run out of Resolene, I'm gonna try the Mop n Glow, per several professional recommendations on here...their results speak for themselves...it's WAY cheaper than the Res and available locally.
what, what!? Details please.
21 minutes ago, Matt S said:
Sponges. Tandy wants £2 for a sponge. I get 20 for 28p at the supermarket. Still works.
I've been using generic q-tips, ( not sure if that is an international term... cotton swabs you clean your ears with) for glue application and for applying edge dye or small dying areas. (funny that I use a dish rag for everything and you guys are stuck with a tea towel ;)
  • Replies 41
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
On 2/27/2018 at 0:37 AM, Mjolnir said:
PS I actually love beeswax. I am about to purchase carnuba wax. but I could probably get some car wax cheaper.
Don't with the car wax; it usually contains additives like silicon which are not good for leather.
Beeswax, carnuba, neetsfoot oil mix feeds the leather and gets right into it. Car wax doesn't and remains on the surface
>>>   Plastic bags are too expensive here [yes, really, about $1 each for a small bag for a few groceries and they fall apart as soon as you use them] I use the free newspapers that come thru my letter box
Same as Matt; cheap sponges from supermarket shop
Edited by fredk
uhm. plastic shopping bags that are free here and go into land fills? I reuse as much as I can, my small town has no recycling program. Tell me I'm misunderstand you. Oh!! so you guys don't have the waste that we do. Makes sense. I think ill start using the cloth bags.
Edited by Mjolnir
add
England basicly outlawed the plastic carrier bags yrs ago everyone brings there own and packs own groceries. We have about 20 Sainsburys reusable shopping bags and confuses people when we pack our own groceries. Lol
Wax paper for gluing and dying on. Q-tips as well for glue. I put a little resoline in a small jam jar that just fits a wool dauber, leave it in there, get a lot of mileage from one dauber. Don't fill past the wool, the shaft will rust quickly. I keep a little bowl of water next to me when I am dying, drop the dauber in that as soon as I am finished then when I have time wash them out and reuse. Old socks for buffing your leather. Wet dry sandpaper taped to my slab for sharpening instead of a stone. I'm pretty cheap but that's all I can think of right now, lol.
As Matt says; All 4 home countries of the UK have banned or limited the use of throw-away plastic bags. In each country shops charge for what used to be free. In England/Scotland/Wales the shops charge about 15p [22c] a bag.  But in N.I. we pay more for the plastic bags. In N.I. most shops charge between 30p - 75p [42c - $1] per bag. So we buy other bags to last longer.  We've reduced the use of throw-away plastic bags by  about 98%.
I'm thinking of branching out and making 'life-time'* shopping bags out of upholstery leather I have
* re-useable shopping bags are known as 'a bag for life' in the UK; but I have a swmbo
Sorry - wandered of topic there
Edited by fredk
I don't do any tooling or carving, so I don't need a thick, heavy slab. But for skiving I use the glass oven door off an old cooker. I got it originally for painting model planes on; it's very easy to clean
Up until recently a friend used an old microwave as his spray painting booth. He knows his electrics so he disconnected the heating element so he could have it on with the door open and the turntable turning slowly. His micro had a vent which he connected to a pipe leading outside to take fumes away. I've thought of doing the same, for spraying small leather goods
I use a cardboard box for my spray booth. I hooked up a computer fan through the back to take fumes away. It sort of works ... a little bit. :unsure:
I was told the only way to go for stamping was a 35 - 40 mm (or heavier) marble or granite slab. Nothing available in my area that I could find, but I did find some 20mm marble tiles. Local tile shop was throwing out some damaged bags of tile adhesive ... so I now have a few ~40mm laminated marble surfaces, around 400 x 400mm, that are stronger than the real stuff because the flaws don't go all the way through.
Kindest regards
Brian
"Whether you think you can or whether you think you can't, you are right"  Henry Ford
Machines: Singer 201p, Kennedy,  Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
