ramble away dprezgay; it all helps to understand your needs
But 24 sets each with its own colour? I think for that you're going to have to go stripey. Using the heat shrink , a piece of red on one set, a piece of red and a piece of yellow on another set, red & blue on another, blue & yellow and so on. Thats easiest way I can see of doing 24 sets each with their own matching colour combo. I forget my maths but I think with 6 basic colours - red, blue, green, yellow, white, black, you will have more than enough colour mixes for 24 sets
Edited by fredk
  • Replies 26
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I vote shrink wrap. Do the whole thing in batches. And, you can get more than one set with each color. Take blue for example. 1" 2" and 3" covers will give you 3 sets of one color but the length will identify which set is which.
As Cledus said to the Bandit; That'll work too
  • 9 months later...
I keep a running assortment  of spray paint  probably no less than 24 colors at least three shades of each color. To be quick about it, I would probably  line up each set and spray paint the handles a different color and paint the tool rack/ holder the same color. Krylon dries quick and has a lot of different colors.  The bad part is that the paint will wear off the chrome handles with use and make the tools look ugly and valueless and purchasing a bunch of colors of spay paint in one go would be expensive.
Overall I doubt the groups that will use these will care much about how they look.
The heat shrink sounds like a winner although time consuming for the number of tools.
Salt-water and vinegar electro etch- permanent and hard to remove to boot!
On ‎4‎/‎30‎/‎2018 at 2:49 PM, Rockoboy said:
I use heat shrink tube on my tools.
I have noticed some of my heat shrink is sliding up and down the handle of some tools, and sometimes falling off. The only colour I can get with adhesive, AFAIK, is black, but I have not used that option yet.
Kindest regards
Brian
"Whether you think you can or whether you think you can't, you are right"  Henry Ford
Machines: Singer 201p, Kennedy,  Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Perhaps your heat shrink didn't shrink down far enough? I use h/s which has an i/d close to the o/d of the tool, that way it shrinks down real tight
It shrank down as far as it would go on the tool shaft, but because the shaft is parallel and not textured (where I applied the heat shrink), there was nothing for it to grip onto, and no glue to hold it in place.
Maybe a couple wraps of insulation tape under the heat shrink would fix the problem. Then again, maybe the heat will destroy the adhesive. Its a learning curve.
Kindest regards
Brian
In Australia if you go to JAYCARS they sell heat shrink with a heat activated glue, they call it double skinned - {I think}, when you use it the glue melts and solves the problem of the tubing sliding off
