Members wayner123 Posted July 31, 2007 Members Report Posted July 31, 2007 Hey all, I have some vintage leather that the knapp on the back is very smooth. I mean it is slick as the front. I was looking at getting a leather rougher to help when I need to laminate/glue the pieces of it. Is there any homemade rougher or cheaper version than the $50 Tandy leather rougher? I was thinking of a wire dog hair brush, but I have yet to use that. Any help is greatly appreciated.
Moderator Johanna Posted July 31, 2007 Moderator Report Posted July 31, 2007 Sandpaper? Johanna You cannot depend on your eyes when your imagination is out of focus. - Mark Twain
Ambassador The Major Posted July 31, 2007 Ambassador Report Posted July 31, 2007 I use a file cleaner brush sometimes. But as Johanna said sandpaper works just as well, and I have a tendency of using that more than the brush. Shawn Zoladz (The Major) dba Major Productions Everything Leather Saddles and Shoes Excluded You can lead me. You can follow me. Or you can get the hell out of my way. -Gen. Geo. S. Patton
Members whinewine Posted July 31, 2007 Members Report Posted July 31, 2007 a metal brush-type scraper normally used to remove rust from tools- any hardware store has them, perhaps under $1 or $2
Moderator bruce johnson Posted July 31, 2007 Moderator Report Posted July 31, 2007 I use the wire brushes they sell at Harbor Freight or the welding suppliers. They cost about $1.50. Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Moderator Art Posted July 31, 2007 Moderator Report Posted July 31, 2007 That thing is $36 club and $26.50 reseller at Tandy. However in a pinch a hedghog will do, just don't hurt the little fellow. Steel wool from the hardware store works too. Art Hey all,I have some vintage leather that the knapp on the back is very smooth. I mean it is slick as the front. I was looking at getting a leather rougher to help when I need to laminate/glue the pieces of it. Is there any homemade rougher or cheaper version than the $50 Tandy leather rougher? I was thinking of a wire dog hair brush, but I have yet to use that. Any help is greatly appreciated. For heaven's sakes pilgrim, make yourself a strop!
Members Hoyden Posted August 1, 2007 Members Report Posted August 1, 2007 I use one of those wire fox tail brushes for cleanning rust off of metal to rough up leather.
Billsotx Posted August 1, 2007 Report Posted August 1, 2007 (edited) As usual Jo is right-on with sandpaper. I use 80 grit wet/dry sandpaper to prep for glue-ups. (Belt lining, etc.) It makes short work of roughing up a smooth leather surface. If you want less rough use a finer grit. Any sandpaper will work but for prepping a glue-up I don't mess around - 80 grit gets it done. Just do it and drive-on. Use finer grit to true up the edges and even finer to start a burnish. Ultra-fine will burnish in a heartbeat! - 2000 grit. Leather sands better (fast)if it's damp and there won't be much if any dust you might inhale. That's why I use wet/dry. Available at you local hardware or home improvement center. Keep it in order using manila folders. Start off with a couple of assortment packs until you figure out what works for you. It has a lot more use that that expensive callus remover you buy from a leathercraft supply. Sanding sponges are also an options. I even use steel wool to remove marks and blemishes. It's pretty inexpensive and awful handy to have around in my limited experience. Good luck with which ever you choose. Edited August 1, 2007 by Billsotx
Members Romey Posted August 3, 2007 Members Report Posted August 3, 2007 This is what i use for roughing leather Stanly tru form Works faster the anything, dont have to have sand paper laying around, i use it for all glueing and such Romey Cowboy inc highcountryknives
Members Brandon Posted August 3, 2007 Members Report Posted August 3, 2007 Hair blade if you already have one.
