JJN Posted June 24, 2018 Report Posted June 24, 2018 Included with a purchase I made was a large quantity of these bronze (or brass) two needle clamps. I have no idea what machine they are for but I suspect it is an old domestic type of machine. It has a 0.25" hole to attach to the needle bar. The holes for the needle shanks are smaller than a normal domestic needle and measure 0.068", or a little over 1/16". The needle centers are 0.085" or 2mm apart. The overall height is 0.688" ant the width is 0.500". The needle holes are drilled through to where the needle bar stops. I have a ton of them. I am sure it is not for an industrial leather sewing machine, but I figured someone on here might recognize them. Any help is appreciated. Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
JJN Posted June 24, 2018 Author Report Posted June 24, 2018 I just tried a couple 16x257 needles and they fit perfectly. Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
ljk Posted June 26, 2018 Report Posted June 26, 2018 This is a twin needle attachment used to add a double stitch to a single needle sewing machine. The one shown I am modifying to make jeans belt loop. The one you have I could use to sew a narrow double line on shoe uppers. Let me know if I could buy one and after trying I will get back to you with feedback. tx Lynn Quote
JJN Posted June 27, 2018 Author Report Posted June 27, 2018 7 hours ago, ljk said: This is a twin needle attachment used to add a double stitch to a single needle sewing machine. The one shown I am modifying to make jeans belt loop. The one you have I could use to sew a narrow double line on shoe uppers. Let me know if I could buy one and after trying I will get back to you with feedback. tx Lynn Lynn, Send me a PM with your address and I will ship 6 of them to you. No charge. Thanks, John Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
Rockoboy Posted June 30, 2018 Report Posted June 30, 2018 On 27/06/2018 at 4:24 AM, ljk said: This is a twin needle attachment used to add a double stitch to a single needle sewing machine Do you mean to say this attachment can make any single needle machine a double needle machine? Surely a double needle machine needs to have double bobbins or be set up as a chain stitch machine. On the other hand, maybe I have no idea what I am talking about. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Northmount Posted June 30, 2018 Report Posted June 30, 2018 Works on a zigzag machine, set for no zigzag (straight). 2 spools on the top, single bobbin. Both threads fed through the tension disks together. My wife uses this for hemming tee-shirts. There are off the shelf twin needles for domestic machines. Tom Quote
Members KeriHat Posted September 24, 2022 Members Report Posted September 24, 2022 On 6/26/2018 at 4:24 PM, ljk said: This is a twin needle attachment used to add a double stitch to a single needle sewing machine. The one shown I am modifying to make jeans belt loop. The one you have I could use to sew a narrow double line on shoe uppers. Let me know if I could buy one and after trying I will get back to you with feedback. tx Lynn Hello, I have a singer 20U33 that I bought because I read that it can be used as a double/twin needle, not knowing how hard it would be to find info and parts. I did find the one pictured (blue background) but everywhere is out of stock and they cannot say when it will be back (ebay, aliexpress, amazon). If anyone has any leads I would really appreciate it! I need the wider gauge as it will be used for double top-stitching seams that are backed with bias tape. Thanks! Quote
Northmount Posted September 24, 2022 Report Posted September 24, 2022 On 6/30/2018 at 11:17 AM, Rockoboy said: Surely a double needle machine needs to have double bobbins or be set up as a chain stitch machine. Just to clarify, the twin needles on top with a spool for each, both threads passed through the tension disks, single bobbin thread on the bottom. The top shows double row of stitches, the bottom thread shows as a single zigzag stitch since it has to hit both top threads. Quote
