Members doorty Posted June 3, 2018 Members Report Posted June 3, 2018 Is there a rule of thumb for the the strength of leather at a given thickness/weight? For instance, if I had a belt with a buckle, how much weight could the belt support before ripping the hole. The same question applies to stitching connecting two pieces of leather or the rings and clips. My use case is mostly around motorcycles, but I'm sure a similar situation arises for horse saddles and other heavy duty situations. Quote
Contributing Member LatigoAmigo Posted June 3, 2018 Contributing Member Report Posted June 3, 2018 The belly section of the hide will not be as strong as the shoulder/back, yet be the exact same thickness/weight. So I'd say there is not "a rule of thumb for the the strength of leather at a given thickness/weight." Quote
Rockoboy Posted June 3, 2018 Report Posted June 3, 2018 Besides the area of the animal where the leather came from, there are other variables that might improve of reduce the strength, breaking strain or shear properties of leather. Defects from scars, imperfect tanning methods, uneven hide thickness for whatever reason. If you consider a different hide or a different tannery or a different country of manufacture, I think the variables could become almost uncountable. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Contributing Member fredk Posted June 3, 2018 Contributing Member Report Posted June 3, 2018 to re-inforce what has been said already; I have some 1.5mm/2mm cow veg tan which I can rip apart like cloth, but I also have some 0.6mm/0.8mm deer skin leather which I cannot rip apart at all Quote Al speling misteaks aer all mi own werk..
Members doorty Posted July 2, 2018 Author Members Report Posted July 2, 2018 Thanks guys. I guess you just look at what others have done. Based on the original post, it looks like about 1" straps of 6oz leather with brass/copper hardware should hold to a moving motorcycle. Quote
Members chrisash Posted July 2, 2018 Members Report Posted July 2, 2018 Rather than the strength of the leather, the wear of the leather may be more important where it constantly moves around You could always test the strength of the leath sample by hanging weights on it say 2 or 3 times what you expect the person to use and dont forget outdoor use has other requirements maybe harness leather Quote Mi omputer is ot ood at speeling , it's not me
Members SheltathaLore Posted July 13, 2018 Members Report Posted July 13, 2018 I think it's going to depend a lot on both the tannage and the species; I've been told that kidskin is stronger than cow leather, and kangaroo is the strongest thing you can get for a given weight. I'd like to say that the finer-grained leathers tend to be stronger for a given thickness, but I don't know if that's universally true. However, stretch is also a factor - the cost of having a material with high tensile strength might be a tendency to accommodate the extra strain by stretching. Quote
Members Treesner Posted January 14, 2019 Members Report Posted January 14, 2019 Im curious about this as well would like to know how many pounds veg tanned 1” 6oz leather could hold on average. @doorty did you do any weight testing? Quote
