Members flhx06 Posted October 21, 2018 Members Report Posted October 21, 2018 Is anyone using one? I have been eyeing one that the BuckleGuy sells but its $100 + dollars. Currently I am using an awl and a spatula. I am getting ok results but still having trouble keeping it from running over the sides. I am thinking a roller might make my edges more consistent. Quote
Members niakulah Posted October 21, 2018 Members Report Posted October 21, 2018 On 10/21/2018 at 3:21 AM, flhx06 said: Is anyone using one? I have been eyeing one that the BuckleGuy sells but its $100 + dollars. Currently I am using an awl and a spatula. I am getting ok results but still having trouble keeping it from running over the sides. I am thinking a roller might make my edges more consistent. Expand This is my favourite: https://www.rmleathersupply.com/collections/tools/products/edge-paint-roller I have this as well, not as easy to do thick edges like a wallet I did recently, but a lot easier to prep and cleanup after. https://www.rmleathersupply.com/collections/tools/products/precision-bottles Quote
Rockoboy Posted October 21, 2018 Report Posted October 21, 2018 I use an edge paint roller that has a brass cone where the brush would be on a regular applicator, cost is around $6 - $7US from memory, ordered online, just Google it on eBay. *On 2nd thought, for $100+, are we talking about totally different items? Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members flhx06 Posted October 21, 2018 Author Members Report Posted October 21, 2018 Thanks all. I have a hand held cone shaped edge painting roller but it doesnt seem to work for me. It doesnt roll, it drags. Maybe its the piece that I have? My post was referring to something more like this: Quote
Rockoboy Posted October 21, 2018 Report Posted October 21, 2018 On 10/21/2018 at 1:55 PM, flhx06 said: its the piece that I have Expand Absolutely the tool you have. All 3 of mine work perfectly. Each to their own. If you can use the more expensive model, and its within budget, go for it. Of course, that model pictured could not be used on something with tight corners, like some holsters, but it might work great for a large run of belts. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members Stetson912 Posted October 21, 2018 Members Report Posted October 21, 2018 Have you checked the little bearing in your roller? Sometimes paint gets in there and gums it up. Just a thought Quote
Members Nuttish Posted October 23, 2018 Members Report Posted October 23, 2018 Those RM Leather Supply mesh cage rollers are a game changer. The knurled brass ones can leave marks. The mesh ones work great with whatever consistency of edge treatment you use. Quote
Members flhx06 Posted October 23, 2018 Author Members Report Posted October 23, 2018 On 10/21/2018 at 7:15 PM, Stetson912 said: Have you checked the little bearing in your roller? Sometimes paint gets in there and gums it up. Just a thought Expand I'm going to check to see if mine is bound up with paint etc. Thanks for the tip. On 10/23/2018 at 5:45 PM, Nuttish said: Those RM Leather Supply mesh cage rollers are a game changer. The knurled brass ones can leave marks. The mesh ones work great with whatever consistency of edge treatment you use. Expand I think I am going to order one of those. $25 is a small price to pay to achieve perfection Quote
alpha2 Posted October 23, 2018 Report Posted October 23, 2018 On 10/23/2018 at 5:45 PM, Nuttish said: Those RM Leather Supply mesh cage rollers are a game changer. The knurled brass ones can leave marks. The mesh ones work great with whatever consistency of edge treatment you use. Expand This has been my experience. You must apply a moderate amount of pressure to the piece to make it roll, instead of drag. And yes, it tends to leave small ridges from the flutes on the cone. I really like the look of that mesh one! Jeff Quote So much leather...so little time.
Contributing Member Ferg Posted October 23, 2018 Contributing Member Report Posted October 23, 2018 I have never had marks left behind with my brass rollers. Perhaps you aren't putting enough paint on the roller or the paint is too thin. Like everything else worthwhile, it takes a "Little Learning". Ferg Quote
Contributing Member fredk Posted October 23, 2018 Contributing Member Report Posted October 23, 2018 Wot he says. I've only used mine a few times but I've never got ridges and never had to apply any pressure; the roller just glided along Quote Al speling misteaks aer all mi own werk..
alpha2 Posted October 24, 2018 Report Posted October 24, 2018 Yes, it's likely I didn't load up the roller enough. And I didn't stick with it long enough to get good at it. I found I liked the Mr. Clean Magic Eraser better. I cut them into strips, fold it over and dip it into the paint or dye. Amazing how much they can hold, and then let it out at a fairly constant rate. I'll have to practice with the roller some more. Jeff Quote So much leather...so little time.
