Members VeeBee Posted October 11, 2018 Members Report Posted October 11, 2018 Hello all, I've been having this problem with my TechSew 2700 Sewing machine and i pretty much tried everything and maybe now i can get some input from the great leather people here. So, I've had this sewing machine for a while and it's always going out of whack and i'm constantly troubleshooting problems.This time once i start stitching everything will be going fine and when i'm about 10 stitches in the bobbin case starts to make this struggle noise and the tension on my stitches gets to tight, or to loose then it will go back to stitching fine again. I've tried changing the needle, tweaking the hook timing, adjusting the upper, lower and bobbin tension, threading the machine over, re-winding the bobbin and even reset the motor on the machine. Has anyone had this problem? Any suggestions? Thank Yall! Quote
Members chrisash Posted October 11, 2018 Members Report Posted October 11, 2018 I normally put a drop of oil on the hook before starting every day Quote Mi omputer is ot ood at speeling , it's not me
Northmount Posted October 11, 2018 Report Posted October 11, 2018 Hi @VeeBee. Moved your post to leather sewing machines. You'll get more answers here. Tom Quote
Uwe Posted October 11, 2018 Report Posted October 11, 2018 (edited) Check your entire upper thread path starting from the thread spool. Upper thread path issues can cause all manner of problems, including the symptoms you describe. Watch how thread unwinds from the spool as you sew (keep your fingers away from the needle!) You may find it snagging or jerking for some reason. The thread guide hole in the thread stand must be directly above the spool. Some threads are springy and fall off the spool and then get caught under the spool - a thread net may eliminate that issue. Here's a ten year old topic with more details on that: Edited October 11, 2018 by Uwe Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members Pintodeluxe Posted October 11, 2018 Members Report Posted October 11, 2018 I had a similar issue on a flatbed machine, and it wound up being a faulty bobbin case. The bobbin case was simply defective, and wouldn't apply light, even tension on the bobbin thread which caused erratic tension problems. Replacing the bobbin case solved that problem. To test it, load a bobbin and pull on the bobbin thread. Gradually pull out 2-3 feet of thread and see if you have light consistent bobbin tension. I like Uwe's comment about a thread net. I use a short length of my wife's nylons for the same purpose. Quote
Members VeeBee Posted October 12, 2018 Author Members Report Posted October 12, 2018 Thank you everybody for the replies. I tried everyone of your inputs. And now everything is going well. It's so tricky with these machine it's usually the tiniest things that cause major problems. Quote
Members R8R Posted October 12, 2018 Members Report Posted October 12, 2018 One more thing to watch - cheap bobbins. Sometimes they can be just slightly out of round or tweaked and they can bind up a bit in the bobbin case leading to inconsistent lower thread tension. Make sure the bobbin rotates free in the case and the tension on the thread is even. Quote
Members VeeBee Posted October 16, 2018 Author Members Report Posted October 16, 2018 So, i'm having the same problem. It was working well once i switched to a different thickness of leather. I then realized that my take up spring was broken. I've re purchased another one and i will you guys know if this fixed my problem. Quote
