Wot he says. I've only used mine a few times but I've never got ridges and never had to apply any pressure; the roller just glided along
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Yes, it's likely I didn't load up the roller enough. And I didn't stick with it long enough to get good at it. I found I liked the Mr. Clean Magic Eraser better. I cut them into strips, fold it over and dip it into the paint or dye. Amazing how much they can hold, and then let it out at a fairly constant rate.
I'll have to practice with the roller some more.
Jeff
So much leather...so little time.
The Koreans use a knobbled parallel sided 4inch  steel bar  handheld turning on bearings within a handle. They use different sized knobbles depending on the viscosity of the edge paint and also whether it's gloss or matt. I have two. They have served me well for many years.
My two favorite applicators are the mesh roller mentioned that RML carries and the KS Blade Punch applicator. The KS Blade tool is a metal rod with a narrow and broad tip.
That KS Blade tool is interesting. It's almost like my double ended modeling tool, minus the ball on one end. I'll have to try that out.
Jeff
I just got my RM leather mesh roller. I’m excited to use it however how does everyone else clean theirs after they use it?
I just use hot water.
On October 21, 2018 at 4:55 PM, flhx06 said:
Thanks all. I have a hand held cone shaped edge painting roller but it doesnt seem to work for me. It doesnt roll, it drags. Maybe its the piece that I have?
My post was referring to something more like this:
This item would be mostly useless to me.  Even if I was going to make a large run of belts, it would never give me the control I want for my edges.  I use the cone shaped cheapie as well, but I took the cone out of the handle and roll it between my fingers.
Learnleather.com
I have this in the mail, should provide a bit better control as the tip is finer serrated the the cone shaped (which I have).
Where did you find these?
Gary
Cowboy 4500, Consew 206RB-4