Members Japi Posted October 25, 2018 Members Report Posted October 25, 2018 The Koreans use a knobbled parallel sided 4inch steel bar handheld turning on bearings within a handle. They use different sized knobbles depending on the viscosity of the edge paint and also whether it's gloss or matt. I have two. They have served me well for many years. Quote
Members bgl500 Posted October 25, 2018 Members Report Posted October 25, 2018 My two favorite applicators are the mesh roller mentioned that RML carries and the KS Blade Punch applicator. The KS Blade tool is a metal rod with a narrow and broad tip. Quote
alpha2 Posted October 25, 2018 Report Posted October 25, 2018 That KS Blade tool is interesting. It's almost like my double ended modeling tool, minus the ball on one end. I'll have to try that out. Jeff Quote So much leather...so little time.
Members flhx06 Posted November 1, 2018 Author Members Report Posted November 1, 2018 I just got my RM leather mesh roller. I’m excited to use it however how does everyone else clean theirs after they use it? Quote
Members niakulah Posted November 1, 2018 Members Report Posted November 1, 2018 On 11/1/2018 at 4:45 AM, flhx06 said: I just got my RM leather mesh roller. I’m excited to use it however how does everyone else clean theirs after they use it? Expand I just use hot water. Quote
Moderator immiketoo Posted November 2, 2018 Moderator Report Posted November 2, 2018 On 10/21/2018 at 1:55 PM, flhx06 said: Thanks all. I have a hand held cone shaped edge painting roller but it doesnt seem to work for me. It doesnt roll, it drags. Maybe its the piece that I have? My post was referring to something more like this: Expand This item would be mostly useless to me. Even if I was going to make a large run of belts, it would never give me the control I want for my edges. I use the cone shaped cheapie as well, but I took the cone out of the handle and roll it between my fingers. Quote Learnleather.com
Members LetterT Posted November 2, 2018 Members Report Posted November 2, 2018 I have this in the mail, should provide a bit better control as the tip is finer serrated the the cone shaped (which I have). Quote
garypl Posted November 2, 2018 Report Posted November 2, 2018 On 11/2/2018 at 12:27 PM, LetterT said: I have this in the mail, should provide a bit better control as the tip is finer serrated the the cone shaped (which I have). Expand Where did you find these? Gary Quote Cowboy 4500, Consew 206RB-4
Members LetterT Posted November 3, 2018 Members Report Posted November 3, 2018 I pick it up on ebay https://www.ebay.com/itm/DIY-Leather-Craft-Edge-Oil-Treatment-Tool-Roller-Pen-Leather-Oil-Painting-Tool/263901418834?hash=item3d71c01552:m:m9MmZhokUuOJ1jx2Vmd7nvQ:rk:2:pf:0 I think I have also seen it on Amazon but they didn't ship to my country. Quote
garypl Posted November 3, 2018 Report Posted November 3, 2018 On 11/3/2018 at 12:20 AM, LetterT said: I pick it up on ebay https://www.ebay.com/itm/DIY-Leather-Craft-Edge-Oil-Treatment-Tool-Roller-Pen-Leather-Oil-Painting-Tool/263901418834?hash=item3d71c01552:m:m9MmZhokUuOJ1jx2Vmd7nvQ:rk:2:pf:0 I think I have also seen it on Amazon but they didn't ship to my country. Expand Thanks! I found this item on Amazon for $7.99 including shipping! Gary Quote Cowboy 4500, Consew 206RB-4
alpha2 Posted November 3, 2018 Report Posted November 3, 2018 I've got to look into those. Jeff Quote So much leather...so little time.
garypl Posted November 4, 2018 Report Posted November 4, 2018 On 11/3/2018 at 7:48 PM, alpha2 said: I've got to look into those. Jeff Expand I’ve been using the grooved roller pen and it works very well, but I’m looking forward to trying out this new pen. Only downside is shipping can take 3-5 weeks. Gary Quote Cowboy 4500, Consew 206RB-4
garypl Posted November 20, 2018 Report Posted November 20, 2018 On 11/4/2018 at 12:15 AM, garypl said: I’ve been using the grooved roller pen and it works very well, but I’m looking forward to trying out this new pen. Only downside is shipping can take 3-5 weeks. Gary Expand I received the new knurled roller pen today and did a quick test - seems to work really well. Very smooth rolling action and Giardini paint went on much more smoothly than the grooved cone roller I normally use. Will do more testing, but my initial impression is that this is a great tool for the money! Gary Quote Cowboy 4500, Consew 206RB-4
